Installation & Licensing
Autodesk 2015 installation
2 REPLIES 2
450 Views, 2 Replies
Dear Sir,
        I have installed student version autocad 2015 , but due to laptops issue it is formatted, I have tried to reinstall autocad 2015 by using setup available with me, but there ia communication error, screenshot attached.
Can I have to download new setup & do the installation.
Pooja Dudhal
2 REPLIES 2
Otto
Hello poojadudhal and welcome to the Autodesk community!
It looks like you’re seeing the "Communication Failure" window. This error typically occurs when you select the Install Now method to download and install Autodesk software. The following article(s) should help you resolve the problem:
Downloading Previous Versions of Autodesk Software Using the Virtual Agent
For additional information, please see the following:
Communication Failure message during download and installation
Errors during AutoCAD software installation
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@Anonymous
Welcome to the community..  Not sure in the autobot reply helped you or not..   But go to the Autodesk Virtual Agent and follow the download links to your product. Download all of the parts first and then go to your download location. Extract (double click) part 1 and in a few seconds the extraction will start. It will then prompt you to extract to C:\Autodesk and once the extraction is finished the installation will start.
Mark Lancaster
Administrator Productivity
