Cannot Create Directory
emil4587D
Observer Observer
emil4587D
Observer
Observer
First off. Im new to the forum. Sorry if there's already a post about this. But I couldn't find one.
When I instal DWG TrueView on a local user. that is not local administrator.
I get the error message Down below
It doesnt matter if I install it as local admin. Even if I manage to open the program on the local user after that.
I am met with a blank start window. And when I wanna locate my DWG files I only see the administrators side of the explorer. And cannot navigate to the local user. I've tried the CMD command:
REG DELETE "HKLM\SOFTWARE\Autodesk\DWG TrueView\R21\dwgviewr-6101:409\UserData" /v {28B89EEF-6128-0409-0100-CF3F3A09B77D} /f
REG ADD "HKLM\SOFTWARE\Autodesk\DWG TrueView\R21\dwgviewr-6101:409\UserData" /v {CDE988A0-A926-4610-A1F3-DDA8F1312B0B} /t REG_SZ /d "Software\Autodesk\DWG TrueView\R21\dwgviewr-6101:409" /f
This only made the problem worse. Now I cant even install DWG TrueView again...
I know the 2022 version works on another user. But couldn't find that version on Autodesks site.
Please help me!!
Best regards,
Emil
Simon_Weel
Looks like DWG TrueView. It tries to load the configuration for the administrator, for which it doesn't have access permissions. To remedy this, you should delete a different registry key, namely the one for the current user:
reg delete "hkcu\Software\Autodesk\DWG TrueView\R21" /f
I don't have TrueView at hand, so check the registry if this key is the correct one.
emil4587D
Observer
Observer
Will try this!
I´ll update you on how it goes!
Thanks in the meantime!
emil4587D
Observer
Observer
Hey!
I found an installer for DWG TrueViewer 2022 on another users computer.
I installed that. It worked without issues.
Im gonna let the issue of the 2023 version go unsolved!
Thanks anyways
mdavis22569
@emil4587D
Can you review the following
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Unable...
Reinstall  the Edge WebView 2:
Corrupted Microsoft Edge WebView2 Runtime component
  • For Windows 10:
  1. In Control Panel, uninstall the Microsoft Edge WebView2 Runtime component.
  2. Download and install the latest version of the component from Microsoft:
  1. Launch AutoCAD.
  • For Windows 11, this component cannot be uninstalled through Control Panel.
  1. Using "Run as Administrator" launch Command Prompt and enter the following command:
  2. "C:\Program Files (x86)\Microsoft\EdgeWebView\Application\105.0.1343.53\Installer\setup.exe" --uninstall --msedgewebview --system-level --verbose-logging --force-uninstall
  3. Download and install the latest version of the component from Microsoft: WebView2 - Microsoft Edge Developer.
  4. Launch AutoCAD.
Mike Davis
