i suspect licence problem as this is the ADLMINTRES.txt
<?xml version="1.0" encoding="utf-8"?>
<ADLMSTRINGTABLE VERSION="1.0.0.0">
<STRING ID="IDS_NWLIC_BUTTON_YES">
<CAPTION>Yes</CAPTION>
<COMMENT>Button caption Yes</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_BUTTON_NO">
<CAPTION>No</CAPTION>
<COMMENT>Button caption No</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_BORROW_CAPTION1">
<CAPTION>License Borrowed</CAPTION>
<COMMENT>License Borrow information title</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_BORROW_CAPTION2">
<CAPTION>License Borrowing Error</CAPTION>
<COMMENT>License Borrow Error title</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_RETURN_CAPTION1">
<CAPTION>License Returned</CAPTION>
<COMMENT>License Return information title</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_RETURN_CAPTION2">
<CAPTION>License Return Error</CAPTION>
<COMMENT>License Return Error title</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_RETURN_CAPTION3">
<CAPTION>Return Borrowed License</CAPTION>
<COMMENT>License Return Confirmation title</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_ERROR_CAPTION1">
<CAPTION>Unavailable License Alert</CAPTION>
<COMMENT>General License Unavailable error title</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_BORROW_ERROR_INVALID_MAX_TITLE">
<CAPTION>You cannot borrow a license at this time.</CAPTION>
<COMMENT>Invalid maximum borrow hours specified dialog message</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_BORROW_ERROR_INVALID_MAX_DETAIL">
<CAPTION>The borrowing period established for the license server is not valid.<br><br>Contact your system administrator to have the borrowing period reset to a value of at least one day (24 hours).</CAPTION>
</STRING>
<STRING ID="IDS_NWLIC_RETURN_NOW_DETAIL">
<CAPTION>Return the borrowed license now?</CAPTION>
<COMMENT>Return the borrowed license now confirmation question dialog message</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_RETURN_SUCCESS_TITLE">
<CAPTION>The borrowed license has been successfully returned.</CAPTION>
<COMMENT>The borrowed license is returned back to the license server dialog message</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_BORROW_NOLIC_TITLE">
<CAPTION>There are no licenses available to borrow. Try again later.</CAPTION>
<COMMENT>No licenses available to borrow message</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_BORROW_FAILED_TITLE">
<CAPTION>You cannot borrow a license at this time.Try again later.</CAPTION>
<COMMENT>License cannot be borrowed at this time dialog message</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_BORROW_FAILED_NOTE_DETAIL">
<CAPTION>If this problem persists, contact your system administrator.<br><br>Note:You can continue to use %1 while you are connected to the network license server.<br><br>Error: [%2]</CAPTION>
<COMMENT>No licenses available to borrow message displayed with the vendor error code and the product name</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_BORROW_FAILED_NO_NOTE_DETAIL">
<CAPTION>If this problem persists, contact your system administrator.<br><br>Error: [%1]</CAPTION>
<COMMENT>No licenses available to borrow message displayed with the vendor error code</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_BORROW_ERROR_TITLE">
<CAPTION>An unexpected license borrowing error has occured.</CAPTION>
<COMMENT>This message is due to inability to get the borrowing of license</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_BORROW_ERROR_DETAIL">
<CAPTION>You can no longer run %1 using the borrowed license.<br><br>For more information, contact your system administrator.<br><br>Error: [%2]</CAPTION>
</STRING>
<STRING ID="IDS_NWLIC_BORROW_TOOLONG_TITLE">
<CAPTION>You can borrow this license for a maximum of %1 days.</CAPTION>
<COMMENT>This is borrow period ( maximum hours) specified is too long message</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_BORROW_TOOLONG_DETAIL">
<CAPTION>To reset the license borrowing period, use the Autodesk License Borrowing utility and try again.<br><br>Error [%1]</CAPTION>
<COMMENT>This is borrow period (maximums hours) specified is too long message</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_LICENSING_ERROR_TITLE">
<CAPTION>A valid license could not be obtained by the network license manager.</CAPTION>
<COMMENT>Generic licensing error while trying to get the license from the license server displayed with the vendor error code</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_LICENSING_ERROR_DETAIL">
<CAPTION>If you are still unable to access a license, contact your system administrator.<br><br>Error [%1]</CAPTION>
</STRING>
<STRING ID="IDS_NWLIC_LOST_LICENSE_CAPTION">
<COMMENT>The connection to the license server is lost hence the license will not available dialog caption</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_LOST_LICENSE_TITLE">
<CAPTION>Your license is no longer available.</CAPTION>
<COMMENT>The connection to the license server is lost hence the license will not available dialog message</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_LOST_LICENSE_DETAIL">
<CAPTION>To re-establish the license, close and then restart this product.</CAPTION>
