Dynamoplayer.exe will not install = revit 2022 deployment failure
mframpton20
mframpton20
Dynamoplayer.exe will not install = revit 2022 deployment failure.. thoughts solutions. File clearly not in the folder  deployment folder as dowloaded today from autodesk.Screenshot 2021-05-18 204748.jpg error 1.jpgScreenshot 2021-05-18 204748.jpg error 2.jpg
m_latz
The dynamoplayer.exe file should be in the "resource"-folder:
...\Revit_2022_G1_Win_64bit_dlm\x64\RVT\PF64\Autodesk\Root\AddIns\DynamoPlayer\resource\dynamoplayer.exe
Can you look there please ?
regards
Markus
mframpton20
mframpton20
I tried downloading this deployment twice now and I can't get past this issue unfortunately. Same issue each time.
m_latz
Hhm, I created a deployment for Revit 2022 two weeks ago and the dynamoplayer.exe is contained:
May be your virus scanner gets a "positive false", check your quarantined files.
regards
Markus
mframpton20
Yup virus scanner caught it thanks!
