I have Plant Design Suite Ultimate on subscription. I have just installed 2016 from a USB stick but when I try and open and activate Inventor it is saying my serial number is wrong. I have noticed that the serial numbner is correct but the product key is different to what I have.
My serial number and product key should be edited, however the activation screen is showing XXX-XXXXXXX / 797H1
All of the other software within the suite works fine , i.e. Revit,Autocad, Navisworks, 3DS max. But Inventor doesn't.!!
I have uninstalled and reinstalled but still the same problem.
I did previously download a trial version of inventor, but this was uninstalled - not sure if this could be causing the problem ?? However I have tried opening inventor direct from the application file in the 2016 folder - but again the same problem.
Help please !
Please be aware that this is a public forum posting serial numbers or personal information is not advised
Edited by
Discussion_Admin
Solved by RSOUTHEE. Go to Solution.
Just to close this out, the USB media stick supplied was at fault. The solution was to download the software from Autodesk ( which took 3 days !) and install from the download - all ok after that and no problems.
