Help installing Inventor 2018 on Windows 8.1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I've been trying to install inventor 2018 student edition on my pc with no luck. I did a fresh installation of windows 8.1 and installed all available updates through windows update.
Then I proceed to install inventor 2018 (I tried both downloading with the download manager and also the web installer) but in the middle of the installation it pops up a message about a dll (Acipps17.dll) not being registered correctly, and then another dll, and at the end, installation fails. The Inventor icon appears on the desktop but if I try to open it, it pops up a message about a missing dll (pi-ms-win...dll). Placing the missing dll in the system folder doesn't help, as it then errors about another dll and so on.
Thanks a lot for any help.
Here's my installation log:
2017/4/26:12:28:52 froi PC === Setup started on PC by froi ===
2017/4/26:12:28:52 froi PC Path_Length: 179
2017/4/26:12:28:52 froi PC Current Directory C:\Autodesk\Inventor_2018_English_Win_64bit_dlm
2017/4/26:12:28:52 froi PC Launch
2017/4/26:12:28:52 froi PC CommandLine
2017/4/26:12:28:52 froi PC Current Directory C:\Users\froi\AppData\Local\Temp\_AI2193.tmp
2017/4/26:12:29:28 froi PC === Setup ended ===
2017/4/26:12:29:09 froi PC === Setup started on PC by froi ===
2017/4/26:12:29:09 froi PC Path_Length: 179
2017/4/26:12:29:09 froi PC Current Directory C:\Users\froi\AppData\Local\Temp\_AI2193.tmp
2017/4/26:12:29:09 froi PC Launch
2017/4/26:12:29:20 froi PC Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\Setup\AcadeUI.dll
2017/4/26:12:29:20 froi PC Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=https://accounts.autodesk.com/
2017/4/26:12:29:30 froi PC PageOpen LaunchDialog
2017/4/26:12:30:10 froi PC PageOpen LicenseDialog
2017/4/26:12:30:16 froi PC PageOpen ProductInfoDialog
2017/4/26:12:30:16 froi PC PageOpen InventorFlavorSelectionDialog
2017/4/26:12:30:16 froi PC Inventorui==DefaultLanguage: en-us
2017/4/26:12:30:16 froi PC Inventorui==InstallName: INVENTOR
2017/4/26:12:30:16 froi PC Inventorui==ProductName: Autodesk Inventor 2018
2017/4/26:12:30:16 froi PC Inventorui==DisplayName: Autodesk® Inventor® 2018
2017/4/26:12:30:16 froi PC Inventorui==DeploymentName:
2017/4/26:12:30:16 froi PC Inventorui==SetupTitle: Autodesk Inventor 2018
2017/4/26:12:30:16 froi PC Inventorui==ConfigTransform:
2017/4/26:12:30:16 froi PC Inventorui==ExeParams:
2017/4/26:12:30:16 froi PC Inventorui==ProductCode: {7F4DD591-2264-0001-0000-7107D70F3DB4}
2017/4/26:12:30:16 froi PC Inventorui==SupportLink:
2017/4/26:12:30:16 froi PC Inventorui==InfotainmentLink:
2017/4/26:12:30:16 froi PC Inventorui==MsiFileName: inventor.msi
2017/4/26:12:30:16 froi PC Inventorui==AdminImageConfigName: Imgx64
2017/4/26:12:30:16 froi PC Inventorui==AdminImageRoot:
2017/4/26:12:30:16 froi PC Inventorui==GetBaseDeploymentName:
2017/4/26:12:30:16 froi PC Inventorui==DeploymentLocation:
2017/4/26:12:30:16 froi PC Inventorui==DocumentLink: http://autodesk.com/inventor-install-2018-enu
2017/4/26:12:30:16 froi PC Inventorui==InstallDeploymentShortcut:
2017/4/26:12:30:16 froi PC Inventorui==ModifyDeploymentShortcut:
2017/4/26:12:30:16 froi PC Inventorui==SetupLockType: 2
2017/4/26:12:30:16 froi PC Inventorui==SetupNetworkType: 0
2017/4/26:12:30:16 froi PC Inventorui==SystemLocale: 1033
2017/4/26:12:30:16 froi PC Inventorui==EvalMsiFilePath: C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\SetupRes\eval.msi
2017/4/26:12:30:16 froi PC Inventorui==EulaPath: C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\EULA
2017/4/26:12:30:16 froi PC Inventorui==InstallLogPath: C:\Users\froi\AppData\Local\Temp\Inventor2018Install.log
2017/4/26:12:30:16 froi PC Inventorui==ConfigFile: C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\Setup.ini
2017/4/26:12:30:16 froi PC Inventorui==SetupPath: C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\
2017/4/26:12:30:16 froi PC Inventorui==NetworkLogPath:
2017/4/26:12:30:16 froi PC Inventorui==SourceRoot: C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\
