Installation & Licensing
Error 1603 installing Autodesk AutoCad Architecture 2011
11 REPLIES 11
Message 1 of 12
74949 Views, 11 Replies
I am running Windows 7 Ultimate 64 Bit orginal from MS.  Since I have installed this I receive each time when I try to install Autodesk Autocad Architecture Visual C++ 2008 SP1 (x64 following error message:  Error 1935. Error durante la instalación del ensamblado: Microsoft VC90. MFCLOC, version = "9.0.30729.1", publicKeyToken=" 1fc8b3b9a1e18e3b", processorArchitecture = "amd64", type="win32"'. The Problem I have now that all the new Software using Visual C++ 2008 SP1(x64, eg: all Autodesk 2011 software like Autocad Architecture 2011, Maya 2011, Revit 2011 I cannot install. It would be great if someboddy could help me to solve this problem because I need to use the above Software urgently within my job. Thanks
2010/8/18:08:28:04 wilfried WILFRIED === Setup started on WILFRIED by wilfried ===
2010/8/18:08:28:35 wilfried WILFRIED === Setup ended ===
2010/8/18:08:28:23 wilfried WILFRIED === Setup started on WILFRIED by wilfried ===
2010/8/18:08:33:32 wilfried WILFRIED Install Autodesk Design Review 2011 Succeeded
2010/8/18:08:33:38 wilfried WILFRIED Install Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1603
2010/8/18:08:33:55 wilfried WILFRIED Rollback Autodesk Design Review 2011 Succeeded
2010/8/18:08:45:42 wilfried WILFRIED Install Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1603
2010/8/18:08:56:13 wilfried WILFRIED Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2010/8/18:08:56:17 wilfried WILFRIED Install Microsoft Visual C++ 2008 Redistributable (x86) Succeeded
2010/8/18:08:57:03 wilfried WILFRIED Install Autodesk Design Review 2011 Succeeded
2010/8/18:08:57:12 wilfried WILFRIED Install Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1603
2010/8/18:08:57:25 wilfried WILFRIED Rollback Autodesk Design Review 2011 Succeeded
2010/8/18:08:57:25 wilfried WILFRIED Rollback Microsoft Visual C++ 2008 Redistributable (x86) Failed Installation aborted, Result=1619
2010/8/18:08:57:25 wilfried WILFRIED Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2010/8/18:09:29:58 wilfried WILFRIED === Setup ended ===
2010/8/19:07:33:13 wilfried WILFRIED === Setup started on WILFRIED by wilfried ===
2010/8/19:07:33:43 wilfried WILFRIED === Setup ended ===
2010/8/19:07:33:37 wilfried WILFRIED === Setup started on WILFRIED by wilfried ===
2010/8/19:07:38:54 wilfried WILFRIED Install Autodesk Design Review 2011 Succeeded
2010/8/19:07:39:00 wilfried WILFRIED Install Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1603
2010/8/19:07:39:17 wilfried WILFRIED Rollback Autodesk Design Review 2011 Succeeded
2010/8/19:07:39:35 wilfried WILFRIED === Setup ended ===
11 REPLIES 11
Message 2 of 12
pendean
Message 3 of 12
Was getting the same error when i try to install revit 2012 suite. Google search gave me this link..
http://delphintipz.blogspot.com/2011/09/microsoft-visual-c-2005-redistributable.html
helped me to save a lot of time..
Message 4 of 12
For google to find, a simpler solution:
Open Setup.ini in the Autodesk product folder
Comment out these pairs of lines: (by adding a "#" in front of each line)
EXE_PARAM=/q
VC_FUNC=VCx64RedisCheck
EXE_PARAM=/q
VC_FUNC=VCx86RedisCheck
During the installation, Microsoft installers will now pop up. Select "repair" in both cases, and make sure everything goes well. If one of the installers fails, cancel the Autodesk installation and solve the problem the installer had.
What this does is prevent the Autodesk installer from checking if the VC++ packages are correctly installed.This is a solution only if (as it was in my case) the check reports a false negative. If you really have problems with your VC++ installation, it might be a good idea to reinstall Windows.
