Help installing Inventor 2018 on Windows 8.1
Hi, I've been trying to install inventor 2018 student edition on my pc with no luck. I did a fresh installation of windows 8.1 and installed all available updates through windows update.
Then I proceed to install inventor 2018 (I tried both downloading with the download manager and also the web installer) but in the middle of the installation it pops up a message about a dll (Acipps17.dll) not being registered correctly, and then another dll, and at the end, installation fails. The Inventor icon appears on the desktop but if I try to open it, it pops up a message about a missing dll (pi-ms-win...dll). Placing the missing dll in the system folder doesn't help, as it then errors about another dll and so on.
Thanks a lot for any help.
Here's my installation log:
2017/4/26:12:28:52 froi PC === Setup started on PC by froi ===
2017/4/26:12:28:52 froi PC Path_Length: 179
2017/4/26:12:28:52 froi PC Current Directory C:\Autodesk\Inventor_2018_English_Win_64bit_dlm
2017/4/26:12:28:52 froi PC Launch
2017/4/26:12:28:52 froi PC CommandLine
2017/4/26:12:28:52 froi PC Current Directory C:\Users\froi\AppData\Local\Temp\_AI2193.tmp
2017/4/26:12:29:28 froi PC === Setup ended ===
2017/4/26:12:29:09 froi PC === Setup started on PC by froi ===
2017/4/26:12:29:09 froi PC Path_Length: 179
2017/4/26:12:29:09 froi PC Current Directory C:\Users\froi\AppData\Local\Temp\_AI2193.tmp
2017/4/26:12:29:09 froi PC Launch
2017/4/26:12:29:20 froi PC Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\Setup\AcadeUI.dll
2017/4/26:12:29:20 froi PC Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=https://accounts.autodesk.com/
2017/4/26:12:29:30 froi PC PageOpen LaunchDialog
2017/4/26:12:30:10 froi PC PageOpen LicenseDialog
2017/4/26:12:30:16 froi PC PageOpen ProductInfoDialog
2017/4/26:12:30:16 froi PC PageOpen InventorFlavorSelectionDialog
2017/4/26:12:30:16 froi PC Inventorui==DefaultLanguage: en-us
2017/4/26:12:30:16 froi PC Inventorui==InstallName: INVENTOR
2017/4/26:12:30:16 froi PC Inventorui==ProductName: Autodesk Inventor 2018
2017/4/26:12:30:16 froi PC Inventorui==DisplayName: Autodesk® Inventor® 2018
2017/4/26:12:30:16 froi PC Inventorui==DeploymentName:
2017/4/26:12:30:16 froi PC Inventorui==SetupTitle: Autodesk Inventor 2018
2017/4/26:12:30:16 froi PC Inventorui==ConfigTransform:
2017/4/26:12:30:16 froi PC Inventorui==ExeParams:
2017/4/26:12:30:16 froi PC Inventorui==ProductCode: {7F4DD591-2264-0001-0000-7107D70F3DB4}
2017/4/26:12:30:16 froi PC Inventorui==SupportLink:
2017/4/26:12:30:16 froi PC Inventorui==InfotainmentLink:
2017/4/26:12:30:16 froi PC Inventorui==MsiFileName: inventor.msi
2017/4/26:12:30:16 froi PC Inventorui==AdminImageConfigName: Imgx64
2017/4/26:12:30:16 froi PC Inventorui==AdminImageRoot:
2017/4/26:12:30:16 froi PC Inventorui==GetBaseDeploymentName:
2017/4/26:12:30:16 froi PC Inventorui==DeploymentLocation:
2017/4/26:12:30:16 froi PC Inventorui==DocumentLink: http://autodesk.com/inventor-install-2018-enu
2017/4/26:12:30:16 froi PC Inventorui==InstallDeploymentShortcut:
2017/4/26:12:30:16 froi PC Inventorui==ModifyDeploymentShortcut:
2017/4/26:12:30:16 froi PC Inventorui==SetupLockType: 2
2017/4/26:12:30:16 froi PC Inventorui==SetupNetworkType: 0
2017/4/26:12:30:16 froi PC Inventorui==SystemLocale: 1033
2017/4/26:12:30:16 froi PC Inventorui==EvalMsiFilePath: C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\SetupRes\eval.msi
2017/4/26:12:30:16 froi PC Inventorui==EulaPath: C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\EULA
2017/4/26:12:30:16 froi PC Inventorui==InstallLogPath: C:\Users\froi\AppData\Local\Temp\Inventor2018Install.log
2017/4/26:12:30:16 froi PC Inventorui==ConfigFile: C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\Setup.ini
2017/4/26:12:30:16 froi PC Inventorui==SetupPath: C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\
2017/4/26:12:30:16 froi PC Inventorui==NetworkLogPath:
2017/4/26:12:30:16 froi PC Inventorui==SourceRoot: C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\
2017/4/26:12:30:19 froi PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2017/4/26:12:30:19 froi PC PageOpen ProductSelectionDialog2
2017/4/26:12:30:28 froi PC PageOpen FullProgressDialog
2017/4/26:12:30:29 froi PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2017/4/26:12:30:52 froi PC Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 return code: 0
