Installation & Licensing
Error 1606 when uninstalling Autocad Civil 3D
3 REPLIES 3
1570 Views, 3 Replies
I've uninstalled all Autodesk apps in windows 10.
The last is AutoCad Civil 3D.
this will not uninstall with followin error message:
Error 1606. Could not acces network location 0.
Since I had no clue what to do, I searched a bit.
The solution is to be found in the registry.
But then again, my knowledge is unsufficient to be messing about in the registry.
I have included screenshots for if anyone is able to help me out.
The idea is to reinstall Civil 3D since it was not installed correctly.
Kind regards,
Steven
3 REPLIES 3
Otto
Hello belgikaans082466 and welcome to the Autodesk community!
It looks like you're seeing Error 1606 while trying to install an Autodesk product. This issue occurs because the installer tries to place files into another user's profile where you do not have write access. The following article(s) should help you resolve the problem:
"Error 1606: Could not access network location" when using "Run as" option to install
Get Your Autodesk Software Up & Running
Errors during AutoCAD software installation
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
in reply to: Otto
Alas,
I'm working under the admin account. I can reach the folders mentioned in the earlier post.
I've tried to reinstall Civil 3D. Again installation failed. I've uploaded the logfiles and screenshot of the installation sumary.
The logfile is a bit 'vague' as to the reason why installation failed.
Kind regards,
Steven
Mark.Lancaster
@Anonymous
Welcome to the community and hopefully my (or someone else) reply will be beneficially to you.
As a reminder, this is a world wide (public) user forum where users are assisting others. In addition do not post, attach screen shots, or share any personal information (such as your serial #) here.
Your download is failing..   Just review the verbiage below the line/above my signature and follow those steps to download and install your application.
Mark Lancaster
Administrator Productivity