If you still don't get past the VC++ installation (but you are sure your installation is ok), you might also want to comment out this block:
EXE_PARAM=/q /l %temp%\vcredist_x86_2010.log
Tags (2)
Message 5 of 12
In my case I had a later version of the Microsoft Visual C++ 2010 x86 redistrutable already installed on my computer, so when trying to install AutoCAD 2012 the installer was failing.
The solution in my case was to uninstall the existing copy of Microsoft Visual C++ 2010 x86, then re-run the AutoCAD 2012 installer.
Message 6 of 12
That was fantastic! It has been extremly difficult to install/uninstall this software and all of its add-ons up until this point.  Thanks for this post!  As it turns out, my version of Visual Studio 2010 was too new and not recognized, so it errored out.  I uninstalled it and allowed AutoDesk to reinstall and whalla!
Message 7 of 12
I just uninstalledMicrosoft Visual C++ 2010 Redistributable (x86).  After that my install of Vault 2012 went smooth.
Message 8 of 12
Message 9 of 12
plese help me i need to install on windows 8
2013/9/30:17:13:19 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/9/30:17:13:19 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/9/30:17:13:19 Dual Ehitel DUALEHITEL-PC Current Directory L:
2013/9/30:17:13:19 Dual Ehitel DUALEHITEL-PC Launch
2013/9/30:17:13:19 Dual Ehitel DUALEHITEL-PC CommandLine
2013/9/30:17:13:19 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AIBC14.tmp
2013/9/30:17:13:40 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/9/30:17:13:24 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/9/30:17:13:24 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/9/30:17:13:24 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AIBC14.tmp
2013/9/30:17:13:24 Dual Ehitel DUALEHITEL-PC Launch
2013/9/30:17:13:25 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\DUALEH~1\AppData\Local\Temp\_AIBC14.tmp\Setup\RevitSetup.dll
2013/9/30:17:13:25 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/9/30:17:13:39 Dual Ehitel DUALEHITEL-PC PageOpen LaunchDialog
2013/9/30:17:13:56 Dual Ehitel DUALEHITEL-PC PageOpen LicenseDialog
2013/9/30:17:13:58 Dual Ehitel DUALEHITEL-PC PageOpen ProductInfoDialog
2013/9/30:17:16:41 Dual Ehitel DUALEHITEL-PC PageOpen ProductSelectionDialog2
2013/9/30:17:33:30 Dual Ehitel DUALEHITEL-PC PageOpen FullProgressDialog
2013/9/30:17:33:30 Dual Ehitel DUALEHITEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "L:\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\DUALEH~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/9/30:17:33:49 Dual Ehitel DUALEHITEL-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/9/30:17:33:56 Dual Ehitel DUALEHITEL-PC PageOpen InstallCompleteDialog
2013/9/30:17:41:14 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/9/30:17:41:29 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/9/30:17:41:29 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/9/30:17:41:29 Dual Ehitel DUALEHITEL-PC Current Directory L:
2013/9/30:17:41:29 Dual Ehitel DUALEHITEL-PC Launch
2013/9/30:17:41:29 Dual Ehitel DUALEHITEL-PC CommandLine
2013/9/30:17:41:29 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AI87FA.tmp
2013/9/30:17:41:35 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/9/30:17:41:32 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/9/30:17:41:32 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/9/30:17:41:32 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AI87FA.tmp
2013/9/30:17:41:32 Dual Ehitel DUALEHITEL-PC Launch
2013/9/30:17:41:32 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\DUALEH~1\AppData\Local\Temp\_AI87FA.tmp\Setup\RevitSetup.dll
2013/9/30:17:41:32 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/9/30:17:41:35 Dual Ehitel DUALEHITEL-PC PageOpen LaunchDialog
2013/9/30:17:41:40 Dual Ehitel DUALEHITEL-PC PageOpen LicenseDialog
2013/9/30:17:41:43 Dual Ehitel DUALEHITEL-PC PageOpen ProductInfoDialog
2013/9/30:17:42:15 Dual Ehitel DUALEHITEL-PC PageOpen ProductSelectionDialog2
2013/9/30:17:53:06 Dual Ehitel DUALEHITEL-PC PageOpen FullProgressDialog
2013/9/30:17:53:06 Dual Ehitel DUALEHITEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "L:\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\DUALEH~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/9/30:17:53:31 Dual Ehitel DUALEHITEL-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/9/30:17:53:38 Dual Ehitel DUALEHITEL-PC PageOpen InstallCompleteDialog
