Installation & Licensing
AutoCAD Installation Error; "Aborted.(Error: 9)"
99 REPLIES 99
Message 1 of 100
72080 Views, 99 Replies
I'm having trouble installing AutoCAD 2014 ...
After proceeding with the download, the loading task bar fails when it reaches 98% with the report, "Aborted. (Error 9)."
This is the first time I've had trouble downloading anything from Autodesk. If anyone has advice, I would greatly appreciate any correspondence. Thanks!
99 REPLIES 99
Message 41 of 100
in reply to: pendean
Hi! I think this should work as a workaround if you download it direct from your account management page after  you login here: https://manage.autodesk.com/cep/#products-services/all
Hope this helps! 🙂 It works for me.
Message 42 of 100
in reply to: ukdxb012
hi.. tried downloading it lots of times.. still this error appears.. what do you think should i do? please help.. i need autoCAD so much in my studies..
Message 43 of 100
matthew.d
Hi @Anonymous,
Sorry about the issue. You have tried performing a clean uninstall, disabling your antivirus, and installing from the virtual agent in a different browser?
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Message 44 of 100
in reply to: matthew.d
My apologies.. What do you mean by clean uninstall? .. I have windows defender.. I dont know if it counts as an antivirus.. As to the virtual agent.. Im not sure if the one im downloading is the one with 3yrs free license(it is not indicated) for i am a student..
Sent from: Lenovo A850
Message 45 of 100
lynn_zhang
Hi @Anonymous
See this article: How to perform a clean uninstall of an Autodesk product and follow the instructions.
Also, I see you have already got the serial number for your student license. So you just need to download the program itself which is the same when you download from Education Community or from Virtual Agent. The serial number you enter will determine the license you activate.
Lynn Zhang
Message 46 of 100
in reply to: lynn_zhang
Hi.. Thank you for your reply.. In doing the clean uninstall.. Do i need to uninstall all autodesk files? I mean.. i already have my revit and 3d max.. Should i just uninstall the autocad one? Sent from: Lenovo A850
Message 47 of 100
matthew.d
Hi @Anonymous,
Yes, you should just do it on your AutoCAD file or whichever one you are having trouble with.
Matt DiMichele
Message 48 of 100
i have read all the post and tried every recommended installation help, especially in autodesk virtual agent but the installation is still aborted.
Message 49 of 100
lynn_zhang
Hi @Anonymous Welcome to Autodesk Community!
Do you mean you've already tried the download from Virtual Agent?
Lynn Zhang
Message 50 of 100
Thank you! This method worked for me.
Message 51 of 100
hey.. thank you so much!! it worked!! thanks a lot ^_^
Message 52 of 100
Hi. I have the same issue with these guys. I kept redownloading it but it doesn't work. I also tried the link you shared ("virtual agent") but got the same issue. I hope you can help me with this. I need it so badly. Thanks in advance.
Tags (1)
Message 53 of 100
Hello, I´m having issues with the error 9 too. I´ve already read everything about this error, and tried all solutions I´ve found over my researches, but no luck yet. I´m on a notebook with 4 MB RAM, lots of hard disk space and my OS is WIndows 7 Home premium, 64 bit. I can´t even donwload it because the operation is always aborted with the error 9 on the beggining of the download process. I´ve tried many times during many days, and in different periods of the day. I´ve also blocked my firewall. No luck at all until now. Can someone drive me to the solution? I´m trying to download and isntall Autocad.
Message 54 of 100
matthew.d
Hi @Anonymous and @Anonymous,
This usually occurs when there is a change to your name, the name of your company, or your address after the product was registered.
Keep your contact information up to date using Register Once, where you can add an account with your current information, register products to that account, and delete your old accounts, or those with outdated information. Make sure there is no special characters in your system name.
If you're still having trouble with this issue, contact Customer Support.
Matt DiMichele
Message 55 of 100
i have the same problem installing autocad 2016 i wish you could instruct us more other than trying to redownload and reinstall...
Message 56 of 100
matthew.d
Hi @Anonymous,
People have different results based on the set up of their computer, you tried the virtual agent already. Here is more information on the error.
Matt DiMichele
Message 57 of 100
Hi,matthew d. thanks for replying. It can´t be the user name or anything related, because I haven´t installed it yet, and haven´t tried to activate it. I have had trouble in the download process, and that´s when I had the error 9. I´m now once again trying to download through the virtual agent. It´s taking a lot of time, because my connection isn´t fast, but at least it´s downloading and I reached 50% of download already. I´ll try to install after the process is complete, and see if it´s OK this time.
Message 58 of 100
hello everyone im having error 9 when im trying to install revit 2014 in a 32 bits windows
any help?
im trying to install it from the students fee software
Message 59 of 100
jeffrey.sin
Hi @Anonymous,
Welcome to the Community.
Could you try downloading using the Browser Download method or the Virtual Agent instead? Check out this Autodesk Solution on Error 8 or Error 9 during install for more details. Let us know how it goes.
Thank you,
Jeffrey Sin
Autodesk Customer Support
Message 60 of 100
in reply to: jeffrey.sin
I am having this issue installing Mech Sim 2016
Nothing so far works - Only option is "install"
Where can I get the full SW
Administrator Productivity
