Installation & Licensing
File not found, Error Result=1619
0 REPLIES 0
Message 1 of 1
540 Views, 0 Replies
Hi everyone!
I am having some trouble installing AutoCAD Civil 3D 2013. There are no earlier versions downloaded on the computer. Running 64 bit computer
Thank you in advance!
here is the installation log file:
2013/2/1:10:32:56 Wathsala LENOVOG570 === Setup started on LENOVOG570 by Wathsala ===
2013/2/1:10:32:56 Wathsala LENOVOG570 Launch
2013/2/1:10:34:56 Wathsala LENOVOG570 === Setup ended ===
2013/2/1:10:33:01 Wathsala LENOVOG570 === Setup started on LENOVOG570 by Wathsala ===
2013/2/1:10:33:01 Wathsala LENOVOG570 Launch
2013/2/1:10:33:02 Wathsala LENOVOG570 Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/S...
2013/2/1:10:34:35 Wathsala LENOVOG570 Download Error SETUP_CONFIG <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/S...
2013/2/1:10:34:35 Wathsala LENOVOG570 Error downloading. Please Install Now again from the Autodesk website. 2013/2/1:10:34:56 Wathsala LENOVOG570 Download Error SETUP_CONFIG <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/S...
2013/2/1:10:36:23 Wathsala LENOVOG570 === Setup ended ===
2013/2/1:10:41:59 Wathsala LENOVOG570 === Setup started on LENOVOG570 by Wathsala ===
2013/2/1:10:41:59 Wathsala LENOVOG570 Launch
2013/2/1:10:42:03 Wathsala LENOVOG570 === Setup ended ===
2013/2/1:10:42:02 Wathsala LENOVOG570 === Setup started on LENOVOG570 by Wathsala ===
2013/2/1:10:42:02 Wathsala LENOVOG570 Launch
2013/2/1:10:42:02 Wathsala LENOVOG570 Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/S...
2013/2/1:10:42:03 Wathsala LENOVOG570 PageOpen LaunchDialog
2013/2/1:10:42:15 Wathsala LENOVOG570 PageOpen LicenseDialog
2013/2/1:10:42:33 Wathsala LENOVOG570 PageOpen ProductInfoDialog
2013/2/1:10:43:21 Wathsala LENOVOG570 PageOpen ProductSelectionDialog2
2013/2/1:10:43:51 Wathsala LENOVOG570 PageOpen FullProgressDialog
2013/2/1:10:43:51 Wathsala LENOVOG570 Download Play DOTNET4 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/D...
2013/2/1:10:45:45 Wathsala LENOVOG570 Download Error DOTNET4 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/D...
2013/2/1:10:45:56 Wathsala LENOVOG570 Download Complete DOTNET4 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/D...
2013/2/1:10:45:56 Wathsala LENOVOG570 Installing .NET Framework Runtime 4.0: C:\Autodesk\WI\AutoCAD Civil 3D 2013\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/2/1:10:48:01 Wathsala LENOVOG570 Install .NET Framework Runtime 4.0 Succeeded
2013/2/1:10:48:01 Wathsala LENOVOG570 Download Skipped DOTNET4KB2468871 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/D...
2013/2/1:10:48:01 Wathsala LENOVOG570 Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\WI\AutoCAD Civil 3D 2013\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2013/2/1:10:51:15 Wathsala LENOVOG570 Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2013/2/1:10:51:15 Wathsala LENOVOG570 Download Play VCREDIST2008SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/V...
2013/2/1:10:51:18 Wathsala LENOVOG570 Download Complete VCREDIST2008SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/V...
2013/2/1:10:51:18 Wathsala LENOVOG570 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD Civil 3D 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/2/1:10:51:25 Wathsala LENOVOG570 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/2/1:10:51:26 Wathsala LENOVOG570 Download Play VCREDIST2008SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/V...
2013/2/1:10:51:29 Wathsala LENOVOG570 Download Complete VCREDIST2008SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/V...
