AutoDesk Network License
Message 1 of 11
 I want to know that, Whether Autodesk Network License can work on Microsoft Azure Virtual Machine /AWS Virtual Machine /Cloud Physical Server ?
Replies (10)
Message 2 of 11
Mark.Lancaster
@Anonymous
This type of question should be asked over in the Autodesk Licensing and Installation forum and not here in the Inventor forum.  I will have the moderator relocate it.
However to answer your question...
As of right now technically you can't host your license manager in the cloud.  But at the same time others are doing it.  Its a grey area at this point because when the rules/guidelines were written years ago for the license manager, cloud services didn't exist.  Smiley Wink   In addition there's a risk that others can steal your license and etc being out in a public area.
In the end you have to configure ports to ensure the traffic gets through.
Mark Lancaster
Message 3 of 11
I believe you want to mean it, legally and not technically, because others
could/able do it.
Many companies are moving their local physical infrastructure to Cloud. And
many want the licenses be available at cloud and use it From Office/Home/Off
Site without worrying to borrow.
Ensured the necessary ports are opened. The most funniest aspect is the
server (installed on Windows 10) says, the license can be checked out and
client (Inventor 2017) is sitting on the same machine is unable to get the
license and says Error(0,0,0).
Message 4 of 11
Mark.Lancaster
@Anonymous
Legally..  It is against the terms/conditions.  But others are doing it and not sure if Autodesk is going to enforce the rule or not.  Like I said its a grey area.  In addition if the machine is hosting the license file and the application is on the same machine..  What information did you use?  Did you state the actual name of the machine or did you use localhost as the name?
Mark Lancaster
Message 5 of 11
I tried localhost, Machine Name, IP Address, with or without default port, the result is identical i.e. Error(0,0,0).
Message 6 of 11
Mark.Lancaster
@Anonymous
Is this the only machine experiencing the issue?  Is the license manager service running and issuing license?  What version is your license manager?  It has to be version 11.13.1.2 for the 2017 product line.  Can you attach the debug log (log file as indicated in config service tab of LMTOOLS) here?  ALthough it contains names and etc..  There's no impact to your infrastructure if you do share the log file.
Mark Lancaster
Message 7 of 11
Server Dialog Says,
FlexNet diagnostics on Fri 12/1/2017 14:29
License file: C:\Users\Virtual\Documents\Inventor-New.lic
"86608INVNTOR_2017_0F" v1.000, vendor: adskflex, expiry: 1-jan-0
License server: Inventor-New
floating license starts: 1-jan-1990, no expiration date
Requests from the same USER/HOST do not consume a new license
This license can be checked out
The Version is 11.13.1.2
Appended below please find the requested log.
14:28:47 (lmgrd) -----------------------------------------------
14:28:47 (lmgrd) Please Note:
14:28:47 (lmgrd)
14:28:47 (lmgrd) This log is intended for debug purposes only.
14:28:47 (lmgrd) In order to capture accurate license
14:28:47 (lmgrd) usage data into an organized repository,
14:28:47 (lmgrd) please enable report logging. Use Flexera Software LLC's
14:28:47 (lmgrd) software license administration solution,
14:28:47 (lmgrd) FlexNet Manager, to readily gain visibility
14:28:47 (lmgrd) into license usage data and to create
14:28:47 (lmgrd) insightful reports on critical information like
14:28:47 (lmgrd) license availability and usage. FlexNet Manager
14:28:47 (lmgrd) can be fully automated to run these reports on
14:28:47 (lmgrd) schedule and can be used to track license
14:28:47 (lmgrd) servers and usage across a heterogeneous
14:28:47 (lmgrd) network of servers including Windows NT, Linux
14:28:47 (lmgrd) and UNIX. Contact Flexera Software LLC at
14:28:47 (lmgrd) www.flexerasoftware.com for more details on how to
14:28:47 (lmgrd) obtain an evaluation copy of FlexNet Manager
14:28:47 (lmgrd) for your enterprise.
14:28:47 (lmgrd)
14:28:47 (lmgrd)
14:28:47 (lmgrd)
14:28:47 (lmgrd) Server's System Date and Time: Fri Dec 01 2017 14:28:47
Coordinated Universal Time
14:28:47 (lmgrd) pid 6900
14:28:47 (lmgrd) SLOG: Summary LOG statistics is enabled.
14:28:47 (lmgrd) Detecting other license server manager (lmgrd) processes...
14:28:50 (lmgrd) Done rereading
14:28:50 (lmgrd) FlexNet Licensing (v11.13.1.2 build 173302 x64_n6) started
on Inventor-New (IBM PC) (12/1/2017)
14:28:50 (lmgrd) Copyright (c) 1988-2015 Flexera Software LLC. All Rights
Reserved.
