Failed to install Maya 2016 student and DirectConnect 2016
I tried installing Autodesk Maya 2016 Student version but it would not install successfully. It also failed in install DirectConnect 2016. The resons stated for both is, "An error occurred while installing this product. For more information view the installation log file". I can copy and paste these if it would help diagnose the problem.
It also failed to install Autodesk Application Manager also has an 'X' next to it.
Replies (10)
matthew.d
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. Have you tried disabling your antivirus and installing from the virtual agent? Could you post your installation log files?
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Thank you for responding!
Here is my installation log file for Autodesk Maya 2016:
2016/2/11:16:48:43 mattcooke MATTHEW-COOKE-P === Setup started on MATTHEW-COOKE-P by mattcooke ===
2016/2/11:16:48:43 mattcooke MATTHEW-COOKE-P Path_Length: 153
2016/2/11:16:48:43 mattcooke MATTHEW-COOKE-P Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2016/2/11:16:48:43 mattcooke MATTHEW-COOKE-P Launch
2016/2/11:16:48:43 mattcooke MATTHEW-COOKE-P CommandLine /PK 657H1 /SN 900-66576823 /akamai /sid a1b30000008i70EAAQ /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?authp...
2016/2/11:16:48:43 mattcooke MATTHEW-COOKE-P Setup Windows update reboot is pending
2016/2/11:16:48:49 mattcooke MATTHEW-COOKE-P Setup Autodesk Maya 2016 Will restart automatically.
2016/2/11:16:48:49 mattcooke MATTHEW-COOKE-P === Setup ended ===
2016/2/11:16:55:41 mattcooke MATTHEW-COOKE-P === Setup started on MATTHEW-COOKE-P by mattcooke ===
2016/2/11:16:55:41 mattcooke MATTHEW-COOKE-P Path_Length: 153
2016/2/11:16:55:41 mattcooke MATTHEW-COOKE-P Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2016/2/11:16:55:41 mattcooke MATTHEW-COOKE-P Launch
2016/2/11:16:55:41 mattcooke MATTHEW-COOKE-P CommandLine /PK 657H1 /SN 900-66576823 /akamai /sid a1b30000008i70EAAQ /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?authp...
2016/2/11:16:55:41 mattcooke MATTHEW-COOKE-P Current Directory C:\Users\MATTCO~1\AppData\Local\Temp\_AI306E.tmp
2016/2/11:16:55:45 mattcooke MATTHEW-COOKE-P === Setup ended ===
2016/2/11:16:55:42 mattcooke MATTHEW-COOKE-P === Setup started on MATTHEW-COOKE-P by mattcooke ===
2016/2/11:16:55:42 mattcooke MATTHEW-COOKE-P Path_Length: 153
2016/2/11:16:55:42 mattcooke MATTHEW-COOKE-P Current Directory C:\Users\MATTCO~1\AppData\Local\Temp\_AI306E.tmp
2016/2/11:16:55:42 mattcooke MATTHEW-COOKE-P Launch
2016/2/11:16:55:43 mattcooke MATTHEW-COOKE-P Download Play SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/11:16:55:43 mattcooke MATTHEW-COOKE-P Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/11:16:55:43 mattcooke MATTHEW-COOKE-P Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/11:16:55:45 mattcooke MATTHEW-COOKE-P Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/11:16:55:45 mattcooke MATTHEW-COOKE-P PageOpen LaunchDialog
2016/2/11:17:29:42 mattcooke MATTHEW-COOKE-P PageOpen LicenseDialog
2016/2/11:17:29:42 mattcooke MATTHEW-COOKE-P PageOpen ProductInfoDialog
2016/2/11:17:29:42 mattcooke MATTHEW-COOKE-P PageOpen ProductSelectionDialog2
2016/2/11:17:30:25 mattcooke MATTHEW-COOKE-P PageOpen FullProgressDialog
2016/2/11:17:30:25 mattcooke MATTHEW-COOKE-P Download Play STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STAR...