2013/2/1:10:51:29 Wathsala LENOVOG570 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD Civil 3D 2013\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/1:10:51:36 Wathsala LENOVOG570 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2013/2/1:10:51:37 Wathsala LENOVOG570 Download Play VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/V...
2013/2/1:10:51:39 Wathsala LENOVOG570 Download Complete VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/V...
2013/2/1:10:51:39 Wathsala LENOVOG570 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD Civil 3D 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\Wathsala\AppData\Local\Temp\vcredist_x86_2010.log
2013/2/1:10:51:45 Wathsala LENOVOG570 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/2/1:10:51:45 Wathsala LENOVOG570 Download Play VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/V...
2013/2/1:10:51:50 Wathsala LENOVOG570 Download Complete VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/V...
2013/2/1:10:51:50 Wathsala LENOVOG570 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD Civil 3D 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\Wathsala\AppData\Local\Temp\vcredist_x64_2010.log
2013/2/1:10:51:55 Wathsala LENOVOG570 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/2/1:10:51:56 Wathsala LENOVOG570 Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/D...
2013/2/1:10:52:02 Wathsala LENOVOG570 Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/D...
2013/2/1:10:52:02 Wathsala LENOVOG570 Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD Civil 3D 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/1:10:52:45 Wathsala LENOVOG570 Install DirectX Runtime Succeeded
2013/2/1:10:52:45 Wathsala LENOVOG570 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/1:10:52:52 Wathsala LENOVOG570 Install FaroSDK Succeeded
2013/2/1:10:52:52 Wathsala LENOVOG570 Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C...
2013/2/1:10:53:29 Wathsala LENOVOG570 Download Error CM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C...
2013/2/1:10:53:39 Wathsala LENOVOG570 Download Complete CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C...
2013/2/1:10:53:39 Wathsala LENOVOG570 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/1:10:54:09 Wathsala LENOVOG570 Install Autodesk Material Library 2013 Succeeded
2013/2/1:10:54:09 Wathsala LENOVOG570 Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C...
2013/2/1:10:55:09 Wathsala LENOVOG570 Download Error CMILB2013 <B>File not found</B>Please Install Now again from the Autodesk website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C...
2013/2/1:10:55:09 Wathsala LENOVOG570 Download Aborted CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C...
2013/2/1:10:55:09 Wathsala LENOVOG570 Install Autodesk Material Library 2013 - Low Resolution Failed Download Failed, Installation aborted, Result=1603
2013/2/1:10:55:47 Wathsala LENOVOG570 Rollback Autodesk Material Library 2013 Succeeded
2013/2/1:10:55:48 Wathsala LENOVOG570 Rollback FaroSDK Succeeded
2013/2/1:10:55:48 Wathsala LENOVOG570 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/2/1:10:55:48 Wathsala LENOVOG570 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/2/1:10:55:48 Wathsala LENOVOG570 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/2/1:10:55:48 Wathsala LENOVOG570 Rollback .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1619
2013/2/1:10:55:48 Wathsala LENOVOG570 Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1619
2013/2/1:10:55:59 Wathsala LENOVOG570 PageOpen InstallCompleteDialog
2013/2/1:10:59:37 Wathsala LENOVOG570 === Setup ended ===
2013/2/1:11:00:48 Wathsala LENOVOG570 === Setup started on LENOVOG570 by Wathsala ===
2013/2/1:11:00:48 Wathsala LENOVOG570 Launch
2013/2/1:11:00:54 Wathsala LENOVOG570 === Setup ended ===
2013/2/1:11:00:51 Wathsala LENOVOG570 === Setup started on LENOVOG570 by Wathsala ===
2013/2/1:11:00:51 Wathsala LENOVOG570 Launch
2013/2/1:11:00:52 Wathsala LENOVOG570 Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/S...
2013/2/1:11:00:54 Wathsala LENOVOG570 PageOpen LaunchDialog
2013/2/1:11:01:01 Wathsala LENOVOG570 PageOpen LicenseDialog
2013/2/1:11:01:13 Wathsala LENOVOG570 PageOpen ProductInfoDialog
2013/2/1:11:02:01 Wathsala LENOVOG570 PageOpen ProductSelectionDialog2
2013/2/1:11:02:20 Wathsala LENOVOG570 PageOpen FullProgressDialog
2013/2/1:11:02:21 Wathsala LENOVOG570 Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/D...
