With the exception of the 2021 version, download links in the webpage "Download Autodesk Navisworks NWC File Export Utility" aren't working... I need the 2019 version
Solved by jrobrador19. Go to Solution.
Hi there,
I reached out to Autodesk Support, because I also cannot download from the website. I was advised to use a different browser. I'm currently using the new Microsoft Edge which is also chromium based like Google Chrome. So I tried to download using my Internet Explorer and it works!
Kudos to Autodesk Live Chat support.
I hope this helps.
Please hit the ACCEPT SOLUTION or LIKE button if my post helped you to solve your problem.
Jerous Obrador
Mechanical Engineer| LinkedIn | Autodesk Certified Instructor | Revit Architecture Certified Professional | Revit MEP: Mechanical Certified Professional | Revit MEP: Electrical Certified Professional | Inventor Certified Professional | Laguna, Philippines
Win 10 Pro / Dell G7 7590 / i7-9750H / 16GB RAM / NVIDIA GeForce RTX 2060
Try this link: https://efulfillment.autodesk.com/NetSWDLD/2019/PLC0000012/652E49E4-E42A-4629-8012-ED929DB85C88/SFX/...
Try using this link on other browsers like Firefox or Safari. You can also try to clear the cookies and cached files of your local browser then try again.
I hope this helps.
Jerous Obrador
@CharlesGoin wrote:
WHY is the exporter not BUILT INTO REVIT !
Seriously Autodesk..
No one here is Autodesk Revit team, but you can ask Autodesk over there, that forum exists right there just so you could ask/tell Autodesk whatever you want https://forums.autodesk.com/t5/revit-ideas/idb-p/302