2017/4/26:12:30:19 froi PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2017/4/26:12:30:19 froi PC PageOpen ProductSelectionDialog2
2017/4/26:12:30:28 froi PC PageOpen FullProgressDialog
2017/4/26:12:30:29 froi PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2017/4/26:12:30:52 froi PC Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 return code: 0
2017/4/26:12:30:52 froi PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2017/4/26:12:30:52 froi PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2017/4/26:12:31:12 froi PC Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 return code: 0
2017/4/26:12:31:12 froi PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2017/4/26:12:31:12 froi PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\froi\AppData\Local\Temp\vcredist_x64_2010.log
2017/4/26:12:31:20 froi PC Microsoft Visual C++ 2010 SP1 Redistributable (x64) return code: 0
2017/4/26:12:31:20 froi PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2017/4/26:12:31:20 froi PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\froi\AppData\Local\Temp\vcredist_x86_2010.log
2017/4/26:12:31:28 froi PC Microsoft Visual C++ 2010 SP1 Redistributable (x86) return code: 0
2017/4/26:12:31:28 froi PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2017/4/26:12:31:28 froi PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\froi\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/4/26:12:31:33 froi PC Microsoft Visual C++ 2012 Redistributable (x86) Update 4 return code: 0
2017/4/26:12:31:33 froi PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2017/4/26:12:31:33 froi PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\froi\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/4/26:12:31:35 froi PC Microsoft Visual C++ 2012 Redistributable (x64) Update 4 return code: 0
2017/4/26:12:31:35 froi PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2017/4/26:12:31:35 froi PC Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\froi\AppData\Local\Temp\vcredist_x86_2013.log
2017/4/26:12:31:41 froi PC Microsoft Visual C++ 2013 Redistributable (x86) return code: 0
2017/4/26:12:31:41 froi PC Install Microsoft Visual C++ 2013 Redistributable (x86) Succeeded
2017/4/26:12:31:41 froi PC Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\froi\AppData\Local\Temp\vcredist_x64_2013.log
2017/4/26:12:31:43 froi PC Microsoft Visual C++ 2013 Redistributable (x64) return code: 0
2017/4/26:12:31:43 froi PC Install Microsoft Visual C++ 2013 Redistributable (x64) Succeeded
2017/4/26:12:31:43 froi PC Installing Universal C Runtime (KB3118401): "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/4/26:12:31:43 froi PC Universal C Runtime (KB3118401) return code: 0
2017/4/26:12:31:43 froi PC Install Universal C Runtime (KB3118401) Succeeded
2017/4/26:12:31:43 froi PC Installing Microsoft Visual C++ 2015 Redistributable (x86) Update 3: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015UPD3\vcredist_x86.exe" /install /q /norestart /log C:\Users\froi\AppData\Local\Temp\vcredist_x86_2015_UPD3.log
2017/4/26:12:33:29 froi PC Microsoft Visual C++ 2015 Redistributable (x86) Update 3 return code: 23
2017/4/26:12:33:29 froi PC Install Microsoft Visual C++ 2015 Redistributable (x86) Update 3 Succeeded
2017/4/26:12:33:29 froi PC Installing Microsoft Visual C++ 2015 Redistributable (x64) Update 3: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015UPD3\vcredist_x64.exe" /install /q /norestart /log C:\Users\froi\AppData\Local\Temp\vcredist_x64_2015_UPD3.log
2017/4/26:12:33:38 froi PC Microsoft Visual C++ 2015 Redistributable (x64) Update 3 return code: 23
2017/4/26:12:33:38 froi PC Install Microsoft Visual C++ 2015 Redistributable (x64) Update 3 Succeeded
2017/4/26:12:33:38 froi PC Installing .NET Framework Runtime 4.6: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\NET\46\wcu\dotNetFramework\dotnetfx46_full_x86_x64.exe" /q /norestart
2017/4/26:12:34:33 froi PC .NET Framework Runtime 4.6 return code: 5100
2017/4/26:12:34:33 froi PC Install .NET Framework Runtime 4.6 Failed Failure is ignored, Result=1603