2013/10/1:09:46:45 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/1:09:51:46 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/1:09:51:46 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/1:09:51:46 Dual Ehitel DUALEHITEL-PC Current Directory L:
2013/10/1:09:51:46 Dual Ehitel DUALEHITEL-PC Launch
2013/10/1:09:51:46 Dual Ehitel DUALEHITEL-PC CommandLine
2013/10/1:09:51:46 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AIDB1B.tmp
2013/10/1:09:52:04 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/1:09:51:51 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/1:09:51:51 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/1:09:51:51 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AIDB1B.tmp
2013/10/1:09:51:51 Dual Ehitel DUALEHITEL-PC Launch
2013/10/1:09:51:52 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\DUALEH~1\AppData\Local\Temp\_AIDB1B.tmp\Setup\RevitSetup.dll
2013/10/1:09:51:52 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/1:09:52:04 Dual Ehitel DUALEHITEL-PC PageOpen LaunchDialog
2013/10/1:09:52:10 Dual Ehitel DUALEHITEL-PC PageOpen LicenseDialog
2013/10/1:09:52:12 Dual Ehitel DUALEHITEL-PC PageOpen ProductInfoDialog
2013/10/1:09:52:33 Dual Ehitel DUALEHITEL-PC PageOpen ProductSelectionDialog2
2013/10/1:09:53:34 Dual Ehitel DUALEHITEL-PC PageOpen FullProgressDialog
2013/10/1:09:53:34 Dual Ehitel DUALEHITEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "L:\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\DUALEH~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/10/1:09:53:48 Dual Ehitel DUALEHITEL-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/10/1:09:53:54 Dual Ehitel DUALEHITEL-PC PageOpen InstallCompleteDialog
2013/10/1:09:59:30 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/1:10:00:38 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/1:10:00:38 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/1:10:00:38 Dual Ehitel DUALEHITEL-PC Current Directory L:
2013/10/1:10:00:38 Dual Ehitel DUALEHITEL-PC Launch
2013/10/1:10:00:38 Dual Ehitel DUALEHITEL-PC CommandLine
2013/10/1:10:00:38 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AIF61A.tmp
2013/10/1:10:00:43 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/1:10:00:39 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/1:10:00:39 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/1:10:00:39 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AIF61A.tmp
2013/10/1:10:00:39 Dual Ehitel DUALEHITEL-PC Launch
2013/10/1:10:00:40 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\DUALEH~1\AppData\Local\Temp\_AIF61A.tmp\Setup\RevitSetup.dll
2013/10/1:10:00:40 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/1:10:00:43 Dual Ehitel DUALEHITEL-PC PageOpen LaunchDialog
2013/10/1:10:01:36 Dual Ehitel DUALEHITEL-PC PageOpen LicenseDialog
2013/10/1:10:01:39 Dual Ehitel DUALEHITEL-PC PageOpen ProductInfoDialog
2013/10/1:10:03:58 Dual Ehitel DUALEHITEL-PC PageOpen ProductSelectionDialog2
2013/10/1:10:35:41 Dual Ehitel DUALEHITEL-PC PageOpen FullProgressDialog
2013/10/1:10:35:41 Dual Ehitel DUALEHITEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "L:\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\DUALEH~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/10/1:10:36:08 Dual Ehitel DUALEHITEL-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/10/1:10:36:19 Dual Ehitel DUALEHITEL-PC PageOpen InstallCompleteDialog
2013/10/1:10:36:29 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:16:15:50 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:16:15:50 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:16:15:50 Dual Ehitel DUALEHITEL-PC Current Directory L:
2013/10/7:16:15:50 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:16:15:50 Dual Ehitel DUALEHITEL-PC CommandLine
2013/10/7:16:15:50 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AI77FD.tmp
2013/10/7:16:16:13 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:16:15:58 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:16:15:58 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:16:15:58 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AI77FD.tmp
