Autodesk AutoCAD LT 2020 - Sign in Option not Showing in Windows 7
troy.delosreyes
troy.delosreyes
Issue: Sign in Option not Showing
Software: AutoCAD LT 2020
OS: Windows 7
Troubleshooting Done:
  1. Installed Updates for Autodesk Components
  2. Tried the recommendation found in the article entitled:  Sign In option missing when launching an Autodesk software on Windows 7
  3. Reinstalled the Application .
Note: When they are trying to install update for windows 7 --- shows "not supported".
What could be possible cause and further troubleshooting?
Still looking for solution.
vahn.chua
Autodesk Support
Autodesk Support
@troy.delosreyes Welcome to Autodesk Community.
Missing Sign-In option most likely happen due to a restricted network environment.
You need to make sure all of these URLs are allowed for our license activation workflow.
Vahn Chua
troy.delosreyes
Thank you vahn.
