Spent 2 days trying to install 3ds Max.
I am getting same error every time:
InstallAutodesk® Populate Data for 3ds Max 2014FailedDownload Failed, Installation aborted, Result=1603
I tried to uninstall C++
I tried to download instead of istall and it does not work for me with message "Connection lost"
Solved by Darin.Green. Go to Solution.
Instead of choosing the Install option for downloading, you should choose "Download Now". The problem you're facing is the installer is still reaching out to the web for downloading the additional files based on your application selection and there could be an issue on your network preventing this from happening smoothly.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
try downloading from here:
http://autodesk.creativevirtual.com/autodesk/bot.htm?isJSEnabled=1&sitecontext=FRONTDESK
downloading and installation>software Download links>i need to redownload my product>3ds max product>
DarrenP
Well, I tried that option too and got Lost Connection message every time even before anything got downloaded.
Fortunately, I was able to start a download process this time and it's in a progress. Let's see how it goes...
Try downloading from here
http://knowledge.autodesk.com/topics/account-management/software-downloads/download-methods/virtual-...
Please accept as a solution if this fully resolves the issue
DarrenP
