I can't install Maya 2015. I had it installed for some time and wanted to use it recently but there was an error. I decided to reinstall it, but now it won't do that. The 2016 works fine, but I want the 2015 cause we learned how to use this version and 2016 is quite different than 2015. I made sure everything is uninstalled using a Microsoft tool called "Fix It", I disabled all anti virus programs and the Windows firewall and I launched the installer as admin. Here is my log:
2016/1/19:19:58:11 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/19:19:58:11 Dario DARIO-PC Path_Length: 143
2016/1/19:19:58:11 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/19:19:58:11 Dario DARIO-PC Launch
2016/1/19:19:58:11 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/19:19:58:11 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI14EA.tmp
2016/1/19:19:59:05 Dario DARIO-PC === Setup ended ===
2016/1/19:19:58:14 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/19:19:58:14 Dario DARIO-PC Path_Length: 143
2016/1/19:19:58:14 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI14EA.tmp
2016/1/19:19:58:14 Dario DARIO-PC Launch
2016/1/19:19:59:05 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/19:19:59:05 Dario DARIO-PC PageOpen LaunchDialog
2016/1/19:20:00:13 Dario DARIO-PC PageOpen LicenseDialog
2016/1/19:20:00:13 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/19:20:00:30 Dario DARIO-PC PageOpen FullProgressDialog
2016/1/19:20:00:30 Dario DARIO-PC Installing Network License Manager: INSTALLDIR="G:\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Maya 2015" SETUP_PACKAGECODE={1A5DD79A-51E4-43EF-90D1-F6751239AF6E} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2015" INSTALLDIR="C:\Program Files\Autodesk Network License Manager\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/1/19:20:00:31 Dario DARIO-PC Install Network License Manager Succeeded
2016/1/19:20:00:31 Dario DARIO-PC PageOpen InstallCompleteDialog
2016/1/19:20:00:37 Dario DARIO-PC === Setup ended ===
2016/1/19:20:03:53 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/19:20:03:53 Dario DARIO-PC Path_Length: 143
2016/1/19:20:03:53 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/19:20:03:53 Dario DARIO-PC Launch
2016/1/19:20:03:53 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/19:20:03:53 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI4C2F.tmp
2016/1/19:20:03:57 Dario DARIO-PC === Setup ended ===
2016/1/19:20:03:56 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/19:20:03:56 Dario DARIO-PC Path_Length: 143
2016/1/19:20:03:56 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI4C2F.tmp
2016/1/19:20:03:56 Dario DARIO-PC Launch
2016/1/19:20:03:56 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/19:20:03:57 Dario DARIO-PC PageOpen LaunchDialog
2016/1/19:20:04:09 Dario DARIO-PC PageOpen LicenseDialog
2016/1/19:20:04:09 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/19:20:04:19 Dario DARIO-PC PageOpen LicenseDialog
2016/1/19:20:04:19 Dario DARIO-PC PageOpen LaunchDialog
2016/1/19:20:04:21 Dario DARIO-PC PageOpen LicenseDialog
2016/1/19:20:04:21 Dario DARIO-PC PageOpen ProductInfoDialog
2016/1/19:20:04:21 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/19:20:04:32 Dario DARIO-PC PageOpen FullProgressDialog
2016/1/19:20:04:32 Dario DARIO-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/19:20:04:32 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/1/19:20:04:47 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/1/19:20:04:47 Dario DARIO-PC Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/19:20:04:47 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/1/19:20:04:47 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=2
2016/1/19:20:04:47 Dario DARIO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/1/19:20:04:47 Dario DARIO-PC PageOpen InstallCompleteDialog
2016/1/19:20:05:06 Dario DARIO-PC === Setup ended ===
2016/1/19:20:29:23 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/19:20:29:23 Dario DARIO-PC Path_Length: 143
2016/1/19:20:29:23 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/19:20:29:23 Dario DARIO-PC Launch
2016/1/19:20:29:23 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/19:20:29:23 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AIA4BB.tmp
2016/1/19:20:29:27 Dario DARIO-PC === Setup ended ===
2016/1/19:20:29:26 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/19:20:29:26 Dario DARIO-PC Path_Length: 143
2016/1/19:20:29:26 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AIA4BB.tmp
2016/1/19:20:29:26 Dario DARIO-PC Launch
2016/1/19:20:29:27 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/19:20:29:27 Dario DARIO-PC PageOpen LaunchDialog
2016/1/19:20:29:30 Dario DARIO-PC PageOpen LicenseDialog
2016/1/19:20:29:30 Dario DARIO-PC PageOpen ProductInfoDialog
2016/1/19:20:29:30 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/19:20:29:51 Dario DARIO-PC PageOpen FullProgressDialog
