Server Dialog Says,
FlexNet diagnostics on Fri 12/1/2017 14:29
License file: C:\Users\Virtual\Documents\Inventor-New.lic
"86608INVNTOR_2017_0F" v1.000, vendor: adskflex, expiry: 1-jan-0
License server: Inventor-New
floating license starts: 1-jan-1990, no expiration date
Requests from the same USER/HOST do not consume a new license
This license can be checked out
The Version is 11.13.1.2
Appended below please find the requested log.
14:28:47 (lmgrd) -----------------------------------------------
14:28:47 (lmgrd) Please Note:
14:28:47 (lmgrd)
14:28:47 (lmgrd) This log is intended for debug purposes only.
14:28:47 (lmgrd) In order to capture accurate license
14:28:47 (lmgrd) usage data into an organized repository,
14:28:47 (lmgrd) please enable report logging. Use Flexera Software LLC's
14:28:47 (lmgrd) software license administration solution,
14:28:47 (lmgrd) FlexNet Manager, to readily gain visibility
14:28:47 (lmgrd) into license usage data and to create
14:28:47 (lmgrd) insightful reports on critical information like
14:28:47 (lmgrd) license availability and usage. FlexNet Manager
14:28:47 (lmgrd) can be fully automated to run these reports on
14:28:47 (lmgrd) schedule and can be used to track license
14:28:47 (lmgrd) servers and usage across a heterogeneous
14:28:47 (lmgrd) network of servers including Windows NT, Linux
14:28:47 (lmgrd) and UNIX. Contact Flexera Software LLC at
14:28:47 (lmgrd)
www.flexerasoftware.com for more details on how to
14:28:47 (lmgrd) obtain an evaluation copy of FlexNet Manager
14:28:47 (lmgrd) for your enterprise.
14:28:47 (lmgrd)
14:28:47 (lmgrd)
14:28:47 (lmgrd)
14:28:47 (lmgrd) Server's System Date and Time: Fri Dec 01 2017 14:28:47
Coordinated Universal Time
14:28:47 (lmgrd) pid 6900
14:28:47 (lmgrd) SLOG: Summary LOG statistics is enabled.
14:28:47 (lmgrd) Detecting other license server manager (lmgrd) processes...
14:28:50 (lmgrd) Done rereading
14:28:50 (lmgrd) FlexNet Licensing (v11.13.1.2 build 173302 x64_n6) started
on Inventor-New (IBM PC) (12/1/2017)
14:28:50 (lmgrd) Copyright (c) 1988-2015 Flexera Software LLC. All Rights
Reserved.
14:28:50 (lmgrd) World Wide Web:
http://www.flexerasoftware.com14:28:50 (lmgrd) License file(s):
14:28:50 (lmgrd) lmgrd tcp-port 27000
14:28:50 (lmgrd) (@lmgrd-SLOG@)
14:28:50 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
14:28:50 (lmgrd) (@lmgrd-SLOG@) Start-Date: Fri Dec 01 2017 14:28:50
14:28:50 (lmgrd) (@lmgrd-SLOG@) PID: 6900
14:28:50 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.13.1.2 build 173302
x64_n6 ( build 173302 (ipv6))
14:28:50 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
14:28:50 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
14:28:50 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
14:28:50 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: No
14:28:50 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
14:28:50 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup:
-app -win -c C:\Users\Virtual\Documents\Inventor-New.lic -l
C:\Autodesk\Network License Manager\debug.log
14:28:50 (lmgrd) (@lmgrd-SLOG@) License file(s) used:
14:28:50 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-1024
14:28:50 (lmgrd) Starting vendor daemons ...
14:28:50 (lmgrd) Starting vendor daemon at port 2080
14:28:50 (lmgrd) Using vendor daemon port 2080 specified in license file
14:28:50 (lmgrd) Started adskflex (pid 3068)
14:28:50 (adskflex) SLOG: Summary LOG statistics is enabled.
14:28:50 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
14:28:51 (adskflex) SLOG: VM Status: 12
14:28:51 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
14:28:51 (adskflex) Server started on Inventor-New for:
14:28:51 (adskflex) EXTERNAL FILTERS are OFF
14:28:51 (lmgrd) adskflex using TCP-port 2080
14:28:51 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
14:28:51 (adskflex) SLOG: TS update poll interval is 600 seconds.
14:28:51 (adskflex) SLOG: Activation borrow reclaim percentage is 0.
14:28:51 (adskflex) (@adskflex-SLOG@)
14:28:51 (adskflex) (@adskflex-SLOG@) === Vendor Daemon ===
14:28:51 (adskflex) (@adskflex-SLOG@) Vendor daemon: adskflex
14:28:51 (adskflex) (@adskflex-SLOG@) Start-Date: Fri Dec 01 2017 14:28:51
14:28:51 (adskflex) (@adskflex-SLOG@) PID: 3068
14:28:51 (adskflex) (@adskflex-SLOG@) VD Version: v11.13.1.2 build 173302
14:28:51 (adskflex) (@adskflex-SLOG@) === Startup/Restart Info ===
14:28:51 (adskflex) (@adskflex-SLOG@) Options file used: None
14:28:51 (adskflex) (@adskflex-SLOG@) Is vendor daemon a CVD: No
14:28:51 (adskflex) (@adskflex-SLOG@) Is TS accessed: No
14:28:51 (adskflex) (@adskflex-SLOG@) TS accessed for feature load: -NA-
14:28:51 (adskflex) (@adskflex-SLOG@) Number of VD restarts since LS
startup: 0
14:28:51 (adskflex) (@adskflex-SLOG@) === Network Info ===
14:28:51 (adskflex) (@adskflex-SLOG@) Listening port: 2080
14:28:51 (adskflex) (@adskflex-SLOG@) Daemon select timeout (in seconds): 1
14:28:51 (adskflex) (@adskflex-SLOG@) === Host Info ===
14:28:51 (adskflex) (@adskflex-SLOG@) Host used in license file:
Inventor-New
14:28:51 (adskflex) (@adskflex-SLOG@) Running on Hypervisor: Azure
14:28:51 (adskflex) (@adskflex-SLOG@) LMBIND needed: No
14:28:51 (adskflex) (@adskflex-SLOG@) LMBIND port: -NA-