2013/10/7:16:15:58 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:16:15:58 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\DUALEH~1\AppData\Local\Temp\_AI77FD.tmp\Setup\RevitSetup.dll
2013/10/7:16:15:58 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/7:16:16:13 Dual Ehitel DUALEHITEL-PC PageOpen LaunchDialog
2013/10/7:16:16:16 Dual Ehitel DUALEHITEL-PC PageOpen LicenseDialog
2013/10/7:16:16:21 Dual Ehitel DUALEHITEL-PC PageOpen ProductInfoDialog
2013/10/7:16:18:54 Dual Ehitel DUALEHITEL-PC PageOpen ProductSelectionDialog2
2013/10/7:16:19:56 Dual Ehitel DUALEHITEL-PC PageOpen FullProgressDialog
2013/10/7:16:19:56 Dual Ehitel DUALEHITEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "L:\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2013/10/7:16:20:48 Dual Ehitel DUALEHITEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2013/10/7:16:20:48 Dual Ehitel DUALEHITEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "L:\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\DUALEH~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/10/7:16:21:05 Dual Ehitel DUALEHITEL-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/10/7:16:21:10 Dual Ehitel DUALEHITEL-PC PageOpen InstallCompleteDialog
2013/10/7:16:26:21 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:17:16:06 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:17:16:06 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:17:16:06 Dual Ehitel DUALEHITEL-PC Current Directory K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014
2013/10/7:17:16:06 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:17:16:06 Dual Ehitel DUALEHITEL-PC CommandLine
2013/10/7:17:16:06 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AIA332.tmp
2013/10/7:17:16:19 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:17:16:29 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:17:16:29 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:17:16:29 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AIF0A6.tmp
2013/10/7:17:16:29 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:17:16:30 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\DUALEH~1\AppData\Local\Temp\_AIF0A6.tmp\Setup\RevitSetup.dll
2013/10/7:17:16:30 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Custom callback response: Status=3 ERROR Title=Unsupported Operating System Message=You cannot install this product on the current operating system. URLTitle= URLLink=
2013/10/7:17:16:34 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:17:16:25 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:17:16:25 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:17:16:25 Dual Ehitel DUALEHITEL-PC Current Directory K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014
2013/10/7:17:16:25 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:17:16:25 Dual Ehitel DUALEHITEL-PC CommandLine
2013/10/7:17:16:25 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AIF0A6.tmp
2013/10/7:17:16:49 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:17:16:49 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:17:16:49 Dual Ehitel DUALEHITEL-PC Current Directory K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014
2013/10/7:17:16:49 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:17:16:49 Dual Ehitel DUALEHITEL-PC CommandLine
2013/10/7:17:16:49 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AI4DA4.tmp
2013/10/7:17:16:56 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:17:16:52 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:17:16:52 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:17:16:52 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AI4DA4.tmp
2013/10/7:17:16:52 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:17:16:52 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\DUALEH~1\AppData\Local\Temp\_AI4DA4.tmp\Setup\RevitSetup.dll
2013/10/7:17:16:52 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/7:17:16:56 Dual Ehitel DUALEHITEL-PC PageOpen LaunchDialog
2013/10/7:17:17:00 Dual Ehitel DUALEHITEL-PC PageOpen LicenseDialog
2013/10/7:17:17:02 Dual Ehitel DUALEHITEL-PC PageOpen ProductInfoDialog
2013/10/7:17:20:23 Dual Ehitel DUALEHITEL-PC PageOpen ProductSelectionDialog2
2013/10/7:17:20:54 Dual Ehitel DUALEHITEL-PC PageOpen FullProgressDialog