2016/1/19:20:29:51 Dario DARIO-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/19:20:29:52 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/1/19:20:30:09 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/1/19:20:30:09 Dario DARIO-PC Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/19:20:30:09 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/1/19:20:30:09 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=2
2016/1/19:20:30:09 Dario DARIO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/1/19:20:30:09 Dario DARIO-PC PageOpen InstallCompleteDialog
2016/1/19:20:33:17 Dario DARIO-PC === Setup ended ===
2016/1/19:20:33:32 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/19:20:33:32 Dario DARIO-PC Path_Length: 143
2016/1/19:20:33:32 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/19:20:33:32 Dario DARIO-PC Launch
2016/1/19:20:33:32 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/19:20:33:32 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI716C.tmp
2016/1/19:20:33:36 Dario DARIO-PC === Setup ended ===
2016/1/19:20:33:35 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/19:20:33:35 Dario DARIO-PC Path_Length: 143
2016/1/19:20:33:35 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI716C.tmp
2016/1/19:20:33:35 Dario DARIO-PC Launch
2016/1/19:20:33:35 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/19:20:33:36 Dario DARIO-PC PageOpen LaunchDialog
2016/1/19:20:33:40 Dario DARIO-PC PageOpen LicenseDialog
2016/1/19:20:33:40 Dario DARIO-PC PageOpen ProductInfoDialog
2016/1/19:20:33:40 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/19:20:34:23 Dario DARIO-PC PageOpen FullProgressDialog
2016/1/19:20:34:23 Dario DARIO-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/19:20:34:23 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/1/19:20:34:31 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/1/19:20:34:31 Dario DARIO-PC Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/19:20:34:31 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/1/19:20:34:31 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=2
2016/1/19:20:34:31 Dario DARIO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/1/19:20:34:31 Dario DARIO-PC PageOpen InstallCompleteDialog
2016/1/19:20:34:39 Dario DARIO-PC === Setup ended ===
2016/1/19:20:35:19 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/19:20:35:19 Dario DARIO-PC Path_Length: 143
2016/1/19:20:35:19 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/19:20:35:19 Dario DARIO-PC Launch
2016/1/19:20:35:19 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/19:20:35:19 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI12E8.tmp
2016/1/19:20:35:20 Dario DARIO-PC === Setup ended ===
2016/1/19:20:35:19 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/19:20:35:19 Dario DARIO-PC PageOpen LaunchDialog
2016/1/19:20:35:21 Dario DARIO-PC PageOpen LicenseDialog
2016/1/19:20:35:21 Dario DARIO-PC PageOpen ProductInfoDialog
2016/1/19:20:35:21 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/19:20:35:32 Dario DARIO-PC PageOpen FullProgressDialog
2016/1/19:20:35:32 Dario DARIO-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/19:20:35:32 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/1/19:20:35:39 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/1/19:20:35:39 Dario DARIO-PC Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/19:20:35:39 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/1/19:20:35:39 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=2
2016/1/19:20:35:39 Dario DARIO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/1/19:20:35:39 Dario DARIO-PC PageOpen InstallCompleteDialog
2016/1/19:20:36:08 Dario DARIO-PC === Setup ended ===
2016/1/19:20:39:08 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/19:20:39:08 Dario DARIO-PC Path_Length: 143
2016/1/19:20:39:08 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/19:20:39:08 Dario DARIO-PC Launch
2016/1/19:20:39:08 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/19:20:39:08 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI9408.tmp
2016/1/19:20:39:09 Dario DARIO-PC === Setup ended ===
2016/1/19:20:39:09 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/19:20:39:09 Dario DARIO-PC Path_Length: 143
2016/1/19:20:39:09 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI9408.tmp
2016/1/19:20:39:09 Dario DARIO-PC Launch
2016/1/19:20:39:09 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/19:20:39:09 Dario DARIO-PC PageOpen LaunchDialog
2016/1/19:20:39:11 Dario DARIO-PC PageOpen LicenseDialog
2016/1/19:20:39:11 Dario DARIO-PC PageOpen ProductInfoDialog
2016/1/19:20:39:11 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/19:20:39:20 Dario DARIO-PC PageOpen FullProgressDialog
2016/1/19:20:39:21 Dario DARIO-PC Download Skipped MENTALRAYPLUGIN http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/MENTALRAY...
