AutoCAD LT 2017 will not install
Message 1 of 8
I just bought a stand alon verion of AutoCAD lt 2017, and it is quite frustrating as I have downloaded the installation files however after a few minutes i get a red cross next to all the parts im trying to download and a message saying failed and nothing else. Please help, what can I do to solve this?
I have attached the error messge and also have turned of my firewall and  cheked the operating system which I believe is correct.
Replies (7)
Message 2 of 8
Otto
Hello sharanchandola and welcome to the Autodesk community!
It looks like you are stuck at the activation/installation step while attempting to download software, or are having problems with starting your software immediately after installing. The following article(s) should help you resolve the problem:
Communication Failure message during download and installation - Note that this article also provides alternate downloading and installation methods.
Application Manager Update stuck at installing
In order to manually activate your software (in cases where the activation appears stuck), please refer to Manually Activating Your Autodesk Software.
If the activation window is not displayed, others have resolved this by completely uninstalling and reinstalling their software. Please refer to How to Remove all Software from a Windows System for assistance.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 8
Darin.Green
Use the Virtual Agent to download the software. Once it's completely downloaded, you can run the installation.
If this information was helpful, please consider using the Accept Solution
Message 4 of 8
Juan_Cendejas_78
Solve the problem of Autodesk 2017 installation consists of Microsoft Visual C ++.
Solution:
1. open window settings, applications and features, desinstaler all Microsoft Visual C ++ 2012 Redistributable (86) and (68), Microsoft Visual C ++ 2013 Redistributable (86) and (68), Microsoft Visual C ++ Redistributable 2015 (86) and (68). one by one, it may take a few minutes, once finished close the window.
** No need to restart the PC.
2. SETUP.exe can open the file and begin the installation Autodesk.
Autodesk Setup again installed the Visual C ++ 2012, 2015, do not need intalarlos again if required for other programs can download in the official website of Microsoft.
I hope it will help them.
Regards
Jc.
Message 5 of 8
rudi.roux
Hi @Anonymous
As mentioned by @Darin.Green, use the Virtual Agent to download the files. You can then also do a manual .NET & C++ cleanup and delete temporary files in your TEMP folder. Instead of reposting the entire thread with appropriate links and images here, you could visit THIS thread which shows you how to accomplish this. This will guide you through the above-mentioned steps.
The particular link above relates to AutoCAD 2015 on Windows 8, but the steps outlined resolved installation issues for other members trying to install AutoCAD 2017 on Windows 10.
I hope this helps and welcome to the community! Smiley Happy
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Message 6 of 8
Mark.Lancaster
@rudi.roux
This posting dates back to May 2016...  I hope by now the original poster has had their software installed and working by now..  Smiley Very Happy
Mark Lancaster
Message 7 of 8
rudi.roux
@Mark.Lancaster - bloody hell... hahaha... blond moment... After 16 hours of work I should rather switch my PC off. I managed to stumble on this post for some reason and figured that I'll provide my input without checking the dates. haha - Cheers for pointing it out though and I also hope they resolve their issue by now! Smiley LOL
Rudi Roux
LinkedIn
Message 8 of 8
Mark.Lancaster
@rudi.roux
No problem (it happens)..  I've done it a few times in the past too..  Like replying to a posting that is 2 or 3 years old... Smiley Sad
Mark Lancaster