</STRING>
<STRING ID="IDS_NWLIC_CALENDAR_MONTH1">
<CAPTION>January</CAPTION>
<COMMENT>First Month of the english calendar</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_CALENDAR_MONTH2">
<CAPTION>February</CAPTION>
<COMMENT>Second Month of the english calendar</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_CALENDAR_MONTH3">
<CAPTION>March</CAPTION>
<COMMENT>Third Month of the english calendar</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_CALENDAR_MONTH4">
<CAPTION>April</CAPTION>
<COMMENT>Fourth Month of the english calendar</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_CALENDAR_MONTH5">
<CAPTION>May</CAPTION>
<COMMENT>Fifth Month of the english calendar</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_CALENDAR_MONTH6">
<CAPTION>June</CAPTION>
<COMMENT>Sixth Month of the english calendar</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_CALENDAR_MONTH7">
<CAPTION>July</CAPTION>
<COMMENT>Seventh Month of the english calendar</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_CALENDAR_MONTH8">
<CAPTION>August</CAPTION>
<COMMENT>Eigth Month of the english calendar</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_CALENDAR_MONTH9">
<CAPTION>September</CAPTION>
<COMMENT>Ninth Month of the english calendar</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_CALENDAR_MONTH10">
<CAPTION>October</CAPTION>
<COMMENT>Tenth Month of the english calendar</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_CALENDAR_MONTH11">
<CAPTION>November</CAPTION>
<COMMENT>Eleventh Month of the english calendar</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_CALENDAR_MONTH12">
<CAPTION>December</CAPTION>
<COMMENT>Twelth Month of the english calendar</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_WEEK_DAY0">
<CAPTION>Sunday</CAPTION>
<COMMENT>First Day of the week</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_WEEK_DAY1">
<CAPTION>Monday</CAPTION>
<COMMENT>Second Day of the week</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_WEEK_DAY2">
<CAPTION>Tuesday</CAPTION>
<COMMENT>Third Day of the week</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_WEEK_DAY3">
<CAPTION>Wednesday</CAPTION>
<COMMENT>Fourth Day of the week</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_WEEK_DAY4">
<CAPTION>Thursday</CAPTION>
<COMMENT>Fifth Day of the week</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_WEEK_DAY5">
<CAPTION>Friday</CAPTION>
<COMMENT>Sixth Day of the week</COMMENT>
</STRING>
<STRING ID="IDS_NWLIC_WEEK_DAY6">
<CAPTION>Saturday</CAPTION>
<COMMENT>Seventh Day of the week</COMMENT>
</STRING>
<STRING ID="IDS_LICENSING_ERROR_CAPTION">
<CAPTION>Licensing Error</CAPTION>
<COMMENT>Licensing error dialog title</COMMENT>
</STRING>
<STRING ID="IDS_LICTS_INIT_ERROR_TITLE">
<CAPTION>Unable to initialize adlm.</CAPTION>
<COMMENT>Adlm trusted storage initialization error title</COMMENT>
</STRING>
<STRING ID="IDS_LICTS_INVALIDPARAM_MSG">
<CAPTION>Invalid parameter.</CAPTION>
<COMMENT>Adlm trusted storage invalid parameter error message</COMMENT>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_UNKNOWN">
<CAPTION>Unknown error.</CAPTION>
<COMMENT>Adlm trusted storage initialization error message</COMMENT>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_NOPROPHANDLE_MSG">
<CAPTION>Invalid or missing property handle.</CAPTION>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_1">
<CAPTION>Unable to find security runtime.</CAPTION>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_2">
<CAPTION>Unable to load security runtime.</CAPTION>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_3">
<CAPTION>OS version too old.</CAPTION>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_4">
<CAPTION>Initialization of security runtime failed.</CAPTION>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_5">
<CAPTION>Unable to allocate resources.</CAPTION>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_6">
<CAPTION>Preptool has not been run since build.</CAPTION>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_7">
<CAPTION>Call to flxInitLoad after an flxInitUnload.</CAPTION>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_8">
<CAPTION>Path string not in UTF-8?</CAPTION>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_9">
<CAPTION>Error creating url.</CAPTION>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_10">
<CAPTION>Error creating path from url.</CAPTION>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_11">
<CAPTION>Framework specified by bundle ID not loaded.</CAPTION>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_12">
<CAPTION>Not a valid bundle ID.</CAPTION>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_13">
<CAPTION>Computed path is too long.</CAPTION>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_20">
<CAPTION>Service not installed.</CAPTION>
</STRING>
<STRING ID="IDS_LICTS_FLEX_INIT_ERROR_MSG_21">
<CAPTION>Not enough rights to talk to service.</CAPTION>
</STRING>
<STRING ID="IDS_LICUT_UB_INIT_ERROR">
<CAPTION>Error initializing the Usage tracking component.</CAPTION>
<COMMENT>Adlm usage tracking initialization error message</COMMENT>
</STRING>
</ADLMSTRINGTABLE>
