Installation & Licensing
213 Views, 2 Replies
ERRROR FATAL
FATAL ERROR: Unhandled Access Violation Reading 0x0028 Exception at 643D4060h
Need help genius, thnks
ERRROR FATAL
2 REPLIES 2
Mark.Lancaster
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Fatal error for what?   Are we supposed to guess...  😁    Autodesk product and version?
This could point to the following
If this fatal error is based on the startup of a 2018 product line, make sure you have this >>licensing hot fix<< installed
1.  You need to >>clean out<< your personal temp (%temp) folder with in Windows.  You will not be able to delete everything but try to delete as many files and folders as possible.
2.  Run a repair on your Autodesk product.  Go to Windows Control Panel/Program and Features/Add & Remove Programs, locate your Autodesk product and right mouse select to uninstall/change.  Select repair when the menu comes up.
3.  You have an outdated graphics card driver or a card that's not supported.  Don't rely on Windows telling you its up-to-date.  Go directly to Windows Device Manager and locate your graphics card under dispay adapter.  Right mouse click on the card and select proprieties.  Go to the "Driver" tab and look at the driver date.
4.  Issues with Microsoft C++  --> https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
5.  Issues with Microsoft Netframe https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
In end try each one before moving onto the next one.
Mark Lancaster
@Anonymous
Mark Lancaster
Administrator Productivity
