Installation & Licensing
I can't install revit 2022
12 REPLIES 12
Message 1 of 13
10431 Views, 12 Replies
why I always Can't install revit from autodesk desktop app?
please help me
Labels (1)
12 REPLIES 12
Message 2 of 13
leowarren34
Hi @Anonymous,
Try using the browser download method: https://knowledge.autodesk.com/customer-service/download-install/download/about-download-methods/browser-download-method-for-autodesk-account
Run the installer with Antivirus and UAC disabled as administrator.
If that all fails please upload your install log file.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Location-of-the-log-files-generated-by-the-installation-of-an-Autodesk-product.html
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 3 of 13
in reply to: leowarren34
Theank you
I will try this method. I Hope this work
Message 4 of 13
205088
Thank you very much. You helped me
 just I click Droite with my mouse and run (execute) the  file as administrator
Message 5 of 13
rodolfo.salcedomo
Hi, I'm having the same problem, I've already ran the installer with Antivirus and UAC disabled as administrator but still can't install Revit 2022,  I'm attaching the log files I've found
Message 6 of 13
Hi @rodolfo.salcedomo
Can you see an Autodesk Revit 2022 Setup.log file or something similar?
The logs attached only show the uninstallation rather than an installation.
Otherwise, can you run the installer and send a screenshot of the error.
Leo Warren
Message 7 of 13
Hi Leo
That is all I found. I couldn´t move on from 7% when installing Revit and it happened several times.
I´m Downgrading to 2021 and it let me install all with no problems.
Sorry for not being more helpful with the log files
Message 8 of 13
mdavis22569
@Anonymous  Was @leowarren34  able to help get you all set?
Mike Davis
Message 9 of 13
RTourvilleH6TFE
I cannot install as well, downloaded fine.
Message 10 of 13
I am unable to get REVIT 2022 too install on a Virtual Desktop (WMWARE running win 10 Pro) It shows its installed under the control panel, however their is no icon in the start menu and when clicking the start option on the completed autodesk revit 2022 installer it doesn't do anything. I have uninstalled all Autodesk products atleast 6 times with a registry cleaning and ensured their are no traces be re-trying the installations.
I have tried the install from the Desktop App that is installed as well as the direct installer from the Autodesk folder.
See screen shots below. I tried the Browser download (as shown in screen shot) as well as the normal install option from Autodesk.com/my account/my products.
Message 11 of 13
huygiastarchitech
I have same problem sir, have you solved it yet?
Message 12 of 13
how do I run the installer with Antivirus and UAC disabled as administrator???
Message 13 of 13
What's the problem?
Administrator Productivity
