We want to transfer some network licences to newly acquired standalone licences on some clients computers without re-installing all the software.
On a previous version of Autocad Map 3D we only had to change the value of the following key in the register database in order to do it: HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.0\ACAD-B002\AdLM\Type
- value 1 for network and 2 for standalone.
But this tip doesn't work anymore on this version of Autocad map3D (2014).
We tried to change this key in the same way:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.1\ACAD-D002\AdLM\Type
But we had the following error when launching Autocad:
Le système de sécurité (gestionnaire de licence du verrouillage du progiciel)
ne fonctionne pas ou n'a pas été installé correctement
I can translate this message for you:
The security system (software-lock licence management)
doesn't work or has not been properly installed
Do you have another procedure to communicate to us?
Is there a way to achieve this without re-installing the software?
Is there any way to use the “LTU - Licence Transfert Utility” for that purpose?
In advance, thank you.
Best regards.