2017/4/26:12:30:52 froi PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2017/4/26:12:30:52 froi PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2017/4/26:12:31:12 froi PC Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 return code: 0
2017/4/26:12:31:12 froi PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2017/4/26:12:31:12 froi PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\froi\AppData\Local\Temp\vcredist_x64_2010.log
2017/4/26:12:31:20 froi PC Microsoft Visual C++ 2010 SP1 Redistributable (x64) return code: 0
2017/4/26:12:31:20 froi PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2017/4/26:12:31:20 froi PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\froi\AppData\Local\Temp\vcredist_x86_2010.log
2017/4/26:12:31:28 froi PC Microsoft Visual C++ 2010 SP1 Redistributable (x86) return code: 0
2017/4/26:12:31:28 froi PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2017/4/26:12:31:28 froi PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\froi\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/4/26:12:31:33 froi PC Microsoft Visual C++ 2012 Redistributable (x86) Update 4 return code: 0
2017/4/26:12:31:33 froi PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2017/4/26:12:31:33 froi PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\froi\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/4/26:12:31:35 froi PC Microsoft Visual C++ 2012 Redistributable (x64) Update 4 return code: 0
2017/4/26:12:31:35 froi PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2017/4/26:12:31:35 froi PC Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\froi\AppData\Local\Temp\vcredist_x86_2013.log
2017/4/26:12:31:41 froi PC Microsoft Visual C++ 2013 Redistributable (x86) return code: 0
2017/4/26:12:31:41 froi PC Install Microsoft Visual C++ 2013 Redistributable (x86) Succeeded
2017/4/26:12:31:41 froi PC Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\froi\AppData\Local\Temp\vcredist_x64_2013.log
2017/4/26:12:31:43 froi PC Microsoft Visual C++ 2013 Redistributable (x64) return code: 0
2017/4/26:12:31:43 froi PC Install Microsoft Visual C++ 2013 Redistributable (x64) Succeeded
2017/4/26:12:31:43 froi PC Installing Universal C Runtime (KB3118401): "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/4/26:12:31:43 froi PC Universal C Runtime (KB3118401) return code: 0
2017/4/26:12:31:43 froi PC Install Universal C Runtime (KB3118401) Succeeded
2017/4/26:12:31:43 froi PC Installing Microsoft Visual C++ 2015 Redistributable (x86) Update 3: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015UPD3\vcredist_x86.exe" /install /q /norestart /log C:\Users\froi\AppData\Local\Temp\vcredist_x86_2015_UPD3.log
2017/4/26:12:33:29 froi PC Microsoft Visual C++ 2015 Redistributable (x86) Update 3 return code: 23
2017/4/26:12:33:29 froi PC Install Microsoft Visual C++ 2015 Redistributable (x86) Update 3 Succeeded
2017/4/26:12:33:29 froi PC Installing Microsoft Visual C++ 2015 Redistributable (x64) Update 3: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015UPD3\vcredist_x64.exe" /install /q /norestart /log C:\Users\froi\AppData\Local\Temp\vcredist_x64_2015_UPD3.log
2017/4/26:12:33:38 froi PC Microsoft Visual C++ 2015 Redistributable (x64) Update 3 return code: 23
2017/4/26:12:33:38 froi PC Install Microsoft Visual C++ 2015 Redistributable (x64) Update 3 Succeeded
2017/4/26:12:33:38 froi PC Installing .NET Framework Runtime 4.6: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\NET\46\wcu\dotNetFramework\dotnetfx46_full_x86_x64.exe" /q /norestart
2017/4/26:12:34:33 froi PC .NET Framework Runtime 4.6 return code: 5100
2017/4/26:12:34:33 froi PC Install .NET Framework Runtime 4.6 Failed Failure is ignored, Result=1603
2017/4/26:12:34:33 froi PC Installing Autodesk® Material Library 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:35:05 froi PC Install Autodesk® Material Library 2018 Succeeded
2017/4/26:12:35:05 froi PC Installing Autodesk® Material Library 2018 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:35:22 froi PC Install Autodesk® Material Library 2018 - Base Image Library Succeeded
2017/4/26:12:35:22 froi PC Installing Autodesk License Service Certificate: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:35:23 froi PC Install Autodesk License Service Certificate Succeeded
2017/4/26:12:35:24 froi PC Installing Autodesk License Service: TRANSFORMS="C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\x64\CLM\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";{79D5E475-5EAB-4474-84F5-BD612337A175},;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:35:40 froi PC Install Autodesk License Service Succeeded
