Installation & Licensing
Error module installing 'Foundation' Maya 2014 Student License - Mac
7 REPLIES 7
Message 1 of 8
1946 Views, 7 Replies
Hello, I need some help!
I'm and animation and I'm late in some deliveries because it's happening some error I on the installation of Maya 2014 in my Mac Yosemite 2014.
It's a student license, and the message that appear is:
"An unexpected error has occurred during execution of the main script ZipImportError: can't find module 'Foundation' See the Console for a detailed traceback."
I really don't know how to proceed.
I need help.
Thank you!
7 REPLIES 7
Message 2 of 8
dembkod
polyanaliz
Not sure what is occuring. Sounds like a possible corrupt download. Download and try to install Servcie Pack 4. This is a full installer.
http://knowledge.autodesk.com/support/maya/downloads/caas/downloads/content/autodesk-maya-2014-servi...
Download and give this a try. It may help.
Thank you for taking part in our community!
David Dembkoski
Message 3 of 8
in reply to: dembkod
I tried to do as you said and still happens the same error while installing the Autodesk Maya 2014.
In the console that’s what appears:
14/03/15 14:45:35,142 nsurlstoraged[245]: ERROR: unable to determine file-system usage for FS-backed cache at /var/root/Library/Caches/installer/fsCachedData. Errno=13
14/03/15 14:45:37,412 Safari[395]: Failed to save record: <CKError 0x608002053320: "Internal Error" (1/5001); "Fetched zone had no protection data&colon; <CKRecordZone: 0x7fc1886a81d0; zoneID=History:__defaultOwner__, capabilities=(Atomic,Sync)>">
I have no idea what to do and I really need to install this program with the student license asap.
I’m very grateful if you can help me.
Thank you.
Message 4 of 8
Umm.. he's asking about an install problem on a Mac.. not a Windows OS.
Message 5 of 8
franchuterivera
Hi, I'm having this exact same trouble. The reason I'm staying with maya 2014 is that Animation mentor does not support maya 2016 yet, so I need to fix this problem because maya is crashing so much and I need those updates for fixing other issues.
Is there a solution? I'm on iOs
BTW: Maya 2016 and his BIG bug with auto key turnedo on, my personal nightmare as an animator.
Message 6 of 8
I have the same problem 😞
Message 7 of 8
natasha.l
Hello @Anonymous,
Welcome to the forum, I am glad you posted.
I am not sure what method of download you are using, the easiest method is via the Autodesk Virtual Agent
Please proceed as follows:
  • Clean Uninstall of the program
  • Logon as an Administrator.
  • Empty your TEMP folder.  To open the TEMP folder, type %TEMP% in the address bar of Windows Explorer and hit Enter.
  • Disable your Antivirus software.
  • Disable UAC.
W7: http://windows.microsoft.com/en-ca/windows7/turn-user-account-control-on-or-off
W10: http://winaero.com/blog/how-to-turn-off-and-disable-uac-in-windows-10/
  • Download all of the parts Autodesk Virtual Agent
  • Locate the download folder and extract (double click) part _001_00X.sfx.exe. If you have a permission issue right click and select, Run as administrator.
  • Files will be directed to C:\Autodesk
  • Follow the prompts to install the program
I hope this answered your question or resolved the issue, if so please click Kudos or the "thumbs-up!" Did my response help resolve the issue? Please "Accept As Solution" to help others in the community.
Message 8 of 8
natasha.l
 Hello @Anonymous,
You may want to consider checking to see if you are eligible to download free educational software. You could download the latest 2017 software. Please refer to these links below:
Administrator Productivity