2016/1/19:20:39:21 Dario DARIO-PC Installing mental ray® renderer for Autodesk® Maya® 2015: TRANSFORMS="C:\Users\Dario\AppData\Local\Temp\_AI9408.tmp\x64\MentalRayPlugIn\MentalRayPlugIn2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2015" INSTALLDIR="G:\Maya\mentalrayForMaya2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/1/19:20:39:39 Dario DARIO-PC Install mental ray® renderer for Autodesk® Maya® 2015 Failed Failure is ignored, Result=1603
2016/1/19:20:39:39 Dario DARIO-PC Install mental ray® renderer for Autodesk® Maya® 2015 SP2 Succeeded
2016/1/19:20:39:39 Dario DARIO-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/19:20:39:39 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/1/19:20:39:46 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/1/19:20:39:47 Dario DARIO-PC Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/19:20:39:47 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/1/19:20:39:47 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=2
2016/1/19:20:39:47 Dario DARIO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/1/19:20:39:47 Dario DARIO-PC Rollback mental ray® renderer for Autodesk® Maya® 2015 SP2 Failed Installation aborted, Result=1619
2016/1/19:20:39:47 Dario DARIO-PC PageOpen InstallCompleteDialog
2016/1/19:20:40:28 Dario DARIO-PC === Setup ended ===
2016/1/19:20:44:03 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/19:20:44:03 Dario DARIO-PC Path_Length: 143
2016/1/19:20:44:03 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/19:20:44:03 Dario DARIO-PC Launch
2016/1/19:20:44:03 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/19:20:44:03 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI14CC.tmp
2016/1/19:20:44:04 Dario DARIO-PC === Setup ended ===
2016/1/19:20:44:04 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/19:20:44:04 Dario DARIO-PC Path_Length: 143
2016/1/19:20:44:04 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI14CC.tmp
2016/1/19:20:44:04 Dario DARIO-PC Launch
2016/1/19:20:44:04 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/19:20:44:04 Dario DARIO-PC PageOpen LaunchDialog
2016/1/19:20:44:06 Dario DARIO-PC PageOpen LicenseDialog
2016/1/19:20:44:06 Dario DARIO-PC PageOpen ProductInfoDialog
2016/1/19:20:44:06 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/19:20:44:34 Dario DARIO-PC PageOpen FullProgressDialog
2016/1/19:20:44:34 Dario DARIO-PC Download Skipped MENTALRAYPLUGIN http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/MENTALRAY...
2016/1/19:20:44:34 Dario DARIO-PC Installing mental ray® renderer for Autodesk® Maya® 2015: TRANSFORMS="C:\Users\Dario\AppData\Local\Temp\_AI14CC.tmp\x64\MentalRayPlugIn\MentalRayPlugIn2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2015" INSTALLDIR="C:\Program Files\Autodesk\mentalrayForMaya2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/1/19:20:47:59 Dario DARIO-PC Install mental ray® renderer for Autodesk® Maya® 2015 Failed Failure is ignored, Result=1603
2016/1/19:20:47:59 Dario DARIO-PC Install mental ray® renderer for Autodesk® Maya® 2015 SP2 Succeeded
2016/1/19:20:47:59 Dario DARIO-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/19:20:47:59 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/1/19:20:48:07 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/1/19:20:48:09 Dario DARIO-PC PageOpen InstallCompleteDialog
2016/1/19:20:48:11 Dario DARIO-PC === Setup ended ===
2016/1/20:14:55:34 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:14:55:34 Dario DARIO-PC Path_Length: 143
2016/1/20:14:55:34 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/20:14:55:34 Dario DARIO-PC Launch
2016/1/20:14:55:34 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/20:14:55:34 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI5698.tmp
2016/1/20:14:55:38 Dario DARIO-PC === Setup ended ===
2016/1/20:14:55:37 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:14:55:37 Dario DARIO-PC Path_Length: 143
2016/1/20:14:55:37 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI5698.tmp
2016/1/20:14:55:37 Dario DARIO-PC Launch
2016/1/20:14:55:37 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/20:14:55:37 Dario DARIO-PC PageOpen LaunchDialog
2016/1/20:14:55:43 Dario DARIO-PC PageOpen LicenseDialog
2016/1/20:14:55:43 Dario DARIO-PC PageOpen ProductInfoDialog
2016/1/20:14:55:43 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/20:14:56:34 Dario DARIO-PC PageOpen FullProgressDialog
2016/1/20:14:56:34 Dario DARIO-PC Download Skipped MENTALRAYPLUGIN http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/MENTALRAY...
