Hi guys. I´ve deinstalled 3ds max because i had some issues with it.
Now i want to reinstall this programm but it is not possible to click on the install button.
How can i fix that?
How can i fix that?
Hi @Anonymous
I looks like it still thinks 3ds Max 2019 is still installed. Could you try uninstalling it using the Autodesk Uninstall Tool?
Hi @Anonymous
@Anonymous
I would recommend that you perform a clean uninstall per these instructions. In addition make sure to use the Microsoft Fixit tool as indicated in that article. NOTE: The information within the article is solely based on you performing a clean uninstall of all "core" Autodesk products on your machine. In certain situations, you will most likely not be removing all of your Autodesk products to resolve a given issue. If that's the case, you'll need to adjust those settings and locations within the article to make sure you are not impacting those other Autodesk products you plan on leaving on your machine.
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
Mark Lancaster
