I have used eagle-9.3.0 successfully with nvidia drivers on a 4K monitor. After changing to a new monitor with 5120 x 1440, eagle fails to start:
Sandboxing disabled by user.
[5382:5397:0706/121010.097688:ERROR:nss_util.cc(808)] After loading Root Certs, loaded==false: NSS error code: -8018
after this message, the command hangs for ~2 minutes, then it shows a lot of messages starting with
Qpainter:: ...
finally, it quits after showing this message:
The X11 connection broke: Maximum allowed requested length exceeded (code 4)
XIO: fatal IO error 0 (Erfolg) on X server ":1"
after 598 requests (594 known processed) with 0 events remaining.
[5405:5405:0100/000000.333530:ERROR:broker_posix.cc(41)] Invalid node channel message
When I change to a lower resolution (2560x1440) eagle starts up. This is not usable, however, because the display is scaled 2:1. The same thing happens with eagle-9.6.2.