2016/2/11:17:30:26 mattcooke MATTHEW-COOKE-P Download Complete STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STAR...
2016/2/11:17:30:26 mattcooke MATTHEW-COOKE-P Download Play VCREDIST2012X86UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/11:17:30:28 mattcooke MATTHEW-COOKE-P Download Complete VCREDIST2012X86UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/11:17:30:28 mattcooke MATTHEW-COOKE-P Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/2/11:17:30:29 mattcooke MATTHEW-COOKE-P Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/2/11:17:30:29 mattcooke MATTHEW-COOKE-P Download Play VCREDIST2012X64UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/11:17:30:32 mattcooke MATTHEW-COOKE-P Download Complete VCREDIST2012X64UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/11:17:30:32 mattcooke MATTHEW-COOKE-P Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/2/11:17:30:33 mattcooke MATTHEW-COOKE-P Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/2/11:17:30:33 mattcooke MATTHEW-COOKE-P Download Play DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRE...
2016/2/11:17:30:36 mattcooke MATTHEW-COOKE-P Download Complete DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRE...
2016/2/11:17:30:36 mattcooke MATTHEW-COOKE-P Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/2/11:17:30:39 mattcooke MATTHEW-COOKE-P Install DirectX® Runtime Succeeded
2016/2/11:17:30:39 mattcooke MATTHEW-COOKE-P Download Play MAYA http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA...
2016/2/11:17:32:55 mattcooke MATTHEW-COOKE-P Download Aborted MAYA http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA...
2016/2/11:17:32:55 mattcooke MATTHEW-COOKE-P Install Autodesk® Maya® 2016 Failed Download Failed, Installation aborted, Result=1603
2016/2/11:17:32:56 mattcooke MATTHEW-COOKE-P Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/2/11:17:32:56 mattcooke MATTHEW-COOKE-P Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/2/11:17:32:56 mattcooke MATTHEW-COOKE-P Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/2/11:17:32:57 mattcooke MATTHEW-COOKE-P PageOpen InstallCompleteDialog
2016/2/11:17:53:15 mattcooke MATTHEW-COOKE-P === Setup ended ===
2016/2/11:17:54:02 mattcooke MATTHEW-COOKE-P === Setup started on MATTHEW-COOKE-P by mattcooke ===
2016/2/11:17:54:02 mattcooke MATTHEW-COOKE-P Path_Length: 153
2016/2/11:17:54:02 mattcooke MATTHEW-COOKE-P Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2016/2/11:17:54:02 mattcooke MATTHEW-COOKE-P Launch
2016/2/11:17:54:02 mattcooke MATTHEW-COOKE-P CommandLine /PK 657H1 /SN 900-66576823 /akamai /sid a1b30000008i7xBAAQ /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?authp...
2016/2/11:17:54:02 mattcooke MATTHEW-COOKE-P Current Directory C:\Users\MATTCO~1\AppData\Local\Temp\_AI9977.tmp
2016/2/11:17:54:04 mattcooke MATTHEW-COOKE-P === Setup ended ===
2016/2/11:17:54:03 mattcooke MATTHEW-COOKE-P === Setup started on MATTHEW-COOKE-P by mattcooke ===
2016/2/11:17:54:03 mattcooke MATTHEW-COOKE-P Path_Length: 153
2016/2/11:17:54:03 mattcooke MATTHEW-COOKE-P Current Directory C:\Users\MATTCO~1\AppData\Local\Temp\_AI9977.tmp
2016/2/11:17:54:03 mattcooke MATTHEW-COOKE-P Launch
2016/2/11:17:54:03 mattcooke MATTHEW-COOKE-P Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/11:17:54:03 mattcooke MATTHEW-COOKE-P Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/11:17:54:04 mattcooke MATTHEW-COOKE-P PageOpen LaunchDialog
2016/2/11:17:54:08 mattcooke MATTHEW-COOKE-P PageOpen LicenseDialog
2016/2/11:17:54:08 mattcooke MATTHEW-COOKE-P PageOpen ProductInfoDialog
2016/2/11:17:54:08 mattcooke MATTHEW-COOKE-P PageOpen ProductSelectionDialog2
2016/2/11:17:54:37 mattcooke MATTHEW-COOKE-P PageOpen FullProgressDialog
2016/2/11:17:54:37 mattcooke MATTHEW-COOKE-P Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STAR...