2013/2/1:11:02:21 Wathsala LENOVOG570 Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD Civil 3D 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/1:11:02:49 Wathsala LENOVOG570 Install DirectX Runtime Succeeded
2013/2/1:11:02:49 Wathsala LENOVOG570 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/1:11:02:53 Wathsala LENOVOG570 Install FaroSDK Succeeded
2013/2/1:11:02:53 Wathsala LENOVOG570 Download Skipped CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C...
2013/2/1:11:02:53 Wathsala LENOVOG570 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/1:11:03:16 Wathsala LENOVOG570 Install Autodesk Material Library 2013 Succeeded
2013/2/1:11:03:16 Wathsala LENOVOG570 Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C...
2013/2/1:11:04:09 Wathsala LENOVOG570 Download Complete CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C...
2013/2/1:11:04:09 Wathsala LENOVOG570 Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/1:11:04:27 Wathsala LENOVOG570 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/2/1:11:04:27 Wathsala LENOVOG570 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD Civil 3D 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/1:11:04:55 Wathsala LENOVOG570 Install Autodesk Content Service Succeeded
2013/2/1:11:04:55 Wathsala LENOVOG570 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/1:11:05:00 Wathsala LENOVOG570 Install Autodesk Content Service Language Pack Succeeded
2013/2/1:11:05:00 Wathsala LENOVOG570 Installing SQL Server CE 3.5 x86: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/1:11:05:04 Wathsala LENOVOG570 Install SQL Server CE 3.5 x86 Succeeded
2013/2/1:11:05:04 Wathsala LENOVOG570 Installing SQL Server CE 3.5 x64: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/1:11:05:09 Wathsala LENOVOG570 Install SQL Server CE 3.5 x64 Succeeded
2013/2/1:11:05:10 Wathsala LENOVOG570 Download Play VBPOWERPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/V...
2013/2/1:11:05:11 Wathsala LENOVOG570 Download Complete VBPOWERPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/V...
2013/2/1:11:05:11 Wathsala LENOVOG570 Installing Microsoft Visual Basic Power Packs 10.0: C:\Autodesk\WI\AutoCAD Civil 3D 2013\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\Wathsala\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2013/2/1:11:05:14 Wathsala LENOVOG570 Install Microsoft Visual Basic Power Packs 10.0 Succeeded
2013/2/1:11:05:14 Wathsala LENOVOG570 Download Play C3D http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C...
2013/2/1:11:07:15 Wathsala LENOVOG570 Download Error C3D <B>File not found</B>Please Install Now again from the Autodesk website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C...
2013/2/1:11:07:15 Wathsala LENOVOG570 Download Aborted C3D http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C...
2013/2/1:11:07:15 Wathsala LENOVOG570 Install AutoCAD Civil 3D 2013 Failed Download Failed, Installation aborted, Result=1603
2013/2/1:11:07:15 Wathsala LENOVOG570 Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619
2013/2/1:11:07:17 Wathsala LENOVOG570 Rollback SQL Server CE 3.5 x64 Succeeded
2013/2/1:11:07:19 Wathsala LENOVOG570 Rollback SQL Server CE 3.5 x86 Succeeded
2013/2/1:11:07:20 Wathsala LENOVOG570 Rollback Autodesk Content Service Language Pack Succeeded
2013/2/1:11:07:28 Wathsala LENOVOG570 Rollback Autodesk Content Service Succeeded
2013/2/1:11:07:42 Wathsala LENOVOG570 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/2/1:11:07:59 Wathsala LENOVOG570 Rollback Autodesk Material Library 2013 Succeeded
2013/2/1:11:08:00 Wathsala LENOVOG570 Rollback FaroSDK Succeeded
2013/2/1:11:08:00 Wathsala LENOVOG570 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
0 REPLIES 0
Administrator Productivity
