I am a school IT Director and we do not have computers in our HS - we use VMWare as a virtual environment to provide Windows Desktops. Can I run AutoCAD LT in a VMWare environment for my students?
Thanx for any feedback you can provide.
Solved by natasha.l. Go to Solution.
Hello @Anonymous,
Autodesk permits virtual environments be used to run software. I have attached an article that explains further, on the forums there are several members that have used VMware.
Autodesk support for hosted operating system environments
Please let us know if you have any further questions. Thank you for posting.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @Anonymous,
Natasha
Helpful Links:
@Anonymous
To answer your question, yes, virtual machines are supported. However, you do not want to use VMWare. I would recommend Citrix XenApps or desktop. It uses the hardware, graphics and processing of the physical machine. Citrix has better performance.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
@Anonymous
Darin Green
Hello @Anonymous,
I hope the information and feedback provided were helpful.
Please "Accept As Solution" if a reply has provided information that was useful or answered your question, to help others in the community.
Thank you.
Natasha
Helpful Links:
Hello @Anonymous,
Thank you.
Natasha
Helpful Links:
Thank you for the feedback. I already have VMware, so the suggestion to abandon this and go to Citrix is not a solution.
Thanx for the article links and the suggestion to view other VM install questions (which obviously I did not do). We will insure we have the proper licensing and then give it a try since I do not have any other option given I am a 100% virtual environment now with a large investment in VM.
Note to Autodesk - please spend time with VmWare and work out the solutions to using it as a solution for your products. Thank you.
VMware exams are easy to pass by the help of our best study material. We provide latest and valid 2V0-620 braindumps with 2V0-620 VCE Questions. Here you get updated 2V0-620 practice test questions answers and pass your exam easily.
Hello Natasha!
The article links you shared are not working anymore. Do you know if things changed since then?
I have a question regarding VM for Acad LT from a client of ours: What are the sys requirements to run Acad LT 2021 on a VM hosted on Azure.
Hello Natasha!
DarrenP
DarrenP
I'm looking for knowledge and experience, not links. I already have those.
