i accidentally click try after i finish install maya , how can i activated the license in try mode ? can i still use the same code after try mode ?
When you first start Maya in trial mode, it will ask you if you want to continue as a trial or enter your serial number. That's when you can fix it.
You can probably click on Help->About Maya->Product License Information->Update, and enter your serial number.
I do it as u said update > enter serial code after that i go activate . and i receive the same mail which contain the same activated code that i receive before . I guess my problem is solved now .......... But anyway thanks for helping .
