Maya is a pathetic program for the stubborn individuals. I prefer C4D by Maxon however I'm forced to use this annoying program called Maya at work.
Why is C4D superior? b/c you don't get these error msgs. Everything works, and works well in C4D. This customer service at Autodesk is hard to get to. Ava, their automated program is shafty as well b/c no solutions are ever solved by it.
*Just trying to install MentalRay (that has been working ever since I've been here) yet all of a sudden it disappeared from my options and within the Plug-In Manager I receieve the following:
// Error: line 1: dlopen(/Applications/Autodesk/mentalrayForMaya2016/plug-ins/Mayatomr.bundle, 1): Library not loaded: @executable_path/libsynColor.2016.0.51.dylib Referenced from: /Applications/Autodesk/mentalrayForMaya2016/plug-ins/Mayatomr.bundle Reason: image not found (Mayatomr)
I then went to Ava to understand wtf is going on and it directs me to an installation process that didn't work.
**Once again this program is a waste of my valuable time, every time, I open the program..(Fix your **** Maya).
-adam osiecki
Solved by natasha.l. Go to Solution.
Hello @Anonymous,
Sorry for the inconvenience. For Maya 2016 SP6 you need to install compatible mental ray plugin for Mac.
Mental ray for Maya 2016 SP6 loading error
mentalray_Plugin_for_Maya_2016_SP6_EN_JP_ZH_Mac_OSX.dmg
Which you can download from the Maya 2016 SP6 download page. Maya 2016 Service Pack 6
Details link:
Note: This Extension requires the latest Maya 2016 Service Pack. Please install the latest Service Pack before applying this update. The Extension may also be installed from the 'Product Enhancements' link. Autodesk recommends applying all available updates (Service Packs, and Product Extensions for Subscription customers) to maintain the highest levels of performance and reliability.
Keep us posted.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @Anonymous,
I wanted to check-in with you, I hope you were able to install the plug-in without a problem.
Natasha
Helpful Links:
