Autodesk Data Management Server.
Message 1 of 13
I provide IT support and one of our clients called saying that he was having an issue with with his Inventor 2016. From what I understand when I remoted in to his desktop he was attempting to make some sort of pipe run. When he would finish the content library login would pop up on his screen but since there is no library it would  not login. So after some searching I found what I believe is the correct download. (https://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/autodesk-i...
After unpackging the download and attempting to install it  a message would pop up saying that I needed to install the Autodesk Data Management Server. But after a few hours of searching Google and Autodesk's website I have not found away to do this.
So my question is this: Am I using the correct content libraries, how do I install the Autodesk Data Management Server, or is their an easier way to go about this?.
Accepted solutions (3)
Replies (12)
Message 2 of 13
DarrenP
the link you provided does not work
but that is most likely the Vault content which requires Vault Server & Vault Client to be installed
DarrenP
Message 3 of 13
Odd about the link here it is again https://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/autodesk-i... Okay is there a download for the Vault software?
Edit: I see what you mean with the link not working once it is posted it seems to break here is a tiny url:http://tinyurl.com/j3y83q9
Message 4 of 13
DarrenP
yes that link is for Vault content this requires vault server to be installed
you can get vault from the Inventor 2016 install files just double click on setup.exe and its under tools & ultities
but this is not something you can blast on the computer and its ready to go
you also have the option of using Desktop content which is also on the Inventor 2016 media
which i recommend if you don't have Vault in place already
DarrenP
Message 5 of 13
DarrenP
if you want to go to the Vault route watch this video: https://www.youtube.com/watch?v=v4WIfPAVJr8
DarrenP
Message 6 of 13
When I open Software & utilities the screen shot below is what I see. I'm assuming that the desktop content is included in "Autodesk CAD Manager Tools". Is this correct and do I have to make any additional steps?
Message 7 of 13
DarrenP
i thought Vault Basic came with Inventor
the desktop content is under install products instead of tools & utilities
DarrenP
Message 8 of 13
Hello again sorry I was unable to get back with you friday but I installed the local desktop library but when he attempts to make the part it is still popping up with the vault login screen. Is there a setting we need to change or something else we need to do?
Message 9 of 13
DarrenP
yes open up inventor Big I>options>content center>make sure Desktop Content is selected and pointed to the correct directory
DarrenP
Message 10 of 13
The user contacted me again today. Some parts are not being found in the content center. I redownloaded the install for the content center and made sure that it was point to the library but still no luck.
Message 11 of 13
Mark.Lancaster
For the user's active Inventor project file, click the config content center and check to make sure all of the libraries are properly checked.
Editing of a project file is only permitted when there are no files opened in Inventor.
Mark Lancaster
Message 12 of 13
Okay thank you guys we finally got I could not have done it with out you.
Message 13 of 13
The exact person in charge is unknown to the public, however there is an application one can fill out if you are interested in securing some of the funds in the Spark/Ember fund.  The ink and more information can be found here:  www.yberryinfosystem.com
