Trying to update to the latest Connector.
Launch the .exe and it runs until halfway completed, then a pop up:
Autodesk Desktop Connector Setup
Could not access network location *:.
Retry Cancel
I try Retry, still fails. I click Cancel 5-6 times and the result is:
Setup Failed. I get a log file and 0x80070643 - Fatal error during installation.
In Control Panel, I tried to Repair ADC and same result as above. I tried to Uninstall ADC and same result. (Cannot uninstall it)
I tried to update .Net Framework (version was the same or newer so nothing happened).
Tried the .Net repair tool, no change, same error on trying to update ADC.
I am on 14.1.0.1074 and trying to update to 14.5.0.1144
Ian
Solved by IanYeager. Go to Solution.
Make sure you have the Anti-Virus and Firewall turned off
Solved........I worked on this with my IT person and in theory, it had nothing to do with rights. I am an administrator on my machine with rights to install and uninstall. IT tried under his log in as well and experienced the same problem. Our final recourse was to use an uninstall utility (https://www.revouninstaller.com/) to strip the Connector out of my computer, including the registry, and then reinstall the newest release. I then logged in as myself and the Connector would not start. I launched it and got the message: A Windows service required by ADC did not start in the expected amount of time. Do you want to manually start the service?
I responded by clicking Start Services.
I then got a pop up that said: Error Autodesk Desktop Connector is shutting down. Failure to initialize Workspace Monitoring.
I performed a repair on ADC as myself, it asked for a reboot, I rebooted and ADC started. I logged in and it appears to be working fine now.
This was a lot of work for what I would classify as a little tool/program.
It wasn't rights as a full IT admin person got the same results as me.
I can only guess this had more to do with the program itself, possibly a corrupt registry or some other issue. There has to be an issue somewhere.
