WHILE SPLITTING AN ARCHITECTURAL WALL WITH PARAMETER VALUES , FATAL ERROR OCCURS AND REVIT CLOSES .
have you try to install latest updates from autodesk? tick audit before opening the file and clear as much as possible warnings and see if helps. thanks
