I need to install the Autocad Map 3D 2018 Update silently. But I am not able to do it.
Can you suggest how can I install the update silently.
@Anonymous
Welcome to the Autodesk Community..
What update are you talking about? Do you have deployment already for Map 3D 2018?
Mark Lancaster
& Autodesk Services MarketPlace Provider
you can use the /q switch to run the update silently
For the AutoCAD_Map_3D_2018.0.1_Update.exe file, use the command line
AutoCAD_Map_3D_2018.0.1_Update.exe /q
by using silent switch /quite, its got silently install, But I need to uninstall this update silently. I am not getting any details in registry or any other files to uninstall this update. Kindly suggest any command or any other way to uninstall it silently.
I am part of Application packaging team so I need to deploy this update silently in which both installation & uninstall required.
Kindly suggest.
