Hi, I am currently in university where we have to use maya. The problem is that when I was using the verification everything went blank and stopped working. Anyways, my account was verified anyways in some way, since I cannot redo the verification. The problem is that I got a 30-day trial instead of a student version, is there any way to fix this since I cannot redo the verification?
Cheers!
Solved by Darin.Green. Go to Solution.
Solved by Mark.Lancaster. Go to Solution.
@Anonymous
Welcome to the community..
Log into your Autodesk Account, jot down your serial # and then go into the program/help about and follow the steps to change your license from trial to activated.
Mark Lancaster
& Autodesk Services MarketPlace Provider
You have to generate a serial number from the education community. When prompted in the software, choose Activate and use the serial number provide to you from the education community.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