2016/1/20:14:56:35 Dario DARIO-PC Installing mental ray® renderer for Autodesk® Maya® 2015: TRANSFORMS="C:\Users\Dario\AppData\Local\Temp\_AI5698.tmp\x64\MentalRayPlugIn\MentalRayPlugIn2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2015" INSTALLDIR="G:\Maya\mentalrayForMaya2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/1/20:14:56:47 Dario DARIO-PC Install mental ray® renderer for Autodesk® Maya® 2015 Failed Failure is ignored, Result=1603
2016/1/20:14:56:47 Dario DARIO-PC Install mental ray® renderer for Autodesk® Maya® 2015 SP2 Succeeded
2016/1/20:14:56:47 Dario DARIO-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/20:14:56:47 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/1/20:14:57:20 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/1/20:14:57:24 Dario DARIO-PC PageOpen InstallCompleteDialog
2016/1/20:14:57:29 Dario DARIO-PC === Setup ended ===
2016/1/20:15:02:11 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:15:02:11 Dario DARIO-PC Path_Length: 143
2016/1/20:15:02:11 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/20:15:02:11 Dario DARIO-PC Launch
2016/1/20:15:02:11 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/20:15:02:11 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI6835.tmp
2016/1/20:15:02:15 Dario DARIO-PC === Setup ended ===
2016/1/20:15:02:14 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:15:02:14 Dario DARIO-PC Path_Length: 143
2016/1/20:15:02:14 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI6835.tmp
2016/1/20:15:02:14 Dario DARIO-PC Launch
2016/1/20:15:02:15 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/20:15:02:15 Dario DARIO-PC PageOpen LaunchDialog
2016/1/20:15:02:21 Dario DARIO-PC PageOpen LicenseDialog
2016/1/20:15:02:21 Dario DARIO-PC PageOpen ProductInfoDialog
2016/1/20:15:02:21 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/20:15:02:31 Dario DARIO-PC PageOpen FullProgressDialog
2016/1/20:15:02:31 Dario DARIO-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/20:15:02:31 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/1/20:15:02:39 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/1/20:15:02:39 Dario DARIO-PC Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/20:15:02:39 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/1/20:15:02:39 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=2
2016/1/20:15:02:39 Dario DARIO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/1/20:15:02:39 Dario DARIO-PC PageOpen InstallCompleteDialog
2016/1/20:15:02:47 Dario DARIO-PC === Setup ended ===
2016/1/20:15:08:22 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:15:08:22 Dario DARIO-PC Path_Length: 143
2016/1/20:15:08:22 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/20:15:08:22 Dario DARIO-PC Launch
2016/1/20:15:08:22 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/20:15:08:22 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI114F.tmp
2016/1/20:15:08:26 Dario DARIO-PC === Setup ended ===
2016/1/20:15:08:25 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:15:08:25 Dario DARIO-PC Path_Length: 143
2016/1/20:15:08:25 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI114F.tmp
2016/1/20:15:08:25 Dario DARIO-PC Launch
2016/1/20:15:08:26 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/20:15:08:26 Dario DARIO-PC PageOpen LaunchDialog
2016/1/20:15:10:05 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:15:10:05 Dario DARIO-PC Path_Length: 143
2016/1/20:15:10:05 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/20:15:10:05 Dario DARIO-PC Launch
2016/1/20:15:10:05 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/20:15:10:05 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AIA1DB.tmp
2016/1/20:15:10:09 Dario DARIO-PC === Setup ended ===
2016/1/20:15:10:08 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:15:10:08 Dario DARIO-PC Path_Length: 143
2016/1/20:15:10:08 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AIA1DB.tmp
2016/1/20:15:10:08 Dario DARIO-PC Launch
2016/1/20:15:10:09 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/20:15:10:09 Dario DARIO-PC PageOpen LaunchDialog
2016/1/20:15:10:15 Dario DARIO-PC PageOpen LicenseDialog
2016/1/20:15:10:15 Dario DARIO-PC PageOpen ProductInfoDialog
2016/1/20:15:10:15 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/20:15:10:19 Dario DARIO-PC PageOpen FullProgressDialog
