Installation & Licensing
BReplace AutoCAD 2024 - not available for me?
3 REPLIES 3
PinRudolf
709 Views, 3 Replies
When starting BREPLACE I receive the below notification, the command cannot be executed.
Entitlement is not available or enabled.
I'm using a single user license and I have all services assigned.
Is someone else experiencng the same issue?
Note: I was looking into this and found that the command sends a server request to developer.api.autodesk.com, using a server in Europe (57.74.47.69). The Response code was 200 (OK), but there is an SSL-error; the certification seems to have been expired.
Tags (1)
3 REPLIES 3
paullimapa
in reply to: PinRudolf
perhaps contact Autodesk directly or if you purchased through a reseller contact them?
Paul Li
IT Specialist
@The Office
Maxington
I have the same issue, you can get around it using the BLOCKREPLACE command.
Now I'm concerned other basic commands will be broken...
paullimapa
in reply to: Maxington
Unfortunately BLOCKREPLACE only works if you have Express Tools.
Also it's not as graphically friendly as the new BREPLACE command.
Paul Li
IT Specialist
@The Office
Administrator Productivity
