Installation & Licensing
Autodesk Fusion 360 Deployment
4 REPLIES 4
MrBHall
447 Views, 4 Replies
I'm trying to deploy the admin versions of Autodesk Fusion 360. I've download the admin installer but when running the program with the -quite parameter the installation fails. Running it normally works fine. When you run with -quite command set, the extraction loading bar is shown, reaches 100% then the exe closes. No errors are shown in event viewer or on screen.
Can anyone advise what the issue is or were to look for the error?
Thank You, Rob
4 REPLIES 4
Darin.Green
in reply to: MrBHall
You would need to export the msi file in order to use the /quiet switch. That said, I don't think you can extract an msi file from this installer.
If this information was helpful, please consider using the Accept Solution
MrBHall
in reply to: Darin.Green
Hi Darin,
I was following the instructions show in this document:
http://damassets.autodesk.net/content/dam/autodesk/docs/pdfs/Advanced_Fusion360_Lab_Installation_Ins...
This shows running the exe with the -quite switch.
Darin.Green
I think the issue is that you're using a single dash instead of a double-dash (--quiet).
MrBHall
Hi Darin,
My script was using --quite but not my test shortcut, put the double dashes in my shortcut but still the same problem. Are then any logs created, it looks like the extraction takes place, then the exe is still running for a few more seconds before it closes.
Thanks, Rob
Administrator Productivity