2016/1/20:15:10:19 Dario DARIO-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/20:15:10:20 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/1/20:15:10:28 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/1/20:15:10:28 Dario DARIO-PC Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/20:15:10:28 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/1/20:15:10:28 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=2
2016/1/20:15:10:31 Dario DARIO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1618
2016/1/20:15:10:31 Dario DARIO-PC PageOpen InstallCompleteDialog
2016/1/20:15:21:41 Dario DARIO-PC === Setup ended ===
2016/1/20:15:22:13 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:15:22:13 Dario DARIO-PC Path_Length: 143
2016/1/20:15:22:13 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/20:15:22:13 Dario DARIO-PC Launch
2016/1/20:15:22:13 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/20:15:22:13 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AIBF69.tmp
2016/1/20:15:22:14 Dario DARIO-PC === Setup ended ===
2016/1/20:15:22:14 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/20:15:22:14 Dario DARIO-PC PageOpen LaunchDialog
2016/1/20:15:22:18 Dario DARIO-PC PageOpen LicenseDialog
2016/1/20:15:22:18 Dario DARIO-PC PageOpen ProductInfoDialog
2016/1/20:15:22:18 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/20:15:22:25 Dario DARIO-PC PageOpen FullProgressDialog
2016/1/20:15:22:25 Dario DARIO-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/20:15:22:25 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/1/20:15:22:34 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/1/20:15:22:34 Dario DARIO-PC Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/20:15:22:34 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/1/20:15:22:34 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=2
2016/1/20:15:22:37 Dario DARIO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1618
Its failing on the Microsoft Visual C++ 2012 installation. Most likely you have a newer version of it. Uninstall that part and try again.
Mark Lancaster
& Autodesk Services MarketPlace Provider
I should uninstall my newer version of the pack or can I skip the installation of the old one?
"I should uninstall my newer version of the pack or can I skip the installation of the old one?" Newer version of the pack/skip installation of the old one? Not sure what you mean? Are you referring to the C++ stuff I indicated?
Mark Lancaster
I have unsinstalled all c++ 2012 packages but it still doesn't work.
2016/1/20:15:22:38 Dario DARIO-PC PageOpen InstallCompleteDialog
2016/1/20:16:03:20 Dario DARIO-PC === Setup ended ===
2016/1/20:16:03:09 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:16:03:09 Dario DARIO-PC Path_Length: 143
2016/1/20:16:03:09 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/20:16:03:09 Dario DARIO-PC Launch
2016/1/20:16:03:09 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/20:16:03:09 Dario DARIO-PC Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2016/1/20:16:03:13 Dario DARIO-PC Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2016/1/20:16:03:19 Dario DARIO-PC Path_Length: 143
2016/1/20:16:03:19 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI3757.tmp
2016/1/20:16:03:22 Dario DARIO-PC === Setup ended ===
2016/1/20:16:03:22 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:16:03:22 Dario DARIO-PC Path_Length: 143
2016/1/20:16:03:22 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI3757.tmp
2016/1/20:16:03:22 Dario DARIO-PC Launch
2016/1/20:16:03:22 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/20:16:03:22 Dario DARIO-PC PageOpen LaunchDialog
2016/1/20:16:03:30 Dario DARIO-PC PageOpen LicenseDialog
2016/1/20:16:03:30 Dario DARIO-PC PageOpen ProductInfoDialog
2016/1/20:16:03:30 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/20:16:05:13 Dario DARIO-PC === Setup ended ===
2016/1/20:16:05:46 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:16:05:46 Dario DARIO-PC Path_Length: 143
2016/1/20:16:05:46 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/20:16:05:46 Dario DARIO-PC Launch
2016/1/20:16:05:46 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/20:16:05:46 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI9C7F.tmp
