Installation & Licensing
Autocad Installation error 1603 and 1619
2 REPLIES 2
446 Views, 2 Replies
Autocad electrical installation failed,please see attached log file.
Thanks.
Thanks.
2 REPLIES 2
Mark.Lancaster
Mark.Lancaster
@Anonymous
Most likely there's a messed up installation (at this point)..
So I would recommend that you perform a clean uninstall per these instructions.   Make sure to use the Microsoft Fixit as indicated in that article and repeat to remove all AutoCAD Electrical components related to this version.
NOTE: The information within the article is solely based on you performing a clean uninstall of all "core" Autodesk products on your machine.  In certain situations, you will most likely not be removing all of your Autodesk products to resolve a given issue.  If that's the case, you'll need to adjust those settings and locations within the article to make sure you are not impacting those other Autodesk products you plan on leaving on your machine.
Mark Lancaster
@Anonymous
Mark Lancaster
in reply to: Mark.Lancaster
Hi Mark
Thanks for the information, however it did not resolve the issue entirely. All the 2019 products (Autocad and electrical) give the following error "problem loading acadres.dll resource file".
What has been done is a clean uninstall, net framework repair and c++ re-install.
I have now reverted back to Autocad 2018 which is working , however Autocad electrical 2018 will not install as it states a newer version is already installed.I have removed 2019 electrical and all the relevant electrical parts, are there any associated files that need to be removed eg:object enablers and auto cad desktop app ??
Regards
Hi Mark
Regards
Administrator Productivity
