Hello All,
Wondering if anyone can help. I'm an occasional user of AutoCAD mobile. I've just purchased a new iPAD and AutoCAD mobile will not let me login. I get as far as the first login screen, type my email address and hit "next", the "next" button briefly flashed "verifying" and nothing more. The password screen never appears.
So, I tried my old iPAD where AutoCAD has worked reliably in the past and got exactly the same result.
I've checked my account and confirmed that I have a valid subscription that includes AutoCAD mobile.
Where do I go from here?
Andrew
Solved by andrew_robertson1. Go to Solution.
Solved by natasha.l. Go to Solution.
Hello @andrew_robertson1,
I have reviewed the Autodesk online services, for the AutoCAD Mobile app and the health status is good.
I recommend reviewing your AutoCAD Mobile support options, "Obtaining AutoCAD Web and AutoCAD Mobile application support" and select an option based on your preferences.
In the meantime, try clearing the browser cache & history (Safari), also make sure you are logged in on 1 device. If you are using a Wifi network with securities enabled try a different network.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Thank you for getting back to me. You put me on the right path. The issue turned out to be that in Safari “Block All Cookies” was turned on. I never use Safari and it seems that in a recent sw upgrade my preferred browser was changed back to Safari.
It works perfectly well now.
Thank you.