2016/2/11:17:54:37 mattcooke MATTHEW-COOKE-P Download Skipped VCREDIST2012X86UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/11:17:54:37 mattcooke MATTHEW-COOKE-P Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/2/11:17:54:38 mattcooke MATTHEW-COOKE-P Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/2/11:17:54:38 mattcooke MATTHEW-COOKE-P Download Skipped VCREDIST2012X64UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/11:17:54:38 mattcooke MATTHEW-COOKE-P Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/2/11:17:54:39 mattcooke MATTHEW-COOKE-P Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/2/11:17:54:39 mattcooke MATTHEW-COOKE-P Download Skipped DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRE...
2016/2/11:17:54:39 mattcooke MATTHEW-COOKE-P Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/2/11:17:54:43 mattcooke MATTHEW-COOKE-P Install DirectX® Runtime Succeeded
2016/2/11:17:54:43 mattcooke MATTHEW-COOKE-P Download Play MAYA http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA...
2016/2/11:17:57:07 mattcooke MATTHEW-COOKE-P Download Aborted MAYA http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA...
2016/2/11:17:57:07 mattcooke MATTHEW-COOKE-P Install Autodesk® Maya® 2016 Failed Download Failed, Installation aborted, Result=1603
2016/2/11:17:57:08 mattcooke MATTHEW-COOKE-P Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/2/11:17:57:08 mattcooke MATTHEW-COOKE-P Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/2/11:17:57:08 mattcooke MATTHEW-COOKE-P Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/2/11:17:57:09 mattcooke MATTHEW-COOKE-P PageOpen InstallCompleteDialog
2016/2/11:18:41:49 mattcooke MATTHEW-COOKE-P === Setup ended ===
2016/2/11:18:44:03 mattcooke MATTHEW-COOKE-P === Setup started on MATTHEW-COOKE-P by mattcooke ===
2016/2/11:18:44:03 mattcooke MATTHEW-COOKE-P Path_Length: 153
2016/2/11:18:44:03 mattcooke MATTHEW-COOKE-P Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2016/2/11:18:44:03 mattcooke MATTHEW-COOKE-P Launch
2016/2/11:18:44:03 mattcooke MATTHEW-COOKE-P CommandLine /PK 657H1 /SN 900-66576823 /akamai /sid a1b30000008i7xBAAQ /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?authp...
2016/2/11:18:44:03 mattcooke MATTHEW-COOKE-P Current Directory C:\Users\MATTCO~1\AppData\Local\Temp\_AI67D8.tmp
2016/2/11:18:44:09 mattcooke MATTHEW-COOKE-P === Setup ended ===
2016/2/11:18:44:04 mattcooke MATTHEW-COOKE-P === Setup started on MATTHEW-COOKE-P by mattcooke ===
2016/2/11:18:44:04 mattcooke MATTHEW-COOKE-P Path_Length: 153
2016/2/11:18:44:04 mattcooke MATTHEW-COOKE-P Current Directory C:\Users\MATTCO~1\AppData\Local\Temp\_AI67D8.tmp
2016/2/11:18:44:04 mattcooke MATTHEW-COOKE-P Launch
2016/2/11:18:44:05 mattcooke MATTHEW-COOKE-P Download Play SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/11:18:44:05 mattcooke MATTHEW-COOKE-P Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/11:18:44:05 mattcooke MATTHEW-COOKE-P Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/11:18:44:09 mattcooke MATTHEW-COOKE-P Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/11:18:44:09 mattcooke MATTHEW-COOKE-P PageOpen LaunchDialog
2016/2/11:18:44:17 mattcooke MATTHEW-COOKE-P PageOpen LicenseDialog
2016/2/11:18:44:17 mattcooke MATTHEW-COOKE-P PageOpen ProductInfoDialog
2016/2/11:18:44:17 mattcooke MATTHEW-COOKE-P PageOpen ProductSelectionDialog2
2016/2/11:18:44:52 mattcooke MATTHEW-COOKE-P PageOpen FullProgressDialog
2016/2/11:18:44:52 mattcooke MATTHEW-COOKE-P Download Play STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STAR...