2013/10/7:17:20:54 Dual Ehitel DUALEHITEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\DUALEH~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/10/7:17:21:12 Dual Ehitel DUALEHITEL-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/10/7:17:21:17 Dual Ehitel DUALEHITEL-PC PageOpen InstallCompleteDialog
2013/10/7:17:21:58 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:17:29:00 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:17:29:00 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:17:29:00 Dual Ehitel DUALEHITEL-PC Current Directory K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014
2013/10/7:17:29:00 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:17:29:00 Dual Ehitel DUALEHITEL-PC CommandLine
2013/10/7:17:29:00 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AI760B.tmp
2013/10/7:17:29:06 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:17:29:02 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:17:29:02 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:17:29:02 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AI760B.tmp
2013/10/7:17:29:02 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:17:29:03 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\DUALEH~1\AppData\Local\Temp\_AI760B.tmp\Setup\RevitSetup.dll
2013/10/7:17:29:03 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/7:17:29:06 Dual Ehitel DUALEHITEL-PC PageOpen LaunchDialog
2013/10/7:17:32:04 Dual Ehitel DUALEHITEL-PC PageOpen LicenseDialog
2013/10/7:17:32:06 Dual Ehitel DUALEHITEL-PC PageOpen ProductInfoDialog
2013/10/7:17:33:15 Dual Ehitel DUALEHITEL-PC PageOpen ProductSelectionDialog2
2013/10/7:17:33:42 Dual Ehitel DUALEHITEL-PC PageOpen FullProgressDialog
2013/10/7:17:33:42 Dual Ehitel DUALEHITEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\DUALEH~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/10/7:17:33:58 Dual Ehitel DUALEHITEL-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/10/7:17:34:02 Dual Ehitel DUALEHITEL-PC PageOpen InstallCompleteDialog
2013/10/7:17:34:06 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:17:34:10 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:17:34:10 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:17:34:10 Dual Ehitel DUALEHITEL-PC Current Directory K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014
2013/10/7:17:34:10 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:17:34:10 Dual Ehitel DUALEHITEL-PC CommandLine
2013/10/7:17:34:10 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AI3006.tmp
2013/10/7:17:34:15 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:17:34:11 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:17:34:11 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:17:34:11 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AI3006.tmp
2013/10/7:17:34:11 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:17:34:12 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\DUALEH~1\AppData\Local\Temp\_AI3006.tmp\Setup\RevitSetup.dll
2013/10/7:17:34:12 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/7:17:34:15 Dual Ehitel DUALEHITEL-PC PageOpen LaunchDialog
2013/10/7:17:34:18 Dual Ehitel DUALEHITEL-PC PageOpen LicenseDialog
2013/10/7:17:34:21 Dual Ehitel DUALEHITEL-PC PageOpen ProductInfoDialog
2013/10/7:17:34:39 Dual Ehitel DUALEHITEL-PC PageOpen ProductSelectionDialog2
2013/10/7:17:34:50 Dual Ehitel DUALEHITEL-PC PageOpen FullProgressDialog
2013/10/7:17:34:50 Dual Ehitel DUALEHITEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\DUALEH~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/10/7:17:35:05 Dual Ehitel DUALEHITEL-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/10/7:18:02:47 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:18:02:47 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:18:02:47 Dual Ehitel DUALEHITEL-PC Current Directory K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014
2013/10/7:18:02:47 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:18:02:47 Dual Ehitel DUALEHITEL-PC CommandLine
2013/10/7:18:02:47 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AIBD36.tmp
2013/10/7:18:03:08 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:18:02:52 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:18:02:52 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:18:02:52 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AIBD36.tmp