2017/4/26:12:34:33 froi PC Installing Autodesk® Material Library 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:35:05 froi PC Install Autodesk® Material Library 2018 Succeeded
2017/4/26:12:35:05 froi PC Installing Autodesk® Material Library 2018 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:35:22 froi PC Install Autodesk® Material Library 2018 - Base Image Library Succeeded
2017/4/26:12:35:22 froi PC Installing Autodesk License Service Certificate: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:35:23 froi PC Install Autodesk License Service Certificate Succeeded
2017/4/26:12:35:24 froi PC Installing Autodesk License Service: TRANSFORMS="C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\x64\CLM\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";{79D5E475-5EAB-4474-84F5-BD612337A175},;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:35:40 froi PC Install Autodesk License Service Succeeded
2017/4/26:12:35:40 froi PC Installing VBA Runtime: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:35:43 froi PC Install VBA Runtime Succeeded
2017/4/26:12:35:43 froi PC Installing VBA Runtime ENG Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:35:44 froi PC Install VBA Runtime ENG Language Pack Succeeded
2017/4/26:12:35:44 froi PC Installing VBA Runtime Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:35:45 froi PC Install VBA Runtime Language Pack Succeeded
2017/4/26:12:35:45 froi PC Installing Autodesk® Material Library 2018 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:36:04 froi PC Install Autodesk® Material Library 2018 - Low Image Library Succeeded
2017/4/26:12:36:04 froi PC Uninstall {8D20B4D7-3422-4099-9332-39F27E617A6F} Failed
2017/4/26:12:36:04 froi PC Uninstall {55D9E026-DCB0-46FF-B60A-68B972228CF6} Failed
2017/4/26:12:36:04 froi PC Uninstall {450063AA-643B-417C-8CF5-405BA3F4EF40} Failed
2017/4/26:12:36:04 froi PC Uninstall {02A00C13-555A-4B8A-B53B-1D02FFF5EEAF} Failed
2017/4/26:12:36:04 froi PC Uninstall {106EC844-9F5E-4B72-BB3B-1E47D274A944} Failed
2017/4/26:12:36:04 froi PC Uninstall {FACF203E-0F4D-489A-B80C-D185253C8FCB} Failed
2017/4/26:12:36:05 froi PC Uninstall {1A2948E0-9445-42BE-9D01-472952F2657F} Failed
2017/4/26:12:36:05 froi PC Uninstall {9A346205-EA92-4406-B1AB-50379DA3F057} Failed
2017/4/26:12:36:05 froi PC Uninstall {C46C3C20-039E-4D7C-869F-9C0C05D65C06} Failed
2017/4/26:12:36:05 froi PC Uninstall {577D60CB-0D5E-48D1-8850-84098AD34804} Failed
2017/4/26:12:36:05 froi PC Uninstall {1ECD6EC8-7BB2-4CD5-A384-BAA371BC4D21} Failed
2017/4/26:12:36:05 froi PC Uninstall {4780F600-0000-0409-0000-114715ACF216} Failed
2017/4/26:12:36:05 froi PC Uninstall {A49BDCBE-590E-43A6-AB77-7C40E499B7C1} Failed
2017/4/26:12:36:05 froi PC Uninstall {9E4D5A41-1051-4F1A-8342-ECB26CA0C86C} Failed
2017/4/26:12:36:05 froi PC Installing Autodesk® Design Review: ADSK_DESKTOPSHORTCUT_1=0 ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:36:36 froi PC Install Autodesk® Design Review Succeeded
2017/4/26:12:36:36 froi PC Installing Autodesk® Inventor® 2018: TRANSFORMS="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\x64\en-us\Inventor\inventor.mst;C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\x64\inventor\inventor-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2018\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:43:45 froi PC Install Autodesk® Inventor® 2018 Succeeded
2017/4/26:12:43:45 froi PC Installing Autodesk® Inventor® 2018 Language Pack: TRANSFORMS="C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\_laC46C.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2018\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:44:59 froi PC Install Autodesk® Inventor® 2018 Language Pack Succeeded
2017/4/26:12:44:59 froi PC Installing Autodesk® Desktop Connect Service: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:45:18 froi PC Install Autodesk® Desktop Connect Service Succeeded
2017/4/26:12:45:18 froi PC Installing Autodesk® Guided Tutorial Plugin: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{FC772454-BB19-0000-0440-44B459520227},;;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:45:51 froi PC Install Autodesk® Guided Tutorial Plugin Succeeded