2016/2/11:18:44:53 mattcooke MATTHEW-COOKE-P Download Complete STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STAR...
2016/2/11:18:44:53 mattcooke MATTHEW-COOKE-P Download Play VCREDIST2012X86UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/11:18:44:55 mattcooke MATTHEW-COOKE-P Download Complete VCREDIST2012X86UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/11:18:44:55 mattcooke MATTHEW-COOKE-P Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/2/11:18:44:56 mattcooke MATTHEW-COOKE-P Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/2/11:18:44:57 mattcooke MATTHEW-COOKE-P Download Play VCREDIST2012X64UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/11:18:44:59 mattcooke MATTHEW-COOKE-P Download Complete VCREDIST2012X64UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/11:18:44:59 mattcooke MATTHEW-COOKE-P Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/2/11:18:45:00 mattcooke MATTHEW-COOKE-P Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/2/11:18:45:00 mattcooke MATTHEW-COOKE-P Download Play DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRE...
2016/2/11:18:45:02 mattcooke MATTHEW-COOKE-P Download Complete DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRE...
2016/2/11:18:45:02 mattcooke MATTHEW-COOKE-P Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/2/11:18:45:04 mattcooke MATTHEW-COOKE-P Install DirectX® Runtime Succeeded
2016/2/11:18:45:04 mattcooke MATTHEW-COOKE-P Download Play MAYA http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA...
2016/2/11:18:47:33 mattcooke MATTHEW-COOKE-P Download Aborted MAYA http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA...
2016/2/11:18:47:33 mattcooke MATTHEW-COOKE-P Install Autodesk® Maya® 2016 Failed Download Failed, Installation aborted, Result=1603
2016/2/11:18:47:33 mattcooke MATTHEW-COOKE-P Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/2/11:18:47:33 mattcooke MATTHEW-COOKE-P Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/2/11:18:47:34 mattcooke MATTHEW-COOKE-P Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/2/11:18:47:34 mattcooke MATTHEW-COOKE-P PageOpen InstallCompleteDialog
2016/2/11:20:46:48 mattcooke MATTHEW-COOKE-P === Setup ended ===
2016/2/12:11:31:23 mattcooke MATTHEW-COOKE-P === Setup started on MATTHEW-COOKE-P by mattcooke ===
2016/2/12:11:31:23 mattcooke MATTHEW-COOKE-P Path_Length: 153
2016/2/12:11:31:23 mattcooke MATTHEW-COOKE-P Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2016/2/12:11:31:23 mattcooke MATTHEW-COOKE-P Launch
2016/2/12:11:31:23 mattcooke MATTHEW-COOKE-P CommandLine /PK 657H1 /SN 900-66576823 /akamai /sid a1b30000008iGrWAAU /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?authp...
2016/2/12:11:31:23 mattcooke MATTHEW-COOKE-P Current Directory C:\Users\MATTCO~1\AppData\Local\Temp\_AIA421.tmp
2016/2/12:11:31:30 mattcooke MATTHEW-COOKE-P === Setup ended ===
2016/2/12:11:31:24 mattcooke MATTHEW-COOKE-P Download Play SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/12:11:31:24 mattcooke MATTHEW-COOKE-P Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/12:11:31:24 mattcooke MATTHEW-COOKE-P Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/12:11:31:29 mattcooke MATTHEW-COOKE-P Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/12:11:31:30 mattcooke MATTHEW-COOKE-P PageOpen LaunchDialog
2016/2/12:11:31:36 mattcooke MATTHEW-COOKE-P PageOpen LicenseDialog
2016/2/12:11:31:36 mattcooke MATTHEW-COOKE-P PageOpen ProductInfoDialog
2016/2/12:11:31:36 mattcooke MATTHEW-COOKE-P PageOpen ProductSelectionDialog2
2016/2/12:11:31:40 mattcooke MATTHEW-COOKE-P PageOpen FullProgressDialog
2016/2/12:11:31:42 mattcooke MATTHEW-COOKE-P Download Play STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STAR...
