Cannot Install Autocad LT2023
DTMEngineering
Message 1 of 26
DTMEngineering
cannot installa Autocad LT2023 update.
Replies (25)
Message 2 of 26
mdavis22569
Make sure you have all of the Windows updates installed and meet the requirements
From there go to AVA ( Autodesk Virtual Agent) and download it
www.ava.autodesk.com
Get the browser download
If the doesn't work, try reinstalling the C++ / .NET
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-remove-and-reinst...
Mike Davis
Message 3 of 26
DTMEngineering
WorkStation Prerfectly Updated
Message 4 of 26
mdavis22569
Can we look at my other suggestions then ..
let's not use the Desktop app, but rather AVA and the browser method
Mike Davis
Message 5 of 26
DTMEngineering
ava link doesnt work
Message 6 of 26
DTMEngineering
used browser download: it doesnt. work
Message 7 of 26
DTMEngineering
cannot install: i've triewd to install several times.
Message 8 of 26
mdavis22569
Can you try this English Installer?
https://efulfillment.autodesk.com/NetSWDLD/2023/ACDLT/C8DC0A93-1BFB-3C0D-B3B6-1BD06D06CCC2/SFX/AutoC...
We can get the language pack for it if needed. I want to see if it could be the installer is an issue for you
Mike Davis
Message 9 of 26
DTMEngineering
Ok, I try ASAP. AS per info: this is the current Autocad Installed Files list: I've already removed Revit LT2023 (please NOTE i'VE PURCHASED Revit LT Suite where Autocad LT is included.) in ordwer to have a clean installation.
Message 10 of 26
DTMEngineering
it doesnt work even in English.
Message 11 of 26
mdavis22569
Going to go with it being something PC related.    AutoCAD and AutoCAD LT have been out for over a month and I'm not seeing this get report else where.  Not hearing of a language specific issue currently either.
Mike Davis
Message 12 of 26
DTMEngineering
replaced .NT framework and Visual C++XX. Downloaded by browser.
now the new message is as follows
Message 13 of 26
mdavis22569
for the click here how to resolve... what is it telling you for the issue?
Mike Davis
Message 14 of 26
mdavis22569
Have you seen the following AKN article about this:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Troubl...
Mike Davis
Message 15 of 26
DTMEngineering
Yes, already seen. Updated PC Operating System, (Win 11 Pro last release) the installation fails again with the same message.
Message 16 of 26
mdavis22569
Natasha any way to get this rerouted up.  I'm seeing quite a few of these tickets over the last few days.
@DTMEngineering
I would put in a support ticket about this:
https://knowledge.autodesk.com/contact-support
Mike Davis
Message 17 of 26
mdavis22569
@DTMEngineering
What OS are you on?
Mike Davis
Message 18 of 26
DTMEngineering
Hi. OS: Windows 11 Pro.
Message 19 of 26
mdavis22569
https://knowledge.autodesk.com/community/article/400081
Mike Davis
Message 20 of 26
DTMEngineering
thanks for your support. in the meantime i uninstalled all autodesk software, trying to do a clean uninstall
Now I'm ready to install Revit LT Suite (including Autocad) and FUsion 360
