I'm trying to install Revit and the installer aborts about 40% through the install process. I've tried on multiple machines with 2025 and 2024 with same issue. Any help would be appreciated.
Here's the install log
2024-06-05T16:43:06.460 [Autodesk ATF for Revit 2024 Install.log INFO] ======================== Start Autodesk ATF for Revit 2024 Install.log ========================
2024-06-05T16:43:06.460 [Autodesk ATF for Revit 2024 Install.log INFO] session-id: 9709c9ad-ffab-4e58-b564-2bfe4493289a
2024-06-05T16:43:06.460 [Autodesk ATF for Revit 2024 Install.log INFO] upi2: {DFFCD732-070F-3226-8785-CA5947C54218}
2024-06-05T16:43:06.460 [Autodesk ATF for Revit 2024 Install.log INFO] ==================================================================
2024-06-05T16:43:06.465 [Autodesk ATF for Revit 2024 Install.log INFO] [ AdIXHandler::IsInstalled ] Current package does not exist {DFFCD732-070F-3226-8785-CA5947C54218}