2016/2/12:11:31:42 mattcooke MATTHEW-COOKE-P Download Complete STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STAR...
2016/2/12:11:31:43 mattcooke MATTHEW-COOKE-P Download Play VCREDIST2012X86UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/12:11:31:47 mattcooke MATTHEW-COOKE-P Download Complete VCREDIST2012X86UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/12:11:31:47 mattcooke MATTHEW-COOKE-P Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/2/12:11:31:48 mattcooke MATTHEW-COOKE-P Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/2/12:11:31:49 mattcooke MATTHEW-COOKE-P Download Play VCREDIST2012X64UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/12:11:31:53 mattcooke MATTHEW-COOKE-P Download Complete VCREDIST2012X64UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/12:11:31:53 mattcooke MATTHEW-COOKE-P Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/2/12:11:31:54 mattcooke MATTHEW-COOKE-P Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/2/12:11:31:55 mattcooke MATTHEW-COOKE-P Download Play DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRE...
2016/2/12:11:31:57 mattcooke MATTHEW-COOKE-P Download Complete DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRE...
2016/2/12:11:31:57 mattcooke MATTHEW-COOKE-P Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/2/12:11:32:00 mattcooke MATTHEW-COOKE-P Install DirectX® Runtime Succeeded
2016/2/12:11:32:01 mattcooke MATTHEW-COOKE-P Download Play MAYA http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA...
2016/2/12:11:35:05 mattcooke MATTHEW-COOKE-P Download Aborted MAYA http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA...
2016/2/12:11:35:05 mattcooke MATTHEW-COOKE-P Install Autodesk® Maya® 2016 Failed Download Failed, Installation aborted, Result=1603
2016/2/12:11:35:05 mattcooke MATTHEW-COOKE-P Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/2/12:11:35:05 mattcooke MATTHEW-COOKE-P Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/2/12:11:35:05 mattcooke MATTHEW-COOKE-P Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/2/12:11:35:06 mattcooke MATTHEW-COOKE-P PageOpen InstallCompleteDialog
2016/2/12:11:55:49 mattcooke MATTHEW-COOKE-P === Setup ended ===
2016/2/12:11:57:26 mattcooke MATTHEW-COOKE-P === Setup started on MATTHEW-COOKE-P by mattcooke ===
2016/2/12:11:57:26 mattcooke MATTHEW-COOKE-P Path_Length: 153
2016/2/12:11:57:26 mattcooke MATTHEW-COOKE-P Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2016/2/12:11:57:26 mattcooke MATTHEW-COOKE-P Launch
2016/2/12:11:57:26 mattcooke MATTHEW-COOKE-P CommandLine /PK 657H1 /SN 900-66576823 /akamai /sid a1b30000008iGrWAAU /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?authp...
2016/2/12:11:57:26 mattcooke MATTHEW-COOKE-P Current Directory C:\Users\MATTCO~1\AppData\Local\Temp\_AI7EB2.tmp
2016/2/12:11:57:32 mattcooke MATTHEW-COOKE-P === Setup ended ===
2016/2/12:11:57:27 mattcooke MATTHEW-COOKE-P === Setup started on MATTHEW-COOKE-P by mattcooke ===
2016/2/12:11:57:27 mattcooke MATTHEW-COOKE-P Path_Length: 153
2016/2/12:11:57:27 mattcooke MATTHEW-COOKE-P Current Directory C:\Users\MATTCO~1\AppData\Local\Temp\_AI7EB2.tmp
2016/2/12:11:57:27 mattcooke MATTHEW-COOKE-P Launch
2016/2/12:11:57:27 mattcooke MATTHEW-COOKE-P Download Play SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/12:11:57:27 mattcooke MATTHEW-COOKE-P Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/12:11:57:28 mattcooke MATTHEW-COOKE-P Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/12:11:57:31 mattcooke MATTHEW-COOKE-P Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETU...
