Catalog file Afields.fdc and Shapes.atc not found on launch AUTOCAD2016 and 2018
Issue occurring on AutoCad Architecture 2016 and 2018 on Citrix VDI while using Windows Roaming Profile & Folder  Redirection (Same as windows Roaming Profile) on Citrix Xendesktop 7.15 LTSR, Windows 10  version 1803.
Please see the error attached below.
manually copying the Shapes.atc and Acfields.fdc from C:\program Files\Autodesk\Autocad 2018\UserDataCache\Support works and is a good Workaround but definately not Fix. There has to be a better solution to manually copying the files. is there any option inside the Autocad application to set a common location to look for these two catalog files (similar to Support Files directory location)? if yes how to set a common location for all users to look for these two catalog files to a common location?
Your thoughts and inputs are greatly appreciated.
Thanks!!
natasha.l
Hello @Anonymous,
Thank you for posting.
Many Autodesk products do not support restricted or roaming users even in the default, out-of-box configuration. Please review the Unable to run AutoCAD as a restricted user.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
natasha.l
Hello @Anonymous,
Just checking in with you, hope you were able to resolve this.