2017/4/26:12:35:40 froi PC Installing VBA Runtime: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:35:43 froi PC Install VBA Runtime Succeeded
2017/4/26:12:35:43 froi PC Installing VBA Runtime ENG Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:35:44 froi PC Install VBA Runtime ENG Language Pack Succeeded
2017/4/26:12:35:44 froi PC Installing VBA Runtime Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:35:45 froi PC Install VBA Runtime Language Pack Succeeded
2017/4/26:12:35:45 froi PC Installing Autodesk® Material Library 2018 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:36:04 froi PC Install Autodesk® Material Library 2018 - Low Image Library Succeeded
2017/4/26:12:36:04 froi PC Uninstall {8D20B4D7-3422-4099-9332-39F27E617A6F} Failed
2017/4/26:12:36:04 froi PC Uninstall {55D9E026-DCB0-46FF-B60A-68B972228CF6} Failed
2017/4/26:12:36:04 froi PC Uninstall {450063AA-643B-417C-8CF5-405BA3F4EF40} Failed
2017/4/26:12:36:04 froi PC Uninstall {02A00C13-555A-4B8A-B53B-1D02FFF5EEAF} Failed
2017/4/26:12:36:04 froi PC Uninstall {106EC844-9F5E-4B72-BB3B-1E47D274A944} Failed
2017/4/26:12:36:04 froi PC Uninstall {FACF203E-0F4D-489A-B80C-D185253C8FCB} Failed
2017/4/26:12:36:05 froi PC Uninstall {1A2948E0-9445-42BE-9D01-472952F2657F} Failed
2017/4/26:12:36:05 froi PC Uninstall {9A346205-EA92-4406-B1AB-50379DA3F057} Failed
2017/4/26:12:36:05 froi PC Uninstall {C46C3C20-039E-4D7C-869F-9C0C05D65C06} Failed
2017/4/26:12:36:05 froi PC Uninstall {577D60CB-0D5E-48D1-8850-84098AD34804} Failed
2017/4/26:12:36:05 froi PC Uninstall {1ECD6EC8-7BB2-4CD5-A384-BAA371BC4D21} Failed
2017/4/26:12:36:05 froi PC Uninstall {4780F600-0000-0409-0000-114715ACF216} Failed
2017/4/26:12:36:05 froi PC Uninstall {A49BDCBE-590E-43A6-AB77-7C40E499B7C1} Failed
2017/4/26:12:36:05 froi PC Uninstall {9E4D5A41-1051-4F1A-8342-ECB26CA0C86C} Failed
2017/4/26:12:36:05 froi PC Installing Autodesk® Design Review: ADSK_DESKTOPSHORTCUT_1=0 ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:36:36 froi PC Install Autodesk® Design Review Succeeded
2017/4/26:12:36:36 froi PC Installing Autodesk® Inventor® 2018: TRANSFORMS="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\x64\en-us\Inventor\inventor.mst;C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\x64\inventor\inventor-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2018\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:43:45 froi PC Install Autodesk® Inventor® 2018 Succeeded
2017/4/26:12:43:45 froi PC Installing Autodesk® Inventor® 2018 Language Pack: TRANSFORMS="C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\_laC46C.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2018\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:44:59 froi PC Install Autodesk® Inventor® 2018 Language Pack Succeeded
2017/4/26:12:44:59 froi PC Installing Autodesk® Desktop Connect Service: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:45:18 froi PC Install Autodesk® Desktop Connect Service Succeeded
2017/4/26:12:45:18 froi PC Installing Autodesk® Guided Tutorial Plugin: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{FC772454-BB19-0000-0440-44B459520227},;;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:45:51 froi PC Install Autodesk® Guided Tutorial Plugin Succeeded
2017/4/26:12:45:51 froi PC Installing Inventor Connected Design: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{FC772454-BB19-0000-0440-44B459520227},;;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:45:59 froi PC Install Inventor Connected Design Succeeded
2017/4/26:12:46:00 froi PC Installing Autodesk® Configurator 360 Add-in for Inventor® 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:46:02 froi PC Install Autodesk® Configurator 360 Add-in for Inventor® 2018 Succeeded
2017/4/26:12:46:02 froi PC Installing Eco Material Advisor: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:46:07 froi PC Install Eco Material Advisor Succeeded
2017/4/26:12:46:07 froi PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/26:12:46:28 froi PC Microsoft Visual C++ 2008 SP1 Redistributable (x86) return code: 0
2017/4/26:12:46:28 froi PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2017/4/26:12:46:28 froi PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2017/4/26:12:46:47 froi PC Microsoft Visual C++ 2008 SP1 Redistributable (x64) return code: 0
