Installation & Licensing
Autodesk FeatureCAM 2019
7 REPLIES 7
Message 1 of 8
852 Views, 7 Replies
I would like someone to help me install FC 2019.
I'm not going to criticize, but this should be a simple job, it does not look like that......
7 REPLIES 7
Message 2 of 8
what is the details of the problem you are having? Is it an upgrade or a new install? are there errors popping up? if so what do they say?
Message 3 of 8
dillon.moulder
dillon.moulder
Hi @Anonymous,
If you have not done so already, I recommend that you use the Browser Download method to download the Autodesk FeatureCAM Ultimate 2019 installer from your Autodesk Account.
If you encounter issues during the installation process, I recommend that you create and submit a case from your Autodesk Account to report them.
Kind regards,
Hi @Anonymous,
Kind regards,
Message 4 of 8
in reply to: dillon.moulder
ok
ok
Message 5 of 8
I did download  2019.3 ,I tried to open and i got this.
Message 6 of 8
dillon.moulder
dillon.moulder
Hi @Anonymous,
I suggest that you try setting the ADSKFLEX_LICENSE_FILE system environment variable and point it to the license server; please refer to this article in the Autodesk Knowledge Network (AKN).
Please let me know whether this resolves your reported issue.
Thanks in advance for your time and cooperation.
Kind regards,
Hi @Anonymous,
Kind regards,
Message 7 of 8
natasha.l
natasha.l
Hello @Anonymous,
Welcome.
I see you have a multi-user network license, please follow the workflow below to set up your license manager to make sure it is set up properly.
A license file first needs to be generated or requested here:
1. Generate a Network License File in your Autodesk Account or Requesting a Network License File
*If you need help Finding Your Host Name and Physical Address
Then, the NLM needs to be installed and setup:
2. Make sure you meet the NLM requirements to Install & Configure it
3. Then, on each Client computer at launch, specify a License Server "2080@ServerName"
If you have done all of the above, Start/Stop the NLM Service:
  • Make sure the current version of Lmtools 11.14.1.3 is installed
  • Start/Stop/Reread Tab > Select FlexNet Service (should only be 1 Autodesk service) > Check Box Force Server Shutdown > Select Stop Server Button > Uncheck Box Force Server Shutdown > Start Server > Server Start Successful. (should appear below)
  • Verify users are pulling licenses
If you continue to have an issue please locate the Config Services Tab > View Log Button
Please attach the results.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Hello @Anonymous,
Welcome.
Message 8 of 8
natasha.l
natasha.l
Hello @Anonymous,
I wanted to check-in with you, I hope you were able to resolve the issue with your software.
Hello @Anonymous,
Administrator Productivity
