i have problem in opening autocad 2025
gumaco1991
gumaco1991
Hello ,
my laptop is gaming laptop and has high specs..
I cannot open the AutoCAD 2025 ...it will take long time to be opened ...this problem happened 2 weeks ago till now .
any help?
Replies (7)
pendean
Community Legend
Community Legend
Turn off wifi and bluetooth on your laptop (aka put it in airplane mode), does the issue with the software go away when you start it up?
gumaco1991
i did ..but same problem
pendean
Community Legend
Community Legend
Simon_Weel
Doesn't it start at all? Or does it take a long time to load? Any error messages in the Windows Eventlog?
gumaco1991
No error message … long time to start
mdavis22569
Do a reset to default .. save the settings, but don't add them back just yet.
2nd test, double click on trying to open this test file:
https://autode.sk/3Sq83rv
Mike Davis
Simon_Weel
Could also be corrupt user files. Try renaming folder C:\Users\<name>\AppData\Roaming\Autodesk\AutoCAD 2025 to something like .old and rename registry key hkcu\Software\Autodesk\AutoCAD\R25.0 to .old as well. Now if you start AutoCAD, it will recreate the user files from scratch. If there's no difference, then delete the newly created folder / registry key and rename the .old ones back to their original name.