2017/4/26:12:46:47 froi PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2017/4/26:12:46:47 froi PC Installing DirectX Runtime: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2017/4/26:12:46:48 froi PC DirectX Runtime return code: 0
2017/4/26:12:46:48 froi PC Install DirectX Runtime Succeeded
2017/4/26:12:46:48 froi PC Installing Autodesk® DWG TrueView™ 2018 - English: USESETUPUNINSTALL=1 ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,Microsoft Visual C++ 2015 Redistributable (x86) Update 3,Microsoft Visual C++ 2015 Redistributable (x64) Update 3,DirectX Runtime,;;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:50:55 froi PC Install Autodesk® DWG TrueView™ 2018 - English Succeeded
2017/4/26:12:50:56 froi PC Installing Access database engine 2010: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:01 froi PC Install Access database engine 2010 Succeeded
2017/4/26:12:51:02 froi PC Installing Autodesk® Inventor® Electrical Catalog Browser 2018: TRANSFORMS="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\x64\en-us\AceInvAddIn\AceInvAddIn.mst;C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\x64\AceInvAddIn\AceInvAddIn-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Inventor 2018\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:06 froi PC Install Autodesk® Inventor® Electrical Catalog Browser 2018 Succeeded
2017/4/26:12:51:07 froi PC Installing Autodesk® Inventor® Electrical Catalog Browser 2018 Language Pack: TRANSFORMS="C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\_la8177.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Inventor 2018\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:12 froi PC Install Autodesk® Inventor® Electrical Catalog Browser 2018 Language Pack Succeeded
2017/4/26:12:51:12 froi PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:19 froi PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/4/26:12:51:19 froi PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:31 froi PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/4/26:12:51:31 froi PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:38 froi PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/4/26:12:51:38 froi PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:45 froi PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/4/26:12:51:45 froi PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:49 froi PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/4/26:12:51:49 froi PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:59 froi PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/4/26:12:51:59 froi PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:52:07 froi PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/4/26:12:52:07 froi PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:52:17 froi PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2017/4/26:12:52:17 froi PC Installing Autodesk® Revit® Interoperability for Inventor® 2018: C_APP_NAME=Inventor C_RES=ALL RX_CF="Revit Interoperability for Inventor 2018" ADDLOCAL=RevitEngine,RPC,API,DWG,OGS,Workflows,IFC INSTALLDIR="C:\Program Files\Autodesk\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,Microsoft Visual C++ 2015 Redistributable (x86) Update 3,Microsoft Visual C++ 2015 Redistributable (x64) Update 3,{04B34E21-5BEE-3D2B-8D3D-E3E80D253F64},{B42E259C-E4D4-37F1-A1B2-EB9C4FC5A04D},{14866AAD-1F23-39AC-A62B-7091ED1ADE64},{4B90093A-5D9C-3956-8ABB-95848BE6EFAD},{C3A57BB3-9AA6-3F6F-9395-6C062BDD5FC4},{6DA2B636-698A-3294-BF4A-B5E11B238CDD},{F6F09DD8-F39B-3A16-ADB9-C9E6B56903F9},{8CCEA24C-51AE-3B71-9092-7D0C44DDA2DF},.NET Framework Runtime 4.6,.NET Framework Runtime 4.6 Language pack,;;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:55:22 froi PC Install Autodesk® Revit® Interoperability for Inventor® 2018 Succeeded
2017/4/26:12:55:22 froi PC Installing A360 Desktop: TRANSFORMS="C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\x64\Components\Cloudsync\AdSync-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:56:15 froi PC Install A360 Desktop Succeeded Reboot is required
2017/4/26:12:56:15 froi PC Installing Autodesk® Inventor® Content Libraries: TRANSFORMS="C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\Content\DClibrary\DCLibrary64-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\ProgramData\Autodesk\Inventor 2018\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:59:53 froi PC Install Autodesk® Inventor® Content Libraries Succeeded
