When trying to down load AutoCAD 2018 on to my brand new Dell laptop (Windows 10) I have these errors 1603 & 1619 what am I doing wrong ?
Solved by user181. Go to Solution.
Check out this link about AIDA, the Autodesk® Installation Diagnostic Assistant
Hi @martinWDJAA,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Did a download using the Virtual Agent help to correct the install problem?
If you haven't had the chance to try it yet, you might also use the Prerequisite Checker tool to help ensure a successful install of your application.
