Installation & Licensing
Deployment to a Technology ICT Suite
5 REPLIES 5
572 Views, 5 Replies
Hi There,
We are looking to deploy Autodesk Inventor 2015 to a suite of computers (20 in total) - and possibly some high-end laptops too.
I was just wondering if you have a guide available or if someone can point me in the right direction towards doing a mass-deployment?
I'm failing to see any pre-made MSI's/ADMX templates etc - do I have to repackage your software in order to do a network deployment via group policy?
I'm surprised this isn't under the FAQ!
5 REPLIES 5
dgorsman
Part of the install options is to create a network deployment.  This should be covered in the Installation Guide.
in reply to: dgorsman
From what I found there wasn't much information on this at all.
Does it literally create the MSIs for you?
Can you point me in the direction of the manual you are referring to please?
In the process of trying to download the full installer (what a nightmare); the download consistantly fails mid-way through.
I've had to use a 3rd party download manager to get the file in it's complete state - only to see the same error as many others complaining that it is an 'incomplete' setup file.
Here are the direct download links to Autodesk Inventor 2015 Professional (BOTH files).
http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/DLM/Autodesk_Inventor_2015_English_Win_64bit_dlm_0...
Once I've fumbled through the network deployment I shall report back.
Hello How did you get on installing the application? I am struggling on our Vanilla network no help or advice from anywhere. I have a teacher that wants to use the product. all and any advice is welcomed!
m_latz
Under this link you can find informations about the network deployment:
http://help.autodesk.com/view/INSTALL_LICENSE/2015/ENU/?guid=GUID-3F604C34-6A58-4E84-BB15-38651CFB30...
When you have created the deployment you can also modify for your special case. All is "readable" through a setup.ini file.
regards
Markus
Administrator Productivity