2013/10/7:18:02:52 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:18:02:54 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\DUALEH~1\AppData\Local\Temp\_AIBD36.tmp\Setup\RevitSetup.dll
2013/10/7:18:02:54 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/7:18:03:09 Dual Ehitel DUALEHITEL-PC PageOpen LaunchDialog
2013/10/7:18:03:11 Dual Ehitel DUALEHITEL-PC PageOpen LicenseDialog
2013/10/7:18:03:14 Dual Ehitel DUALEHITEL-PC PageOpen ProductInfoDialog
2013/10/7:18:04:12 Dual Ehitel DUALEHITEL-PC PageOpen ProductSelectionDialog2
2013/10/7:18:27:12 Dual Ehitel DUALEHITEL-PC PageOpen FullProgressDialog
2013/10/7:18:27:12 Dual Ehitel DUALEHITEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\DUALEH~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/10/7:18:27:46 Dual Ehitel DUALEHITEL-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/10/7:18:27:50 Dual Ehitel DUALEHITEL-PC PageOpen InstallCompleteDialog
2013/10/7:18:31:32 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:18:35:12 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:18:35:12 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:18:35:12 Dual Ehitel DUALEHITEL-PC Current Directory K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014
2013/10/7:18:35:12 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:18:35:12 Dual Ehitel DUALEHITEL-PC CommandLine
2013/10/7:18:35:12 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AI691F.tmp
2013/10/7:18:35:18 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:18:35:13 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:18:35:13 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:18:35:13 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AI691F.tmp
2013/10/7:18:35:13 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:18:35:14 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\DUALEH~1\AppData\Local\Temp\_AI691F.tmp\Setup\RevitSetup.dll
2013/10/7:18:35:14 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/7:18:35:18 Dual Ehitel DUALEHITEL-PC PageOpen LaunchDialog
2013/10/7:18:35:19 Dual Ehitel DUALEHITEL-PC PageOpen LicenseDialog
2013/10/7:18:35:21 Dual Ehitel DUALEHITEL-PC PageOpen ProductInfoDialog
2013/10/7:18:37:26 Dual Ehitel DUALEHITEL-PC PageOpen ProductSelectionDialog2
2013/10/7:18:37:47 Dual Ehitel DUALEHITEL-PC PageOpen FullProgressDialog
2013/10/7:18:37:47 Dual Ehitel DUALEHITEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\DUALEH~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/10/7:18:38:13 Dual Ehitel DUALEHITEL-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/10/7:18:38:17 Dual Ehitel DUALEHITEL-PC PageOpen InstallCompleteDialog
2013/10/7:19:32:26 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:19:32:42 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:19:32:42 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:19:32:42 Dual Ehitel DUALEHITEL-PC Current Directory K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014
2013/10/7:19:32:42 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:19:32:42 Dual Ehitel DUALEHITEL-PC CommandLine
2013/10/7:19:32:42 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AICCE.tmp
2013/10/7:19:32:49 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:19:32:43 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:19:32:43 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:19:32:43 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AICCE.tmp
2013/10/7:19:32:43 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:19:32:44 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\DUALEH~1\AppData\Local\Temp\_AICCE.tmp\Setup\RevitSetup.dll
2013/10/7:19:32:44 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/7:19:32:49 Dual Ehitel DUALEHITEL-PC PageOpen LaunchDialog
2013/10/7:19:33:26 Dual Ehitel DUALEHITEL-PC PageOpen LicenseDialog
2013/10/7:19:33:29 Dual Ehitel DUALEHITEL-PC PageOpen ProductInfoDialog
2013/10/7:19:37:22 Dual Ehitel DUALEHITEL-PC PageOpen ProductSelectionDialog2
2013/10/7:19:48:37 Dual Ehitel DUALEHITEL-PC PageOpen FullProgressDialog
2013/10/7:19:48:38 Dual Ehitel DUALEHITEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\DUALEH~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/10/7:19:49:03 Dual Ehitel DUALEHITEL-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/10/7:19:49:08 Dual Ehitel DUALEHITEL-PC PageOpen InstallCompleteDialog
