Genuine Service - How to uninstall it? (I moved to a different machine)
EricsUsername
EricsUsername
HOW TO UNINSTALL The ADSK Genuine Service ?
• I moved 3dsMax to a new computer.
• 3dsMax is no longer installed on that previously used computer.
• I want to remove the Genuine Service from the previously used system.
To whoever or whomever saves the say here.. I PRE-THANK YOU
IMO:  The "ADSK Genuine Service" should be smart enough to allow uninstall of itself when there's no longer any ADSK programs on the system.
Replies (124)
Works perfectly
Josue.RomeroMUBNY
Message from Brian~Roberts solved it for me, thank you very much. And yes, quite unethical from Autodesk's side.
Josue.RomeroMUBNY
This is so egregious. I want this malware off my machine.
Thanks for this. the troubleshooter does the job so easily
:Deleted:
I want to delete your app now, I don't have any autodesk products and I'm not going to use them because they don't meet my needs
Autodesk should be ashamed of themselves because they stopped me from removing Genuine Service from my PC (they have no right to do this). I will never buy any of their products because of this. Here is the solution guys from Microsoft (If you are on a MAC best of luck):
https://support.microsoft.com/en-us/topic/fix-problems-that-block-programs-from-being-installed-or-r...
This is absolutely unacceptable. I cannot believe a professional company would force a service that persists after uninstallations and in addition will only disable itself even after rejecting TOS.
I will make every effort I can to move our company (about 160 licensed ACAD/Revit/Max products) out of your ecosystem.
This is not a solution. I don't want it disabled, I want it gone and on my timetable. There is no good reason Autodesk should permanently install a piece of software that I, as an Admin, can't remove.
It worked .....thanks
Thanks it works for me !!
S
Yea this is the definition of malware.
I never again work with autodesk
This worked, thanks!
Hi. I found that folder but it's empty...
walkermacy
@Brian~Roberts wrote:
The uninstall puts down a powershell script for a few seconds (before it disappears) which appears to check for the existence of 2 files to determine if Autodesk Genuine Service can be uninstalled....
1.
"C:\ProgramData\Autodesk\Adlm\ProductInformation.pit"
2.
"C:\Users\username\AppData\Local\Autodesk\Genuine Autodesk Service\id.dat"
username being into which account this was installed
Delete these two files.
Then run your uninstall
MsiExec.exe /X{54A00624-3EF9-49A2-92A9-7244EADD0212}
This worked for me within a VM environment for testing the uninstall of one product.
I would not like to guess what doing this on an end users machine with numerous Autodesk products installed would do.... probably not recommended. However to perform a clean up of a machine to move 3ds to another, it may suffice as a workaround.
I want to point out that this is the ONLY method I've found that will reliably allow me to uninstall AGS. I use it in our automated PDQ Deploy scripts as well as having to do it manually a number of times. The only difference I've found with what Brian-Roberts posted is the AGS GUID has changed in newer versions, so I had to track that down in the registry to get the current one, which will likely change again at some point in the future. I believe an updated version of the application was released in late November, 2020, and the uninstall string for it is:
MsiExec.exe /X{317D67F2-9027-4E85-9ED1-ADF4D765AE02}
The user account where the "id.dat" file is located is the one that was used to install the software, not necessarily the one that's used to run the software. I install all of our software using an admin account on workstations, not the user account of the person who uses the computer and the software, so I have to find that file in the admin account's local appdata directory. I'm sure most people install and run their Autodesk software from the same account, but it's good to have clarity on where to look for that file.
All of the above solutions are So Unnecessary if you are using a PC. Just use this tool from Microsoft it will uninstall anything and you are good to go:
walkermacy
https://support.microsoft.com/en-us/topic/fix-problems-that-block-programs-from-being-installed-or-removed-cca7d1b6-65a9-3d98-426b-e9f927e1eb4d
Yeah, unless you are automating your uninstalls, then Microsoft's tool is useless. Otherwise, yes it's actually a really great utility.
Repeat posting