2017/4/26:12:45:51 froi PC Installing Inventor Connected Design: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{FC772454-BB19-0000-0440-44B459520227},;;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:45:59 froi PC Install Inventor Connected Design Succeeded
2017/4/26:12:46:00 froi PC Installing Autodesk® Configurator 360 Add-in for Inventor® 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:46:02 froi PC Install Autodesk® Configurator 360 Add-in for Inventor® 2018 Succeeded
2017/4/26:12:46:02 froi PC Installing Eco Material Advisor: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:46:07 froi PC Install Eco Material Advisor Succeeded
2017/4/26:12:46:07 froi PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/26:12:46:28 froi PC Microsoft Visual C++ 2008 SP1 Redistributable (x86) return code: 0
2017/4/26:12:46:28 froi PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2017/4/26:12:46:28 froi PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2017/4/26:12:46:47 froi PC Microsoft Visual C++ 2008 SP1 Redistributable (x64) return code: 0
2017/4/26:12:46:47 froi PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2017/4/26:12:46:47 froi PC Installing DirectX Runtime: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2017/4/26:12:46:48 froi PC DirectX Runtime return code: 0
2017/4/26:12:46:48 froi PC Install DirectX Runtime Succeeded
2017/4/26:12:46:48 froi PC Installing Autodesk® DWG TrueView™ 2018 - English: USESETUPUNINSTALL=1 ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,Microsoft Visual C++ 2015 Redistributable (x86) Update 3,Microsoft Visual C++ 2015 Redistributable (x64) Update 3,DirectX Runtime,;;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:50:55 froi PC Install Autodesk® DWG TrueView™ 2018 - English Succeeded
2017/4/26:12:50:56 froi PC Installing Access database engine 2010: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:01 froi PC Install Access database engine 2010 Succeeded
2017/4/26:12:51:02 froi PC Installing Autodesk® Inventor® Electrical Catalog Browser 2018: TRANSFORMS="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\x64\en-us\AceInvAddIn\AceInvAddIn.mst;C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\x64\AceInvAddIn\AceInvAddIn-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Inventor 2018\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:06 froi PC Install Autodesk® Inventor® Electrical Catalog Browser 2018 Succeeded
2017/4/26:12:51:07 froi PC Installing Autodesk® Inventor® Electrical Catalog Browser 2018 Language Pack: TRANSFORMS="C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\_la8177.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Inventor 2018\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:12 froi PC Install Autodesk® Inventor® Electrical Catalog Browser 2018 Language Pack Succeeded
2017/4/26:12:51:12 froi PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:19 froi PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/4/26:12:51:19 froi PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:31 froi PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/4/26:12:51:31 froi PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:38 froi PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/4/26:12:51:38 froi PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:45 froi PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/4/26:12:51:45 froi PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:49 froi PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/4/26:12:51:49 froi PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:51:59 froi PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/4/26:12:51:59 froi PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:52:07 froi PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/4/26:12:52:07 froi PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:52:17 froi PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2017/4/26:12:52:17 