2013/10/7:19:53:42 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:19:54:10 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:19:54:10 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:19:54:10 Dual Ehitel DUALEHITEL-PC Current Directory K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014
2013/10/7:19:54:10 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:19:54:10 Dual Ehitel DUALEHITEL-PC CommandLine
2013/10/7:19:54:10 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AIB3D6.tmp
2013/10/7:19:54:18 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:19:54:12 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:19:54:12 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:19:54:12 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AIB3D6.tmp
2013/10/7:19:54:12 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:19:54:13 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\DUALEH~1\AppData\Local\Temp\_AIB3D6.tmp\Setup\RevitSetup.dll
2013/10/7:19:54:13 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/7:19:54:18 Dual Ehitel DUALEHITEL-PC PageOpen LaunchDialog
2013/10/7:19:56:22 Dual Ehitel DUALEHITEL-PC PageOpen LicenseDialog
2013/10/7:19:56:25 Dual Ehitel DUALEHITEL-PC PageOpen ProductInfoDialog
2013/10/7:19:57:21 Dual Ehitel DUALEHITEL-PC PageOpen ProductSelectionDialog2
2013/10/7:19:58:18 Dual Ehitel DUALEHITEL-PC PageOpen FullProgressDialog
2013/10/7:19:58:18 Dual Ehitel DUALEHITEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe"
2013/10/7:19:58:26 Dual Ehitel DUALEHITEL-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2013/10/7:19:58:26 Dual Ehitel DUALEHITEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\DUALEH~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/10/7:19:58:52 Dual Ehitel DUALEHITEL-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/10/7:19:58:52 Dual Ehitel DUALEHITEL-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2013/10/7:19:59:00 Dual Ehitel DUALEHITEL-PC PageOpen InstallCompleteDialog
2013/10/7:19:59:16 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:19:59:21 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:19:59:21 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:19:59:21 Dual Ehitel DUALEHITEL-PC Current Directory K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014
2013/10/7:19:59:21 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:19:59:21 Dual Ehitel DUALEHITEL-PC CommandLine
2013/10/7:19:59:21 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AI7273.tmp
2013/10/7:19:59:29 Dual Ehitel DUALEHITEL-PC === Setup ended ===
2013/10/7:19:59:24 Dual Ehitel DUALEHITEL-PC === Setup started on DUALEHITEL-PC by Dual Ehitel ===
2013/10/7:19:59:24 Dual Ehitel DUALEHITEL-PC Path_Length: 149
2013/10/7:19:59:24 Dual Ehitel DUALEHITEL-PC Current Directory C:\Users\DUALEH~1\AppData\Local\Temp\_AI7273.tmp
2013/10/7:19:59:24 Dual Ehitel DUALEHITEL-PC Launch
2013/10/7:19:59:25 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\DUALEH~1\AppData\Local\Temp\_AI7273.tmp\Setup\RevitSetup.dll
2013/10/7:19:59:25 Dual Ehitel DUALEHITEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/7:19:59:30 Dual Ehitel DUALEHITEL-PC PageOpen LaunchDialog
2013/10/7:19:59:40 Dual Ehitel DUALEHITEL-PC PageOpen LicenseDialog
2013/10/7:19:59:43 Dual Ehitel DUALEHITEL-PC PageOpen ProductInfoDialog
2013/10/7:20:00:22 Dual Ehitel DUALEHITEL-PC PageOpen ProductSelectionDialog2
2013/10/7:20:01:36 Dual Ehitel DUALEHITEL-PC PageOpen FullProgressDialog
2013/10/7:20:01:37 Dual Ehitel DUALEHITEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "K:\Descargas\AUTODESK REVIT ARCHITECTURE V2014-ISO\rac2014\rac2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe"
2013/10/7:20:01:46 Dual Ehitel DUALEHITEL-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=-2147023673
Message 10 of 12
pendean
1. This is not a REVIT forum.
2. There is an Installation forum where you might want to post instead:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
3. Search that Installation forum first: there are many Error 1603 topics.
Message 11 of 12
I've been a month looking for this answer.
It really worked, thank you :))
Tags (2)
Message 12 of 12
i found the culprit to be a half installed inventor
Administrator Productivity
