autocad installation error
i downloaded autocad 2018 from AVA and the installation fails once it reaches direct x runtime. fresh install of windows 7.
ive uplaoded the temp installation file
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Sorry that you are faced with this problem..  A 1603 failure on a core Autodesk product..  Not good.  Smiley Sad
See information in this posting.   Some users have had success in reinstalling Windows but that's not really a viable solution.   If something does work for you please let us know because to this date no one has indicated any success in getting over the 1603 error on a core product installation.
Mark Lancaster
rkmcswain
1603 and 1619 errors, fairly common.
Start here:
https://www.google.com/search?q=autocad+install+1603+1619+error
Also, the log file you uploaded is not the verbose log. Look in your %temp% folder, it will be much larger.
i have already googled the solution and i can't find anything that helps.
how do i get the verbose logs? is this it?