2017/4/26:12:59:53 froi PC Installing Uninstalling all previous ReCap/ReCap 360 installations: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\Setup\UninstallReqCheck_x64.exe" /uninstall_updgrade_codes {31ABA3F2-1000-1033-0102-111D43815377};{7B511E9E-1000-1033-0102-30C7CD025838};{F6FD1651-1000-1033-0102-387BAF9B3B0A};{16D3DACE-1000-1033-0102-C33330B7D65D};
2017/4/26:12:59:54 froi PC Uninstalling all previous ReCap/ReCap 360 installations return code: 0
2017/4/26:12:59:54 froi PC Install Uninstalling all previous ReCap/ReCap 360 installations Succeeded
2017/4/26:12:59:54 froi PC Installing FARO.LS_6.0.6.5: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:13:00:21 froi PC Install FARO.LS_6.0.6.5 Succeeded
2017/4/26:13:00:22 froi PC Installing Autodesk® ReCap™: TRANSFORMS="C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\x64\RC2018\AutodeskReCap-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk ReCap\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:13:01:11 froi PC Install Autodesk® ReCap™ Succeeded
2017/4/26:13:01:11 froi PC Installing Autodesk® Vault Basic 2018 (Client): TRANSFORMS="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\x64\en-us\VE\Vault.mst;C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\x64\VE\Vault-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Vault Basic 2018\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:13:01:26 froi PC Install Autodesk® Vault Basic 2018 (Client) Failed Installation aborted, Result=1603
2017/4/26:13:01:27 froi PC Rollback Autodesk® Inventor® Electrical Catalog Browser 2018 Language Pack Succeeded
2017/4/26:13:01:28 froi PC Rollback Autodesk® Inventor® Electrical Catalog Browser 2018 Succeeded
2017/4/26:13:01:28 froi PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/4/26:13:01:44 froi PC Rollback Autodesk® Design Review Succeeded
2017/4/26:13:01:56 froi PC Rollback Autodesk License Service Succeeded
2017/4/26:13:01:56 froi PC Rollback Autodesk License Service Certificate Succeeded
2017/4/26:13:01:57 froi PC Rollback Universal C Runtime (KB3118401) Failed Failure is ignored, Result=1619
2017/4/26:13:01:57 froi PC Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619
2017/4/26:13:01:57 froi PC Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619
Mark.Lancaster
@Anonymous
Do you have Vault Basic 2018 client already installed?  Windows/Control Panel/Programs?  Your installation is failing to replace it which usually means you have it already installed.
Mark Lancaster
Hi @Mark.Lancaster
Thanks for your reply.
Vault Basic 2018 was not and is not installed (I checked the programs in the control panel as suggested). As mentioned, I am installing on a fresh copy of Windows 8.1, to which I applied all available updates.
I read that Microsoft Office needs to be installed. That sounds weird. Is that really the case?
Thank you.
Mark.Lancaster
@Anonymous
Excel is really required for Inventor but not needed for the installation part of it.  Can you just run Microsoft Fixit and confirm the Vault Client Basic is not in a list of programs to uninstall.  Also when I start hearing that dll files are missing, it sounds like your Anti-Virus application is blocking stuff on the installation so make the following
1.  You have full admin rights to the PC.
2.  User Access Control (UAC) is set to never notify.
3.  If possible disable Anti-Virus.
4.  Clean out your personal (%temp%) folder.
Good luck and report back on your progress.
Mark Lancaster
Hi @Mark.Lancaster
I followed your suggestions but unfortunately I was unable to solve the issue. I ended up installing inventor 2015. Could you please point me in a direction where I can start looking for a solution? I would really like to test the latest versions.
natasha.l
Hello @Anonymous,
Glad you found a workaround and have some software working. The issue installing a newer version of Inventor maybe due to .Net Framework 4.6 the product needs it to run. You will have to install the update for Windows 8.1 KB2919355 it is a prerequisite to install .Net Framework 4.6. Then install Microsoft .NET Framework 4.6.2 (for Windows 7, 8, 8.1, and 10). Try to install Inventor 2018 again.
Please let us know how it goes. Smiley Happy
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
natasha.l
Hello @Anonymous,
Have you tried installing Inventor 2018 again with my suggestion?
Let us know, thank you. Smiley Happy
