AUTODESK REVIT HAS STOPPED WORKING
hi guys
i downloaded the free student revit om my pc and when i start the application it crash giving me the error of
the version i use is 2014
my pc = intel core 2 duo cpu t6600 2.2 ghz / 1 gb ram / 32 bit
guys i really need to work in this application for my graduation project .... thanks any way
KMLCAD
Hi salem777 and welcome to the community!  I did some searching and found this article that may be useful.  PLease try the solution provided within and see if that fixes your issue.
Kevin.L
Customer Service Technical Specialist
Installation and Licensing Forum | Up and Ready Blog | Up and Ready Webinar
@KMLCAD, The article you mentioned isn't even remotely relevant; it applies to a different program (AutoCAD), it blames the license manager as the issue, and the error message is completely different from what @Anonymous is experiencing!
If you actually want to help users solve problems, have a little attention to detail and determine the cause of the exact error for the exact program!
Mark.Lancaster
@Anonymous
The original posting is close to be a year old...   Do you have in issue with Revit stopping?
Mark Lancaster
@Mark.Lancaster, Yes, I have a similar problem with the exact same error message, but no error code. I've opened a fresh, detailed post here: http://forums.autodesk.com/t5/revit-architecture/quot-autodesk-revit-has-stopped-working-quot-unreso...
