I provide IT support and one of our clients called saying that he was having an issue with with his Inventor 2016. From what I understand when I remoted in to his desktop he was attempting to make some sort of pipe run. When he would finish the content library login would pop up on his screen but since there is no library it would not login. So after some searching I found what I believe is the correct download. (https://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/autodesk-i...
After unpackging the download and attempting to install it a message would pop up saying that I needed to install the Autodesk Data Management Server. But after a few hours of searching Google and Autodesk's website I have not found away to do this.
So my question is this: Am I using the correct content libraries, how do I install the Autodesk Data Management Server, or is their an easier way to go about this?.
