Hi to all,
I try since yesterday to install Autocad 2018 to my PC, window 7 sp 1 64.
I get error message: "please run material library2018.msi first"
1. I have used the Browser download and get 2 files:
AutoCAD_2018_English_Win_64bit_dlm_001_002.sfx and AutoCAD_2018_English_Win_64bit_dlm_002_002.sfx
2. I have tried the Orca tool to modify the installer
3. I have tried the MicrosoftProgram_Install_and_Uninstall.meta (1)
4. I disable my antivirus
5. Clear the %temp% folder
6. Run as administrator
7. disable the firewall
And I still get: "please run material library2018.msi first"
here is the short Installation log file:
2018/4/19:08:32:45 FRED PCC === Setup started on PCC by FRED ===
2018/4/19:08:32:45 FRED PCC Path_Length: 158
2018/4/19:08:32:45 FRED PCC Current Directory C:\Autodesk\AutoCAD_2018_English_Win_64bit_dlm
2018/4/19:08:32:45 FRED PCC Launch
2018/4/19:08:32:45 FRED PCC CommandLine
2018/4/19:08:32:45 FRED PCC Current Directory C:\Users\FRED\AppData\Local\Temp\_AI4569.tmp
2018/4/19:08:32:53 FRED PCC === Setup ended ===
2018/4/19:08:32:48 FRED PCC === Setup started on PCC by FRED ===
2018/4/19:08:32:48 FRED PCC Path_Length: 158
2018/4/19:08:32:48 FRED PCC Current Directory C:\Users\FRED\AppData\Local\Temp\_AI4569.tmp
2018/4/19:08:32:48 FRED PCC Launch
2018/4/19:08:32:48 FRED PCC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\FRED\AppData\Local\Temp\_AI4569.tmp\Setup\AcSetup.dll
2018/4/19:08:32:48 FRED PCC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/4/19:08:32:53 FRED PCC PageOpen LaunchDialog
2018/4/19:08:32:57 FRED PCC PageOpen LicenseDialog
2018/4/19:08:33:00 FRED PCC PageOpen ProductInfoDialog
2018/4/19:08:33:00 FRED PCC PageOpen ProductSelectionDialog2
2018/4/19:08:33:06 FRED PCC PageOpen FullProgressDialog
2018/4/19:08:33:06 FRED PCC Installing DirectX Runtime: "C:\Autodesk\AutoCAD_2018_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2018/4/19:08:33:29 FRED PCC DirectX Runtime return code: 0
2018/4/19:08:33:29 FRED PCC Install DirectX Runtime Succeeded
2018/4/19:08:33:29 FRED PCC Installing Autodesk Material Library 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={C928E4FC-B352-4E6E-BC69-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2018/4/19:08:33:48 FRED PCC Install Autodesk Material Library 2018 Succeeded
2018/4/19:08:33:48 FRED PCC Installing Autodesk Material Library 2018 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2018" SETUP_PACKAGECODE={DD42F784-12DC-49EE-8045-600335BE940B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={C928E4FC-B352-4E6E-BC69-E578C6B5D699} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2018/4/19:08:33:54 FRED PCC Install Autodesk Material Library 2018 - Base Image Library Failed Installation aborted, Result=1603
2018/4/19:08:34:05 FRED PCC Rollback Autodesk Material Library 2018 Succeeded
2018/4/19:08:34:05 FRED PCC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Thanks for your help !
Cheers, Fred.
Hi to all,
Cheers, Fred.
@Anonymous
Is there a reason why you are posting again about the same issue: https://forums.autodesk.com/t5/installation-licensing/impossible-to-install-autocad-2018-please-run-material/m-p/7943711
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
Mark Lancaster