2016/1/20:16:05:50 Dario DARIO-PC === Setup ended ===
2016/1/20:16:05:49 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:16:05:49 Dario DARIO-PC Path_Length: 143
2016/1/20:16:05:49 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI9C7F.tmp
2016/1/20:16:05:49 Dario DARIO-PC Launch
2016/1/20:16:05:49 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/20:16:05:49 Dario DARIO-PC PageOpen LaunchDialog
2016/1/20:16:06:05 Dario DARIO-PC PageOpen LicenseDialog
2016/1/20:16:06:05 Dario DARIO-PC PageOpen ProductInfoDialog
2016/1/20:16:06:05 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/20:16:06:16 Dario DARIO-PC PageOpen FullProgressDialog
2016/1/20:16:06:16 Dario DARIO-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/20:16:06:16 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/1/20:16:06:26 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/1/20:16:06:26 Dario DARIO-PC Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/20:16:06:26 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/1/20:16:06:26 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=2
2016/1/20:16:06:26 Dario DARIO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/1/20:16:06:26 Dario DARIO-PC PageOpen InstallCompleteDialog
2016/1/20:16:06:43 Dario DARIO-PC === Setup ended ===
2016/1/20:16:06:58 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:16:06:58 Dario DARIO-PC Path_Length: 143
2016/1/20:16:06:58 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/20:16:06:58 Dario DARIO-PC Launch
2016/1/20:16:06:58 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/20:16:06:58 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AIB5D8.tmp
2016/1/20:16:07:02 Dario DARIO-PC === Setup ended ===
2016/1/20:16:07:01 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:16:07:01 Dario DARIO-PC Path_Length: 143
2016/1/20:16:07:01 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AIB5D8.tmp
2016/1/20:16:07:01 Dario DARIO-PC Launch
2016/1/20:16:07:01 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/20:16:07:01 Dario DARIO-PC PageOpen LaunchDialog
2016/1/20:16:07:39 Dario DARIO-PC PageOpen LicenseDialog
2016/1/20:16:07:39 Dario DARIO-PC PageOpen ProductInfoDialog
2016/1/20:16:07:39 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/20:16:08:04 Dario DARIO-PC === Setup ended ===
2016/1/20:16:09:01 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:16:09:01 Dario DARIO-PC Path_Length: 143
2016/1/20:16:09:01 Dario DARIO-PC Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2016/1/20:16:09:01 Dario DARIO-PC Launch
2016/1/20:16:09:01 Dario DARIO-PC CommandLine /PK 657G1 /SN 900-64329818 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2016/1/20:16:09:01 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI96D4.tmp
2016/1/20:16:09:05 Dario DARIO-PC === Setup ended ===
2016/1/20:16:09:05 Dario DARIO-PC === Setup started on DARIO-PC by Dario ===
2016/1/20:16:09:05 Dario DARIO-PC Path_Length: 143
2016/1/20:16:09:05 Dario DARIO-PC Current Directory C:\Users\Dario\AppData\Local\Temp\_AI96D4.tmp
2016/1/20:16:09:05 Dario DARIO-PC Launch
2016/1/20:16:09:05 Dario DARIO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2016/1/20:16:09:05 Dario DARIO-PC PageOpen LaunchDialog
2016/1/20:16:09:17 Dario DARIO-PC PageOpen LicenseDialog
2016/1/20:16:09:17 Dario DARIO-PC PageOpen ProductInfoDialog
2016/1/20:16:09:17 Dario DARIO-PC PageOpen ProductSelectionDialog2
2016/1/20:16:09:21 Dario DARIO-PC PageOpen FullProgressDialog
2016/1/20:16:09:21 Dario DARIO-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/20:16:09:21 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/1/20:16:09:30 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/1/20:16:09:30 Dario DARIO-PC Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/VCREDIST2...
2016/1/20:16:09:30 Dario DARIO-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/1/20:16:09:30 Dario DARIO-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=2
2016/1/20:16:09:31 Dario DARIO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
Also try uninstall 2008,2010 and 2012 Visual C++ Redistributable both (x64) and (x86), and then make sure 4.5 network framework is installed.
Also in the future.. Post your log file as a spoiler (6 icon from the left) so it can be collapsed or either post your setup file as an attachment...
Mark Lancaster