froi PC Installing Autodesk® Revit® Interoperability for Inventor® 2018: C_APP_NAME=Inventor C_RES=ALL RX_CF="Revit Interoperability for Inventor 2018" ADDLOCAL=RevitEngine,RPC,API,DWG,OGS,Workflows,IFC INSTALLDIR="C:\Program Files\Autodesk\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,Microsoft Visual C++ 2015 Redistributable (x86) Update 3,Microsoft Visual C++ 2015 Redistributable (x64) Update 3,{04B34E21-5BEE-3D2B-8D3D-E3E80D253F64},{B42E259C-E4D4-37F1-A1B2-EB9C4FC5A04D},{14866AAD-1F23-39AC-A62B-7091ED1ADE64},{4B90093A-5D9C-3956-8ABB-95848BE6EFAD},{C3A57BB3-9AA6-3F6F-9395-6C062BDD5FC4},{6DA2B636-698A-3294-BF4A-B5E11B238CDD},{F6F09DD8-F39B-3A16-ADB9-C9E6B56903F9},{8CCEA24C-51AE-3B71-9092-7D0C44DDA2DF},.NET Framework Runtime 4.6,.NET Framework Runtime 4.6 Language pack,;;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:55:22 froi PC Install Autodesk® Revit® Interoperability for Inventor® 2018 Succeeded
2017/4/26:12:55:22 froi PC Installing A360 Desktop: TRANSFORMS="C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\x64\Components\Cloudsync\AdSync-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:56:15 froi PC Install A360 Desktop Succeeded Reboot is required
2017/4/26:12:56:15 froi PC Installing Autodesk® Inventor® Content Libraries: TRANSFORMS="C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\Content\DClibrary\DCLibrary64-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\ProgramData\Autodesk\Inventor 2018\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:12:59:53 froi PC Install Autodesk® Inventor® Content Libraries Succeeded
2017/4/26:12:59:53 froi PC Installing Uninstalling all previous ReCap/ReCap 360 installations: "C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\Setup\UninstallReqCheck_x64.exe" /uninstall_updgrade_codes {31ABA3F2-1000-1033-0102-111D43815377};{7B511E9E-1000-1033-0102-30C7CD025838};{F6FD1651-1000-1033-0102-387BAF9B3B0A};{16D3DACE-1000-1033-0102-C33330B7D65D};
2017/4/26:12:59:54 froi PC Uninstalling all previous ReCap/ReCap 360 installations return code: 0
2017/4/26:12:59:54 froi PC Install Uninstalling all previous ReCap/ReCap 360 installations Succeeded
2017/4/26:12:59:54 froi PC Installing FARO.LS_6.0.6.5: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2018" SETUP_PACKAGECODE={8CB42675-2200-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={5637D432-9F0F-4296-A787-ECD5F68B4106} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:13:00:21 froi PC Install FARO.LS_6.0.6.5 Succeeded
2017/4/26:13:00:22 froi PC Installing Autodesk® ReCap™: TRANSFORMS="C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\x64\RC2018\AutodeskReCap-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk ReCap\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:13:01:11 froi PC Install Autodesk® ReCap™ Succeeded
2017/4/26:13:01:11 froi PC Installing Autodesk® Vault Basic 2018 (Client): TRANSFORMS="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\x64\en-us\VE\Vault.mst;C:\Users\froi\AppData\Local\Temp\_AI2193.tmp\x64\VE\Vault-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Vault Basic 2018\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/26:13:01:26 froi PC Install Autodesk® Vault Basic 2018 (Client) Failed Installation aborted, Result=1603
2017/4/26:13:01:27 froi PC Rollback Autodesk® Inventor® Electrical Catalog Browser 2018 Language Pack Succeeded
2017/4/26:13:01:28 froi PC Rollback Autodesk® Inventor® Electrical Catalog Browser 2018 Succeeded
2017/4/26:13:01:28 froi PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/4/26:13:01:44 froi PC Rollback Autodesk® Design Review Succeeded
2017/4/26:13:01:56 froi PC Rollback Autodesk License Service Succeeded
2017/4/26:13:01:56 froi PC Rollback Autodesk License Service Certificate Succeeded
2017/4/26:13:01:57 froi PC Rollback Universal C Runtime (KB3118401) Failed Failure is ignored, Result=1619
2017/4/26:13:01:57 froi PC Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619
2017/4/26:13:01:57 froi PC Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619