14:28:50 (lmgrd) World Wide Web: http://www.flexerasoftware.com
14:28:50 (lmgrd) License file(s):
14:28:50 (lmgrd) lmgrd tcp-port 27000
14:28:50 (lmgrd) (@lmgrd-SLOG@)
14:28:50 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
14:28:50 (lmgrd) (@lmgrd-SLOG@) Start-Date: Fri Dec 01 2017 14:28:50
14:28:50 (lmgrd) (@lmgrd-SLOG@) PID: 6900
14:28:50 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.13.1.2 build 173302
x64_n6 ( build 173302 (ipv6))
14:28:50 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
14:28:50 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
14:28:50 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
14:28:50 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: No
14:28:50 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
14:28:50 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup:
-app -win -c C:\Users\Virtual\Documents\Inventor-New.lic -l
C:\Autodesk\Network License Manager\debug.log
14:28:50 (lmgrd) (@lmgrd-SLOG@) License file(s) used:
14:28:50 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-1024
14:28:50 (lmgrd) Starting vendor daemons ...
14:28:50 (lmgrd) Starting vendor daemon at port 2080
14:28:50 (lmgrd) Using vendor daemon port 2080 specified in license file
14:28:50 (lmgrd) Started adskflex (pid 3068)
14:28:50 (adskflex) SLOG: Summary LOG statistics is enabled.
14:28:50 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
14:28:51 (adskflex) SLOG: VM Status: 12
14:28:51 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
14:28:51 (adskflex) Server started on Inventor-New for:
14:28:51 (adskflex) EXTERNAL FILTERS are OFF
14:28:51 (lmgrd) adskflex using TCP-port 2080
14:28:51 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
14:28:51 (adskflex) SLOG: TS update poll interval is 600 seconds.
14:28:51 (adskflex) SLOG: Activation borrow reclaim percentage is 0.
14:28:51 (adskflex) (@adskflex-SLOG@)
14:28:51 (adskflex) (@adskflex-SLOG@) === Vendor Daemon ===
14:28:51 (adskflex) (@adskflex-SLOG@) Vendor daemon: adskflex
14:28:51 (adskflex) (@adskflex-SLOG@) Start-Date: Fri Dec 01 2017 14:28:51
14:28:51 (adskflex) (@adskflex-SLOG@) PID: 3068
14:28:51 (adskflex) (@adskflex-SLOG@) VD Version: v11.13.1.2 build 173302
14:28:51 (adskflex) (@adskflex-SLOG@) === Startup/Restart Info ===
14:28:51 (adskflex) (@adskflex-SLOG@) Options file used: None
14:28:51 (adskflex) (@adskflex-SLOG@) Is vendor daemon a CVD: No
14:28:51 (adskflex) (@adskflex-SLOG@) Is TS accessed: No
14:28:51 (adskflex) (@adskflex-SLOG@) TS accessed for feature load: -NA-
14:28:51 (adskflex) (@adskflex-SLOG@) Number of VD restarts since LS
startup: 0
14:28:51 (adskflex) (@adskflex-SLOG@) === Network Info ===
14:28:51 (adskflex) (@adskflex-SLOG@) Listening port: 2080
14:28:51 (adskflex) (@adskflex-SLOG@) Daemon select timeout (in seconds): 1
14:28:51 (adskflex) (@adskflex-SLOG@) === Host Info ===
14:28:51 (adskflex) (@adskflex-SLOG@) Host used in license file:
Inventor-New
14:28:51 (adskflex) (@adskflex-SLOG@) Running on Hypervisor: Azure
14:28:51 (adskflex) (@adskflex-SLOG@) LMBIND needed: No
14:28:51 (adskflex) (@adskflex-SLOG@) LMBIND port: -NA-
Message 8 of 11
Mark.Lancaster
@Anonymous
Here's what I would recommend..
In the folder location where your license manage is located.
Create 2 folders
License and Log.
For the log file make sure "EVERYONE" is giving fill access to that folder.
Move your license file from a User's document folder location and place in the license folder.  Access LMTOOLS/Config tab, stop the service and reconfig license and log location to the new folders you just created.
Also check this registry entry..
2017-12-01_9-47-26.jpg Does it exist?  What value is there?
Mark Lancaster
Message 9 of 11
Mark.Lancaster Thanks a Lot.
We went to the Basic, first checked the License File and found it is
Inventor 2017 and the client was Inventor Professional 2017. How foolish we
are? Sorry for troubling you.
Thanks Many for your constant and immediate advises.
Message 10 of 11
Now it is certified that the Inventor License can be hosted on Azure Server and works seamlessly for the same country (R) same country clients.
Message 11 of 11
natasha.l
Hello @lkumaresan,
Thank you for following up with the community on this.
Autodesk is not supporting any cloud services/platforms hosting network license they remain officially unsupported. Just be sure to review & follow the license compliance terms & you will be fine.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
