Ive been trying to download revit for about 3 weeks now and evry time i try and dowload the Low Image material library it will get to a certain MB, then it will show (connecting) on the status bar and wont do anything else. Ive tryed to let it sit on (connecting) over night and nothing had changed.
Solved by Mark.Lancaster. Go to Solution.
Solved by TravisNave. Go to Solution.
Welcome to the community..
Just follow these steps and don't worry about downloading through your Autodesk Account.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
If you can't find the Autodesk material library, move to the second step that is;
ACCESS THE AUTODESK EDUCATIONAL FREE SOFTWARE
Do not use install now option, as this will only install Autodesk Revit without its library. You should use the DOWNLOAD NOW option. This will use the Autodesk download manager, with this, all content of the installation will be downloaded.
Let me know as it goes.
Best wishes
Find attached images and click on the highlighted texts. I hope they will be of help.
Keep me updated as it goes
Best wishes
Unless you know.. Don't always assume that everybody coming here looking for assistance on this has access to free educational software.
Mark Lancaster