2016/2/12:11:57:31 mattcooke MATTHEW-COOKE-P PageOpen LaunchDialog
2016/2/12:11:57:45 mattcooke MATTHEW-COOKE-P PageOpen LicenseDialog
2016/2/12:11:57:45 mattcooke MATTHEW-COOKE-P PageOpen ProductInfoDialog
2016/2/12:11:57:45 mattcooke MATTHEW-COOKE-P PageOpen ProductSelectionDialog2
2016/2/12:11:57:48 mattcooke MATTHEW-COOKE-P PageOpen FullProgressDialog
2016/2/12:11:57:48 mattcooke MATTHEW-COOKE-P Download Play STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STAR...
2016/2/12:11:57:48 mattcooke MATTHEW-COOKE-P Download Complete STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STAR...
2016/2/12:11:57:48 mattcooke MATTHEW-COOKE-P Download Play VCREDIST2012X86UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/12:11:57:51 mattcooke MATTHEW-COOKE-P Download Complete VCREDIST2012X86UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/12:11:57:51 mattcooke MATTHEW-COOKE-P Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/2/12:11:57:52 mattcooke MATTHEW-COOKE-P Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/2/12:11:57:52 mattcooke MATTHEW-COOKE-P Download Play VCREDIST2012X64UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/12:11:57:54 mattcooke MATTHEW-COOKE-P Download Complete VCREDIST2012X64UPD4 http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCRE...
2016/2/12:11:57:54 mattcooke MATTHEW-COOKE-P Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/2/12:11:57:55 mattcooke MATTHEW-COOKE-P Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/2/12:11:57:55 mattcooke MATTHEW-COOKE-P Download Play DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRE...
2016/2/12:11:57:57 mattcooke MATTHEW-COOKE-P Download Complete DIRECTX http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRE...
2016/2/12:11:57:57 mattcooke MATTHEW-COOKE-P Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/2/12:11:58:01 mattcooke MATTHEW-COOKE-P Install DirectX® Runtime Succeeded
2016/2/12:11:58:01 mattcooke MATTHEW-COOKE-P Download Play MAYA http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA...
2016/2/12:12:00:17 mattcooke MATTHEW-COOKE-P Download Aborted MAYA http://efulfillment.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA...
2016/2/12:12:00:17 mattcooke MATTHEW-COOKE-P Install Autodesk® Maya® 2016 Failed Download Failed, Installation aborted, Result=1603
2016/2/12:12:00:17 mattcooke MATTHEW-COOKE-P Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/2/12:12:00:18 mattcooke MATTHEW-COOKE-P Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/2/12:12:00:18 mattcooke MATTHEW-COOKE-P Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
And this is my installation log file for DirectConnect 2016:
Thank you.
matthew.d
Hi @Anonymous,
Thanks for posting. This is an error 1603, here is how to resolve this. The easiest way though is to download from the virtual agent with your antivirus off though (linked in my first post).
Note: you can attach files Smiley Wink
Matt DiMichele
Thank you so much!!!
Hello
I am having issues when istalling maya
the problem i got is that the installation says:
failed to instal
how can i fix it?
matthew.d
Hi @Anonymous,
Great to have you in the community.
Have you tried disabiling your antivirus and installing from the virtual agent?
Matt DiMichele
Yes, i did try that way and i get this erros
And i can select the software
lynn_zhang
Hi @Anonymous
Could you post your installation log files so that we can further check?
Lynn Zhang
Where can i find the installation log file?
Mark.Lancaster
@Anonymous
See this article: https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Location-of-the-log-files-generated-by-the-installation-of-an-Autodesk-product.html
Mark Lancaster
Type a product name
